One piece driveshaft noise? - Mustang Evolution
Old 12-10-2013, 01:37 PM   #1
SouthFLV6's Avatar
I installed my driveshaft this weekend and I noticed when I shift from park to reverse or drive to reverse I hear a clinging noise. Anyone have or had this problem and knows how to solve it?
SouthFLV6 is offline   Reply With Quote
Old 12-10-2013, 09:22 PM   #2
2011 Kona Blue's Avatar
Mine sometimes does it. Not always but sometimes. I don't really pay any attention to it. Lol
Old 12-10-2013, 10:06 PM   #3
NewMtang's Avatar
Mine sounds like a clunking sound.
Old 12-10-2013, 10:40 PM   #4
Mine similar but only for a quick second
Old 12-11-2013, 10:08 AM   #5
SouthFLV6's Avatar
Any ideas on how to get rid of the noise?
Old 12-11-2013, 01:42 PM   #6
Bear376's Avatar
Have you lowered or changed any suspension parts?
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 12-11-2013, 02:16 PM   #7
SouthFLV6's Avatar
Yeah I've lowered it an inch and a half
Old 12-11-2013, 06:15 PM   #8
NewMtang's Avatar
Yes but I did the suspension work first and no sound. I installed (my mechanic) installed the new driveshaft later.
Old 12-11-2013, 06:36 PM   #9
SouthFLV6's Avatar
same here
Old 12-11-2013, 10:00 PM   #10
Bear376's Avatar
One piece shafts are more susceptible to alignment issues. You need to install adjustable UCA and pan hand bar. I would also do adjustable LCA. Once installed, have a good mechanic adjust the differential/shaft angle. Failure to keep the proper alignment will cost you in the future.
From American Muscle:
When changing from a four-link suspension to a three-link suspension, Ford used a panhard bar. This change results in an additional consideration for owners of these cars. With a panhard bar, as the rear axle rises and falls, movement is in a slight arc instead of completely vertical. This arc also comes into play as the car is lowered, and the result is that the rear end will shift slightly to one side as the car is lowered. The solution to this shift, is an adjustable panhard bar to replace the fixed length factory bar. This allows the rear end to be properly centered again, once the vehicle is lowered.
Pinion Angle
The three-link suspension can also affect the vehicle’s pinion angle as well. An incorrect pinion angle can cause undesired stress on the universal joints, excessive drivetrain noise or vibration, or even possible contact between the underside of the car and the rear axle. To combat this, you want to look into an aftermarket upper control arm. You can choose between fixed length replacements, or adjustable options.
Old 12-11-2013, 10:44 PM   #11
NewMtang's Avatar
If this is true, american muscle dropped the ball!!!
Mine was lowered only 1 inch, Ford Racing Handling Package for V6. Any recommendation on UCA or Panhand Bar?
When I ORDERED the Ford Racing Handling Package, IT sure would have been nice if someone (like who took the order) had told me I might also need Upper Control Arms and an adjustable Panhard Bar!!! Especially since the Ford Racing Package was installed, these could have been installed cheaper!!!!!
Old 12-12-2013, 03:46 PM   #12
Bear376's Avatar
American Muscle has several guides with the information you need. They also have several different panhard bars and upper control arms that would do good. I am looking at the Whiteline versions. Not the cheapest, but good reputation. I would also get the pan hard brace to go with the panhard bar.
11:47 AM
