UCA Help - Mustang Evolution
Old 11-21-2013, 12:55 AM   #1
Schram1's Avatar
UCA Help
I picked up the steeda ADJ UCA for 60 bucks. Will i have to swap the mount or will i be fine using the stock one. Who has installed a UCA without upgrading the mount and do you have any noise
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake / BBk TB
J&M panhard bar J&M extreme lower control arm /relo
koni STR.T RTR wheels NT555/ Shelby Baer 6P
DSS Aluminum 3.5/3.73 gears
https://www.youtube.com/watch?v=1cm4Di-zmZA
Schram1 is offline   Reply With Quote
Old 11-21-2013, 06:21 AM   #2
bucko's Avatar
Have you talked to the Steeda support folks about the upper control arm requirements? I'd say they would be the best qualified in answering these good concerns you have.
Old 11-21-2013, 07:52 AM   #3
You can use it with stock bracket, our bracket is far stronger then the factory one. You may get a slight increase in nvh due to the stiffer bushings but the performance trade off is worth it to most performance enthusiasts.
Matt Henschke
Steeda Autosports
954-960-0774
steedamatt is offline   Reply With Quote
Old 11-21-2013, 09:40 AM   #4
Schram1's Avatar
Yah i just need the rear held down more i can feel it moving alot at high speeds and i know it will help my tire from not spinning at launch. my car is lowered to
Old 11-21-2013, 10:15 AM   #5
The lower control arms will eliminate the wheel hop. If your car is lowered and you have wheel spin problems the control arm relocation brackets will help correct the instant center of your car from being lowered and improve the weight transfer.
Steeda 2005-14 Mustang Lower Control Arm Relocation Brackets - Made in the USA 555-8119 - Free Shipping!
Matt Henschke
Steeda Autosports
954-960-0774
11:44 AM
