Will this fit on a 2010 v6 - Mustang Evolution
Old 10-30-2013, 11:51 AM   #1
Ghoststang18's Avatar
http://www.americanmuscle.com/frpp-s...mbly-0512.html
Ghoststang18 is offline   Reply With Quote
Old 10-30-2013, 12:09 PM   #2
I am just curious to if this fits the 2010 v6 mustang because it says 2011 thats y im unsure and this does come with the limited slip diff so that i could do a 2 wheel burnout if i wanted too (not that i would) but yea im just curious hope full i got some help
Old 10-30-2013, 12:11 PM   #3
Mustang 4pt0's Avatar
Oh I'm sure you would. Why else would you want to buy it?
Mustang 4pt0 is offline   Reply With Quote
Old 10-30-2013, 12:28 PM   #4
idk for non tacing reasons so im more stable on the ground lol
Old 10-30-2013, 12:34 PM   #5
So you want to be more stable on the and not be involved in any racing?
Old 10-30-2013, 12:53 PM   #6
silvrbullet2012's Avatar
I'm pretty sure it can fit. It's like you can the IRS from a cobra in a GT just need the parts for it.
Idk what the difference between the 2010 and the 2011 suspension. But I think it should fit.
silvrbullet2012 is offline   Reply With Quote
Old 10-30-2013, 01:15 PM   #7
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
I don't see why this wouldn't fit your car but I want to look into this for your first. Since it fits the 11+ V6's, I don't see why it wouldn't fit the 2010! I'm going to reach out to FRPP really quick and get an exact answer. I'm assuming it's just going to be a small typo though and that it should fit fine!
I'll be sure to let you know!
-Dan
Old 10-30-2013, 02:37 PM   #8
bucko's Avatar
Need the entire axle as a replacement? Just a gear swap with a different ratio could do the trick, or were the 2010 axles that much of a difference (no limited slip)?
Old 10-30-2013, 02:52 PM   #9
I believe the 2010 has the 7.5 axel?
Old 10-31-2013, 01:29 AM   #10
Siber Express's Avatar
Physically it fits, you just have to change the pinion flange over so your V6 drive shaft fits.
7.5 to 8.8 rearend swap questions...
Siber Express is online now   Reply With Quote
Old 10-31-2013, 05:43 AM   #11
Originally Posted by Siber Expres View Post
Physically it fits, you just have to change the pinion flange over so your V6 drive shaft fits. 7.5 to 8.8 rearend swap questions...
thanks bro
Old 10-31-2013, 07:13 AM   #12
bucko's Avatar
Thanks; was not aware of that....I thought all the Mustangs were 8.8.
Old 10-31-2013, 08:10 AM   #13
AmericanMuscle.com
Sponsor
This completely slipped my mind. I contacted FRPP directly and received the response that it wouldn't fit because you have a 7.5 rear end! Like listed above, you could probably make it fit if you'd like do but it won't be a direct bolt on.
I hope this helps and appreciate your patience while I found out the correct answer!
-Dan
Old 10-31-2013, 09:19 AM   #14
JimC's Avatar
An 8.8 rear end from a 2011+ will be a direct fit on a 2005-10 V6. The pinion flange was changed in 2011 and as a result it doesn't have to be changed. Earlier rear ends off 2005-10 GT's just need the pinion change. Everything else mounts exactly the same.
JimC is offline   Reply With Quote
Old 10-31-2013, 11:34 AM   #15
Not to question u bro but are u sure cuz its 1300 dollars i dont wanna buy the wrong thing u know wat i mean bro and thanks for the help
Old 10-31-2013, 12:27 PM   #16
JimC's Avatar
Positive. I've installed 2 on a 2006 and used to broker rear ends for a take off supplier. The first 2011+ rear end we sold had the right flange and didn't have to be changed for a 2008 V6. The only reason it says 2011-14 V6 Mustang is because the 2005-10 had the 7.5.
Both rear ends are 3 link attachment. So it bolts right in.
Old 10-31-2013, 03:22 PM   #17
Positive. I've installed 2 on a 2006 and used to broker rear ends for a take off supplier. The first 2011+ rear end we sold had the right flange and didn't have to be changed for a 2008 V6. The only reason it says 2011-14 V6 Mustang is because the 2005-10 had the 7.5. Both rear ends are 3 link attachment. So it bolts right in.
Thanks bro where can u buy the correct flange for it to be correct
Old 10-31-2013, 07:24 PM   #18
JimC's Avatar
American Muscle has the flange if you need it. It is the cobra flange.
But the rear end you linked to says it is "original equipment on 2012-2014 Boss" so it should have the correct pinion flange for your 2010 V6.
Old 10-31-2013, 09:23 PM   #19
American Muscle has the flange if you need it. It is the cobra flange. But the rear end you linked to says it is "original equipment on 2012-2014 Boss" so it should have the correct pinion flange for your 2010 V6.
Damn bro good lookn out man ur alot of help
03:39 PM
