sounded like water in the doors ? - Mustang Evolution
Old 11-28-2013, 05:22 AM   #1
after that big rain the other day when backing up it sounded like there was water inside the doors ? a 2013 ...... after a few miles it seemed to go away , have any of you guys had that problem . sure sounded like water sloshing around
jon paris is offline   Reply With Quote
Old 11-28-2013, 05:40 AM   #2
I've heard of someone having water in the rear panels or something like that. My girlfriends 06 ford five hundred gathered water in her rear doors. I drilled a couple small holes on the lowest point of each door to drain cause it didn't go away
Old 11-28-2013, 06:27 AM   #3
thanks for the heads up some years ago I went to a Ford dealer for parts ,a man& his wife were there the whole trunk was like a swimming pool ! it wasn't the first time ! he refused to take the car & left it in the middle of the floor ........ was a brand new car , the manager handled it wrong & the people got even more angry I left as it was headed for trouble I just cant remember what model it was ? I hope this doesn't happen again I like the car but I,m not drilling any holes in a 2013 let them fix it will let you know how it turns out will get a garden hose & spray the front windows & rear area & see what happens
Old 11-28-2013, 06:31 AM   #4
David Young's Avatar
clean out the drain holes in the bottom of the door. Might have gotten cloged with leaves, pine tree needles etc.
David Young is offline   Reply With Quote
Old 11-28-2013, 07:22 AM   #5
Blogger
99ford's Avatar
Do you have a vert or coupe?
Old 11-28-2013, 09:29 AM   #6
leak
its a coupe I looked under the door & there are two plastic plugs one front & one back , look to be about 3/4" - 1 1/2 ..... I can see they have an opening behind them look like they snap right out , should I just remove them ? thanks for any help are your cars the same way ?
Old 11-28-2013, 09:49 AM   #7
Blogger
99ford's Avatar
I can't speak for the coupe but the vert's are identical because they use a lot of similar components on the S197 chassis. I would try removing those plugs, my rear quarters filled with water last year, and I had to vacuum out the water and then suck up the dirt clogging the drain holes.
07:55 AM
