1/8 mile times what are you gettimg?? - Mustang Evolution
Old 10-28-2013, 01:56 PM   #1
layton's Avatar
I have a tune and cai and run 9.0 and I am going to 3.73 gears this week from 2.73 it's an auto what do you think I will run now?
And also what are your best times with what gears?
borla atak axle-back exhaust, 19in rtr wheels wrapped in 255/40r19 goodyear fl supercar tires, airaid cai, tinted windows 10%, grabber blue custom stripes. and last a bad a** driver
layton is offline   Reply With Quote
Old 10-29-2013, 07:39 AM   #2
My 1/8th time
I did 8.6754 and 74.40 MPH
No Tune but good hookup.
Back tires at 25PSI--Fronts at 38PSI and did not get them wet. (Stay out of the wet stuff with street tires)
I have the Airaid CAI and Magnaflow streets an Automatic with 2.73 rear.
I'm sure you will do much better with the tune.
Old 10-29-2013, 07:50 AM   #3
Seabiscuit's Avatar
I ran an 8.56@81.61 93 tune, o/r x pipe, jlt cai. Stock 2.73s
Seabiscuit is offline   Reply With Quote
Old 10-29-2013, 09:00 AM   #4
Whitelightning's Avatar
I Hit a 9.10 with roush AB, and a Cai. My lower control arms are shot though and I'm on street tires.
Old 10-29-2013, 09:02 AM   #5
02GTvert's Avatar
Back tires at 25PSI--Fronts at 38PSI and did not get them wet. (Stay out of the wet stuff with street tires) Ronnie
Do this.
02GTvert is offline   Reply With Quote
Old 10-29-2013, 09:08 AM   #6
layton's Avatar
You two must be on a lot better track because I'm running 9.0 at 81.51 mph. I don't see how you get 8.6 running 74
Old 10-29-2013, 09:54 AM   #7
bucko's Avatar
Rear axle ratio's are going to play a huge factor with the times.
Old 10-29-2013, 01:18 PM   #8
Mustangs's Avatar
You guys have good tracks and locations. Tune +3.55s got 9.00
Mustangs is offline   Reply With Quote
Old 10-29-2013, 06:45 PM   #9
With the track I'm at, you can't hook at all with 3.55 but my 2.73 hooked ldescent. But I blew out my bushing on the lower control arms.
Old 11-02-2013, 09:16 AM   #10
Black12's Avatar
My best 1/8th mile time with stock street tires is 9.20 @ 78.33 with 3.55 gears and BMR lower trailing arms to kill the wheel hop. 2.076 60' NO under hood mods. All stock.
Black12 is offline   Reply With Quote
Old 11-02-2013, 09:36 AM   #11
alrefire's Avatar
Yup :p
I spun halfway down the track XD
I'd say the prep is 0
Old 11-02-2013, 09:51 AM   #12
Drag racing is a lot different then track racing
If running street tires it seems the 2.73 ratio automatics 3.7 V6 have the advantage due to a lighter engine up front and way easier to hook up. The 3.31 and lower ratio cars have trouble hooking up. When I ran that night the V8 GT's were not hooking up at all.
But don't think your 3.7 will be faster then a V8 5.0 in the real world from a roll.
Put some drag radials on a V8 or even a V6 with low ratio gears and you will see that these Mustangs are all very quick and surprising.
Drag racing is nice really inexpensive fun unless you get obsessed with trying to be the fastest car at the track. It is fun just to run and not worry if you get beat or you win. Just enjoy the acceleration and have fun.
Old 11-02-2013, 09:54 AM   #13
alrefire's Avatar
If running street tires it seems the 2.73 ratio automatics 3.7 V6 have the advantage due to a lighter engine up front and way easier to hook up. The 3.31 and lower ratio cars have trouble hooking up. When I ran that night the V8 GT's were not hooking up at all. But don't think your 3.7 will be faster then a V8 5.0 in the real world from a roll. Put some drag radials on a V8 or even a V6 with low ratio gears and you will see that these Mustangs are all very quick and surprising. Drag racing is nice really inexpensive fun unless you get obsessed with trying to be the fastest car at the track. It is fun just to run and not worry if you get beat or you win. Just enjoy the acceleration and have fun. Ronnie
Amen!
Do it for the fun of it!!!
Old 11-02-2013, 12:10 PM   #14
powerwhee's Avatar
The 2.73 gears are good for the 1/8th mile. You end up at the finish at the top of second.
With 3.31 or higher gears you need to upshift into third.
---------- Post added at 11:10 AM ---------- Previous post was at 11:09 AM ----------
Originally Posted by powerwhee View Post
The 2.73 gears are good for the 1/8th mile. You end up at the finish at the top of second. With 3.31 or higher gears you need to upshift into third.
That being said my best time before my headers/catless h pipe was a 8.83@81.68 mph w/ a 2.19 60". If I could hook up better it would be a 8.6. With my mods now if I could hook up I think the car has a 8.5@83 + mph in it. Gotta get back to the 1/8th mile and see
powerwhee is offline   Reply With Quote
Old 11-02-2013, 01:01 PM   #15
Oh2freshstang's Avatar
My best was a 9.057 @ 80mph. That was with 2.73s CAI & bama 91 tune. When I went back with LTs/X pipe I couldn't hook & got worse times! Now I have 275 rear tires so I need to go back & see if I can hook any better!
Old 11-02-2013, 07:01 PM   #16
Black12's Avatar
Tires are everything in the 1/4 mile. Your tires have everything to do with a best run. It won't come without them. I use BMR lower control arms and they wiped out the wheel hop issue and really set the tire. If you can launch above 3000 rpm you'll get the numbers. It's hard to do though on stock tires. My 4.23 first gear (6 speed manual) with 3.55s is nuts. Over 3000 and I spin the tires. Using Hoosier drag radials next spring. Looking for a 1.9 something 60'.
04:40 AM
