New TSB release - Mustang Evolution
Old 10-22-2013, 05:41 AM   #1
bucko's Avatar
New TSB release
For more details on a particular TSB mentioned in the list below, simply type the TSB number in the Google search box.
For those who are new to TSB's, they are Technical Service Bulletins. They are basically a "silent recall", meaning if you take your car in for service that matches a symptom of a TSB, they correct it for free, even if the warranty has expired.
TSB 13-09-22 - Effective Sep 25 2013
SYNC - Various vehicles equipped with SYNC may exhibit concerns related to SYNC features. Refer to the vehicle list to determine applicable vehicle lines and build dates located in the Service Procedure Section along with complete symptom details
TSB 13-09-03 - Effective Sep 4 2013 2011-2014 Mustang
- Grunt/Creak/Chirp/Squeak Noise From The Front Lower Control Arm Over Bumps
TSB 13-08-07 - Effective Aug 20 2013 2012-2013
Multiple Vehicle Line - Intermittent/Inoperative Integrated Keyhead Transmitter (IKT) - Built On 9/1/2011 And Through 12/1/2012
TSB 13-06-15 - Effective Jun 13 2013 2011-2014
Mustang 5.0L - Malfunction Indicator Lamp (MIL) - DTCs P0300-P0308 And/Or P0316 No Drivability Symptoms - Built On Or Before 5/1/2013
TSB 13-05-30 - Effective May 29 2013 2012 Escape, 2012-2013 F150, Explorer, Mustang -
Sun Visor Vanity Mirror Door Will Not Close Or Is Loose - Built On Or Before 8/31/2012
TSB 12-11-12 - Effective Nov 16 2012 2011-2013
mustang Intermittent No Start And/Or Rough Running - Blown Fuse 13 - DTC P0627
TSB 12-08-19 - Effective Aug 28 2012
SYNC - VARIOUS FUNCTIONALITY CONCERNS - BUILT ON OR BEFORE 7/1/2012
TSB 12-08-15 - Effective Aug 17 2012
REAR DRIVE AXLE VENT - OIL LEAK
TSB 12-08-14 - Effective Aug 16 2012 2011-2012
MUSTANG 5.0L WITH A/C COMPRESSOR DRIVE STRETCHY BELT CONFIGURATION - LIGHT LOWER-END ENGINE KNOCK
TSB 12-06-11 - Effective Jun 25 2012
CLUTCH PEDAL SQUEAK OR CREAK NOISE
TSB 12-03-01 - Effective Mar 2 2012 2011-2012
F-150 AND 2011-2012 MUSTANG 5.0L - INTERMITTENT METALLIC RATTLE OR SCRATCHING TYPE NOISE - WARM ENGINE AT IDLE
TSB 11-07-07 - Effective Jul 1 2011 AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION - NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS
Old 10-22-2013, 06:22 AM   #2
DWC_SmOziLLa's Avatar
Great Post. Thanks Bucko!
Old 10-22-2013, 07:01 AM   #3
Seabiscuit's Avatar
The dealer near me told me they wouldn't fix the front control arm groan because I was out of warranty?
Seabiscuit is offline   Reply With Quote
Old 10-22-2013, 08:03 AM   #4
Great info, thanks!
Hiram2011 is offline   Reply With Quote
Old 10-22-2013, 08:10 AM   #5
Whitelightning's Avatar
Same problem with my rear axle vent gushing oil. Had to buy it and do it myself. Not a big deal with a lift in the garage.
Old 10-22-2013, 08:21 AM   #6
Seabiscuit's Avatar
Yeah I just chose to live with it, got bigger things to fix.
Old 10-22-2013, 10:31 AM   #7
bucko's Avatar
Knowledge is good (remember Animal House?). Provide the TSP to the service advisor next time you visit. Simply print it out and present he/she with it.
Old 10-22-2013, 08:39 PM   #8
Right now my front end is wailing away when I turn at low speeds. Not sure what it is but what I did do about my valve is look up the part number, went to said dealership that said they would charge to have the tsb fixed, and ordered the part and I said, I have a lift and can do a better job, thanks for having the part on hand. Not a fan of the ford dealers in Alabama besides the one I bought my car from, 2 hours away; long Lewis ford in Hoover, AL.
Old 10-23-2013, 05:08 AM   #9
bucko's Avatar
Strange. I need to look into this. My dealership explained TSB's as a "silent recall", meaning an auto manufacturer does not recall a vehicle to make the repair, but if a customer comes in and complains about a problem, and a TSB is issued as a repair, then the dealership performs the TSB, and at no charge (at least by my dealership). Some dealerships will pull the TSB list and perform the repairs on vehicles that are in for other service repairs. This happened on my 2005 F150; I took it in to have the rear end fluid serviced, and the dealership performed a TSB on the truck while it was there, as their records showed it had not been done.
Old 10-23-2013, 07:23 AM   #10
Seabiscuit's Avatar
The Toyota dealer I work for handles TSBs this way. They always check for them and then repair whatever it is. I was a little confused when I was told it had to be within warranty...
Old 10-07-2014, 09:10 PM   #11
Vic14's Avatar
Strange I've got the creak/squeaking noise on my 2014 V6. Already took it in twice for this and both times it has been replaced part for part. The dealership never did show any TSB work done. They just told me the creaking/squeaking was normal. Friday I'll be heading there with this new info.
I know you gave us a lot of info but is there new TSB'S now? And thanks for the info bucko
You need to know the rules, to break the rules
"I know I was born and I know that I'll die... The in between is mine." -Pearl Jam
Vic14 is offline   Reply With Quote
Old 10-07-2014, 09:19 PM   #12
5pointYoBro's Avatar
I have the front lower control grunt.
Do I have to go back to the dealership that I bought the car from? I live in TN but bought it in AL
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 10-07-2014, 09:22 PM   #13
Any Ford dealer, well, any honest Ford dealer
Old 10-07-2014, 09:23 PM   #14
Great haha. Hope I can find one close
Old 10-07-2014, 09:26 PM   #15
Vic14's Avatar
+1
I'm lucky the service peeps are pretty decent, the service manager is the one I have pretty good contact with. They only messed up on not doing the TSB from the start.
Old 10-07-2014, 09:27 PM   #16
Going to print this out and bring to dealership
http://cdn.lrsstatic.com/downloads/t...sb12-08-24.pdf
Old 10-07-2014, 09:30 PM   #17
Vic14's Avatar
Was about to tell you this.
Ask for the service manager and show the print out to him/her
Old 10-07-2014, 09:30 PM   #18
Awesome, Gracias
I keep reading online that TSBs are only free under warranty and Recalls are free no matter what.
Edmunds is where I read
Old 10-08-2014, 03:57 AM   #19
ponie1992's Avatar
Subsribing
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 10-08-2014, 04:59 PM   #20
NewMtang's Avatar
Found this site on the net. It brings up the years from 2005-2014. Just scroll down and pick the year.
2005-2014 Mustang TSB's and Recalls
Old 10-10-2014, 03:11 AM   #21
ttt
ttt's Avatar
I'm also experience the clutch pedal squeak/creak noise. Thanks Bucko for providing the info. I will have my local dealer check it out.
ttt is offline   Reply With Quote
Old 10-10-2014, 06:31 AM   #22
Vic14's Avatar
You beat me to it. I was going to post that link lol
Old 10-10-2014, 08:12 AM   #23
blackstang1's Avatar
OMG, That is my favorite part of the movie!!! "Knowledge is good" lol!
2014 Mustang V6 w/Technology package, 6MT
Mods: Airaid CAI w/ Synthamax filter, 18" black AMR wheels
blackstang1 is offline   Reply With Quote
05:42 AM
