Upper, Lower Control Arms and Panhard Bar - Mustang Evolution
Old 11-21-2013, 11:52 PM   #1
NewMtang's Avatar
I have the FRHP on my 2013 V6 and 3/4. I dropped the front and back by 1.25 inches. Since I am not taking it to the track, do I still need to put on front and rear control arms?
Do the rear control arms take the place of what some of us seniors put on their wheelchairs to control the wheel hop?
I have been told that since I didn't drop the car 1.5" or more, I won't need a panhard bar.
Thanks to you knowledgeable Stang People out there.
Old 11-22-2013, 01:20 AM   #2
You don't need any of that stuff. Not unless you want to seriously track your car.
The aftermarket rear control arms can help with wheel hop.
Let's see a picture of your car now that it's lowered Mtang...
Old 11-22-2013, 03:44 AM   #3
Tpost08's Avatar
I was informed that if your lower control arms are slanted down towards the front of the car. Than you need new ones with relocation brackets. If it is slanted down towards the axle or flat across than you should be ok. A picture of mine. I need new arms and brackets.
Tpost08 is offline   Reply With Quote
Old 11-22-2013, 08:02 AM   #4
I may be wrong, but I'm pretty sure you still need a pan hard bar even at 1.25". When you lower your car it throws your rear axle out of whack and that's what corrects it, otherwise youll get some whining and noise from your rear end later down the road. As for the control arms, im not sure.
Deep_Impact is offline   Reply With Quote
Old 11-22-2013, 09:20 AM   #5
Otis's Avatar
I have the FRHP on my 2013 V6 and 3/4. I dropped the front and back by 1.25 inches. Since I am not taking it to the track, do I still need to put on front and rear control arms? Do the rear control arms take the place of what some of us seniors put on their wheelchairs to control the wheel hop? I have been told that since I didn't drop the car 1.5" or more, I won't need a panhard bar. Thanks to you knowledgeable Stang People out there.
Since you are already lowered, just have an alignment shop check your alignment. They can tell you if you need a panhard bar. You can't really tell by measuring fender to tire distance if the rear has shifted.
Measure your pinion angle to determine if you need adj upper control arms.
Otis is offline   Reply With Quote
Old 11-22-2013, 06:37 PM   #6
NewMtang's Avatar
The picture posted is 1.25" lowered front and back.
Old 11-22-2013, 06:46 PM   #7
Oh. Ok.
Looks good!
If it drives good, doesn't make any funny noises or anything, hell, I'd just leave it like it is.
I assume that this doesn't void the warranty...
Old 11-22-2013, 07:18 PM   #8
NewMtang's Avatar
Originally Posted by straybullitt View Post
Oh. Ok.
Looks good!
The warranty question is a good one. As far as the dealer I bought it from, I took him a list before I purchased my first mod. I followed up several times and got the same answer, As long as it wasn't the mod causing the problem, I was good to go.
Old 11-22-2013, 07:47 PM   #9
Maybe you should have your pinion angle checked to be on the safe side...
Old 11-22-2013, 10:30 PM   #10
2 Stangz's Avatar
Region: Nevada
Yeah, don't wanna end up like this guy
eibach lowering spring problem
Old 11-22-2013, 10:46 PM   #11
Yeesh.
This seems like a lot of "hoops" to jump through just to lower the car an appreciable amount. You are doing, essentially, a full blown "street prepared" suspension.
So all of those goodies are absolutely required if the drop is more than 1.5 inches?
Old 11-22-2013, 10:48 PM   #12
NewMtang's Avatar
Had the alignment when the suspension was put on. It's good.
Old 11-23-2013, 12:15 AM   #13
Schram1's Avatar
You will have to have a panhard bar installed your rear axle will be way off mine was
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake / BBk TB
J&M panhard bar J&M extreme lower control arm /relo
koni STR.T RTR wheels NT555/ Shelby Baer 6P
DSS Aluminum 3.5/3.73 gears
https://www.youtube.com/watch?v=1cm4Di-zmZA
Schram1 is offline   Reply With Quote
Old 11-23-2013, 02:11 PM   #14
Getn off's Avatar
Just measure the distance between ur wheel wells and rear tires. If ur tires are centered, ur good. If not, just grab a cheap adjustable panhard bar and adjust it to center ur rear axel. Easy cheesy!
Troy
Getn off is offline   Reply With Quote
07:59 AM
