Procharger for the 2013? - Mustang Evolution
Old 11-02-2013, 05:37 PM   #1
SouthFLV6's Avatar
Im going to do a couple more bolt ons then I'm going to start to save up for a procharger. My question is, does anyone know when Procharger is going to release a system for the 2013/2014?
SouthFLV6 is offline   Reply With Quote
Old 11-02-2013, 08:04 PM   #2
Someday they will. The 2011-12 kit works with some minor fabrication for the intercooler piping. No tune for the 13 so it has to be a dyno tune.
grabberbluedrew is offline   Reply With Quote
Old 11-02-2013, 09:24 PM   #3
tarupert's Avatar
Region: Nevada
Installed Evolution Performance Procharger 775HP kit on my 2013 Mustang GT/CS convertible. Absolutely no cutting involved. Just bolted on with no problems. I'm putting down 593 RWHP. My car has a automatic transmission.
SCT Tuner, Vinyl Dipped Plenum and Valve Covers, BBK 85mm TB, JLT Oil Catch Can, Pypes Pipe-Bomb Axle Backs, JBA Ceramic Long Tube Headers, High Flow Cat X-Pipe, Forgestar F14 19x9, 19x10, Nitto Invo Tires, Eibach R2 Suspension, Eibach Adjustable Sway Bars Front and Rear, Eibach Adjustable LCA, BMR Rear Lower Control Arm Relocation Brackets, MMD Bolt-On Hood Strut, BMR Pan Hard Bar, Caster Camber Plates, Brembo Brakes, Adjustable UCA and Mount, Dynotech Aluminum Driveshaft, Procharger Stage II, Bosch 75lbs injectors.
tarupert is offline   Reply With Quote
Old 11-02-2013, 09:43 PM   #4
For the 2013 v6 you need to modify the intercooler piping.
Old 11-02-2013, 09:51 PM   #5
Oh2freshstang's Avatar
U also have a 5.0......
Old 11-02-2013, 11:24 PM   #6
SouthFLV6's Avatar
What kind of fabrications? Stuff I can do in my garage? Also, I was planning on getting it dyno tuned anyway lol
Old 11-03-2013, 10:29 AM   #7
From my understanding it's pretty easy. Small trimming for ic piping I believe. I won't know for sure until January.
03:23 PM
