Handling! - Mustang Evolution
Old 11-02-2013, 04:46 PM   #1
Stampede305's Avatar
Handling!
What would you say is the first and most important handling mod that should be done?
Thanks!
Stampede305 is offline   Reply With Quote
Old 11-02-2013, 04:57 PM   #2
MidnightBlueGT's Avatar
Suspension in general, the best imo would be coilovers/springs or subframe connectors.
Old 11-02-2013, 06:24 PM   #3
Hm can you explain subframe connectors?
Old 11-02-2013, 06:34 PM   #4
Get the weld in design, they work best. They connect the front an rear subframe and stiffen the chassis by eliminating body flex and twist. This helps both responsiveness and handling.
Old 11-02-2013, 06:49 PM   #5
Sounds good how much do they go for? What do you think about strut bars?
Old 11-02-2013, 06:53 PM   #6
About $125. And labor unless you can weld. I've never actually installed strut bars so I cant say. Im doing upper and lower control arms soon though which should be a good difference in feel then Ill be supercharging.
Old 11-02-2013, 08:03 PM   #7
Once lowered I think panhard bar and control arms are essential!
grabberbluedrew is offline   Reply With Quote
Old 11-05-2013, 05:27 AM   #8
strut tower brace is all I needed , shop around for the best price its a 10 minutes install , very easy I felt the improvement right away I doubt you will need anything else unless your going to a road race track the little V6 is pretty well made & doesn't need much more its tight & light from the factory years back the cars had heavy big motors & were not anywhere like these new mustangs
jon paris is offline   Reply With Quote
Old 11-05-2013, 07:39 AM   #9
+1 on the strut tower brace. That is a cheap mod that should come stock, and it firms up the handling nicely.
Before messing with the control arms/chassis/subframe/etc, I would get a good set of wheels and tires. Those might make the biggest difference right off the bat. Once that base is covered, you can see what needs to be improved or stiffened up.
kutch is offline   Reply With Quote
Old 11-05-2013, 09:40 AM   #10
MustangDawg's Avatar
^^ +1 Absolutely on the strut tower brace. First mod I did, really made a difference, fast install and low price. You should be able to do this for no more than $125. I paid $112 for an SR Performance strut tower brace at AM. Go it on sale. Go for it
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
03:25 PM
