Factory trunk release button - Mustang Evolution
Old 11-22-2013, 06:37 PM   #1
Perma3's Avatar
I want to be able to disconnect it. I hate that it's always on. I'm sure there's a wire that I could cut under the center console that will disable it, I was hoping someone could help me out
Perma3 is offline   Reply With Quote
Old 11-22-2013, 08:15 PM   #2
emery2483's Avatar
why would you..?
emery2483 is offline   Reply With Quote
Old 11-22-2013, 08:21 PM   #3
Black on Boss's Avatar
There is a connector under it that you can disconnect but it disconnects the flasher and TCS as well. Or you could find out which one goes to the trunk and cut it
Old 11-22-2013, 08:47 PM   #4
Perma3's Avatar
That's what I was hoping maybe someone knows what wire it is.. I really don't want to cut wires nor do I have a tester
Old 11-22-2013, 08:57 PM   #5
I'm sure you could find a diagram online
Old 11-23-2013, 04:55 AM   #6
EastTNMustang's Avatar
Originally Posted by emery2483 View Post
why would you..?
Again, why do you want to disable the trunk release? Are you accidentally hitting it or do you plan to use the switch for a different function? Just curious.
EastTNMustang is offline   Reply With Quote
Old 11-23-2013, 05:16 AM   #7
silvrbullet2012's Avatar
Even I'm wondering why do you want to disable it??? You won't be able to open your truck just through your key.
When your driving you can't open it. It's a safety measure.
silvrbullet2012 is offline   Reply With Quote
Old 11-23-2013, 05:24 AM   #8
What will probably happen is:::::::
The Trunk ajar light on the dash will be on forever if you cut the wire.
You also would not be able to use your key fob to open it when you need to.
It would be best to just lock your car when you have valuable things in the trunk.
Old 11-23-2013, 06:17 AM   #9
tc x 4's Avatar
I don't understand either. If someone wants in the trunk, all they have to do is fold the seats down.
Old 11-23-2013, 08:01 AM   #10
Perma3's Avatar
I want to move it to a secret area not so visible.. In miami they break into cars like they smuggle drugs. They've already broke into my car and looked through my trunk. I just want to disable it
Old 11-23-2013, 08:11 AM   #11
What you really need is:
A good alarm with a pager
Then if someone messes with your car the pager will go off alerting you. That give you a chance to call the police right away as you go out to see which way the F^$%#%$ing thieves go.
If they can't get into the trunk they automatically think you have something valuable in there and they will just pry it open causing even more damage.
Put on a good pager alarm and call your insurance company and they will discount your premiums.
Old 11-23-2013, 11:34 AM   #12
If they can get into your trunk all they have to do is put your seats down. Either way they have the ability to get into it.
Old 11-23-2013, 05:59 PM   #13
Region: New Mexico
They won't waste the time in most cases.
You need:
Six7One is offline   Reply With Quote
Old 11-23-2013, 06:02 PM   #14
Screaming Mach's Avatar
You need:
Lol nice
Screaming Mach is offline   Reply With Quote
Old 11-23-2013, 06:36 PM   #15
NewMtang's Avatar
You need:
^+10,000,000,000,000...etc
---------- Post added at 08:36 PM ---------- Previous post was at 08:32 PM ----------
You should cut the wire in the trunk, just in case you walk out and they have attempted to get into the trunk via the back seat. With the wire cut in the trunk, they can't get away. (Just in case the Theft Monkey has the day off).
Old 11-23-2013, 06:44 PM   #16
You need:
Omg! That's awesome!!
Old 11-23-2013, 06:50 PM   #17
FastFord13's Avatar
Couldn't you just disconnect the wire from the button under the console? That way you could re-connect it later, no cutting of any wires.
---------- Post added at 08:50 PM ---------- Previous post was at 08:49 PM ----------
You need:
That is awesome! Lmao!!!
Old 11-24-2013, 11:28 AM   #18
JDM
JDM's Avatar
They won't waste the time in most cases. You need:
Ha ha ha!!!! Loves those ads! I agree.
JDM is offline   Reply With Quote
Old 11-24-2013, 12:40 PM   #19
Hey Perma 3
I think you need to do this and then let us know how it works out for you.
Old 11-24-2013, 03:07 PM   #20
ak_stang's Avatar
Region: Alaska
[QUOTE="FastFord13;1871411"]
"Couldn't you just disconnect the wire from the button under the console? That way you could re-connect it later, no cutting of any wires."
This is what I would do, but iihs.net/fsm has an electrical diagram for the whole car
ak_stang is offline   Reply With Quote
Old 11-25-2013, 05:29 AM   #21
bucko's Avatar
Simple; don't cut anything wire wise at the console or trunk area; simply unplug the connector at the trunk release latch in the trunk. This way you can plug it back in if/when you trade/sell the car, and it will be operational again to the next owner.
Old 11-26-2013, 02:49 PM   #22
ftrader's Avatar
Thanks! In Miami too and just realized this as well👀
ftrader is offline   Reply With Quote
Old 05-07-2014, 10:05 AM   #23
Help I am unable to get into my trunk of my 2014 mustang. The key FOB or the trunk release. Do the seat fold down or is there something that I can do other than taking it to a dealer???
Neysea is offline   Reply With Quote
Old 05-07-2014, 10:39 AM   #24
LuisBlackGT's Avatar
Yes the seat folds down
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 05-07-2014, 10:41 AM   #25
bucko's Avatar
Yep. Fold down the rear seat(s) to access the trunk area.
Do you hear any type of noise around the trunk latch area when pressing the trunk release button, or the key fob button? This can aid in troubleshooting; narrows down either a bad trunk release, or a weak battery in the key fob, or the trunk release button on the console.
Old 05-07-2014, 10:43 AM   #26
In case you don't know how to fold the seats down just pull thisClick image for larger version
Name:	ImageUploadedByMustang Evolution1399480992.382654.jpg
Old 05-07-2014, 03:33 PM   #27
Bear376's Avatar
Go to a qualified auto electronics technician. Have him install a slick switch that will need to be active before anyone can use the trunk button. While he is at it, have him install a relay and alarm that will activate when the trunk button is pressed and the slick is not in the on position. You might also look into a GPS locator tied into the GPS antenna where you can track your car if stolen.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 05-07-2014, 07:30 PM   #28
Getn off's Avatar
Um. Mine does! Ask me how I might know this little morsel of information!
Troy
Getn off is offline   Reply With Quote
02:11 PM
