Heater Blows cold - Mustang Evolution
Old 12-09-2013, 10:53 AM   #1
bigmac3's Avatar
Heater Blows cold
It's freezing here in North Texas and I went out with my 2011 V6 the other day only to find that it is blowing cold air from the heater and defroster vents. I kept waiting for it to warm up and it never happened. Temp gauge reads normal water temp. Any ideas?
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 12-09-2013, 11:06 AM   #2
bucko's Avatar
Do you have the manual type temp dial, or do you have the auto temp (if that was even an option for the Mustang...). Is the temp dial all the way over to the red?
Old 12-09-2013, 11:10 AM   #3
bigmac3's Avatar
Like mentioned earlier, the temp is running halfway between C and H. It's an analog gauge.
Frank
Old 12-09-2013, 11:18 AM   #4
bucko's Avatar
I was refering to the dash knob used to control the cool/heat temp that comes out of the vents!
The dash control knob may not be opening the blend door to allow heat to the vents. What happens if it is all the way to the hot side?
I had an F150 that had a simular fault. The fix was to replace the seal (under warranty) for this blend door. That was a 2005 though, so I do not know if our current mustangs have this issue. I'm off to check the repair manual to see.
Old 12-09-2013, 12:25 PM   #5
bigmac3's Avatar
Thanks Bucko, that was what I was thinking was a posible problem. Yes, the temp control knob was turned all the way to the hot side. I once had a similar problem with the a/c blowing warm air during acceleration. I have an extended warranty so it is going to the shop but thought I would just ask if anyone else has such an experience.
Frank
Old 12-10-2013, 03:15 AM   #6
jomcgui's Avatar
Heater delete. Warm weather model option.
jomcgui is offline   Reply With Quote
Old 12-10-2013, 04:35 AM   #7
bucko's Avatar
Really?
Old 12-10-2013, 07:14 AM   #8
bigmac3's Avatar
Got a point, up to this past week, wasn't needed.
Frank
02:00 AM
