Am I getting screwed? - Mustang Evolution
Old 01-07-2014, 11:03 AM   #1
So I went by my local muffler shop today to get an estimate on how much it would cost to cut my existing Y-Pipe off and install a true dual system with straight piping going from the cats to my mufflers, no mid pipe at all.
After seeing how much pipe they would need I got told the price would be $325 for everything including labor, pipe cost and what-not. Now, a question to everyone on here. Is that too much or a decent price. Am I getting played or what? Also, this is my first post here!
10konastang is offline   Reply With Quote
Old 01-07-2014, 11:45 AM   #2
Bear376's Avatar
There is no reason to separate the system. The H-pipe/X-pipe design is beneficial to the performance of the engine. It helps remove the exhaust from the combustion chamber and give a cleaner burn. Different designs are used to tune where the effect is most beneficial.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 01-07-2014, 12:50 PM   #3
Well at the moment it is for sound/looks. Either way, upgrading to a dual exhaust is helping it performance wise at least a little, getting away from the restrictive Y-Pipe that is. I will eventually probably upgrade to an H-Pipe but wont ever put an X on a v6 because it's too raspy in my opinion. But I made this thread about the price, whether it was a decent deal.
Old 01-07-2014, 12:56 PM   #4
DaBluedude's Avatar
For a custom bent system that's actually pretty good price wise as long as they're using decent pipe. As stated, you should do the H pipe now. With a custom bent exhaust, you won't get an opportunity to do it later as the custom stuff wont be easy to work on again once it's all welded up. I would definitely get an H done now.
2003 Mach 1
Old 01-07-2014, 01:19 PM   #5
Would it be easier for them to custom fab an H-Pipe and cost more, or would it be better to try and find one online. I can't seem to find many H-pipes and the ones I do are O/R. Only one that I have seen was the Mac Pro Chamber.
Old 01-07-2014, 02:58 PM   #6
Black12's Avatar
If I read this correctly. You are removing the Y pipe that connects both banks into one single exhaust pipe. Then yes, this is a good move and the price isn't bad. Consider an X or H pipe. Have fun.
Black12 is offline   Reply With Quote
Old 01-07-2014, 03:46 PM   #7
I'm assuming he has a '10 V6 since he has a y pipe, in that case he has an even firing order and it is perfectly fine to run divorced duals. The H and X is only needed with the V8s that have an uneven firing order.
Old 01-07-2014, 04:40 PM   #8
Bear376's Avatar
If he has a 10' with single exhaust, then yes he would be better to go with dual exhaust, and the price is fair. But the H pipe should be included and would be easier to do now than later. The H pipe improves the efficiency of the engine in the mid-range of any V-engine, which would include the 4.0 and most people like the sound with the H pipe The X-pipe is best for high rpm applications, and probably not as suited for the 4.0.
07:19 PM
