Negative effects - Mustang Evolution
Old 01-14-2014, 12:26 AM   #1
Ntbruncie's Avatar
Negative effects
Is there any negative effects to running my car after I change my gears to 3.73 with out doing a tuner to change the speedo and odo right away
Ntbruncie is offline   Reply With Quote
Old 01-14-2014, 12:38 AM   #2
2 Stangz's Avatar
Region: Nevada
Speedometer will be off and you'll be racking up more miles on your odometer faster than you actually will be
Old 01-14-2014, 12:41 AM   #3
Oh2freshstang's Avatar
+1
Old 01-14-2014, 01:17 AM   #4
Ntbruncie's Avatar
I'm talking about less that 30 days
Old 01-14-2014, 03:30 AM   #5
Depending on how much u drive it ur odometer will add extra miles.
Old 01-14-2014, 03:50 AM   #6
Tyriqq's Avatar
My understanding is that it will put more stress on your tranny. You shift points change if you have an automatic. If you have a manual then don't worry about it
Tyriqq is offline   Reply With Quote
Old 01-14-2014, 01:43 PM   #7
Ntbruncie's Avatar
I have a manual.
Old 01-14-2014, 01:52 PM   #8
SixBanger's Avatar
With a manual, your odometer and speedometer will both be wrong. If you had a manual, shift points would be wrong too.
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 01-15-2014, 09:36 AM   #9
Black12's Avatar
30 days shouldn't matter. I doubt your the first in this situation. If you got a code, then stop! Codes will burn in over time and you will never get rid of it. Definitely get the tuner. Diablosport works really well.
Black12 is offline   Reply With Quote
Old 01-15-2014, 10:38 AM   #10
I'm curious how it would hurt your transmission or cause it to shift any differently...never ran into that problem before...
Sent from my massive johnson.
Old 01-15-2014, 10:40 AM   #11
Codes don't "burn in over time".
Some people really need to check their information...
Old 01-16-2014, 06:38 PM   #12
ak_stang's Avatar
Region: Alaska
Yea I'm with you, he stated he has a manual so the tranny is fine, only the odometer and speedometer will be the important things to worry about
ak_stang is offline   Reply With Quote
Old 01-17-2014, 01:44 AM   #13
bucko's Avatar
Where did you come up with this???
Old 01-17-2014, 11:43 AM   #14
ArtU's Avatar
My guess it is might be a misunderstanding between "pending codes" and Hard codes that turn on the CEL. Both can be viewed or cleared in the Andriod App "Torque" with a USB dongle.
Old 01-17-2014, 01:10 PM   #15
alrefire's Avatar
Honda forums :p
Hahaha
OP I wouldn't, especially if auto,
Your transmission and engine won't like it.
It'll say 3k, and you'll actually be turning 5k.
Shift points will be off.
It'll throw your entire system out of whack.
Just play it safe and get a tuner.
Old 01-17-2014, 02:45 PM   #16
2 Stangz's Avatar
Region: Nevada
To OP:
Look guy, I'm going to be blunt. Don't take the cheap way out on your $30k+ car. A tuner costs 1/100th of what you paid for your GT.
Old 01-22-2014, 02:50 PM   #17
pwrby4d's Avatar
A speeding ticket would be a negative affect. just get the tuner ASAP or bring it to a dealer to change the axle ratio in the tune if u never plan on doing any mods that require a tune ever.
pwrby4d is offline   Reply With Quote
Old 01-22-2014, 04:44 PM   #18
alrefire's Avatar
Dealer will only be able to do why comes in stock cars.
For a v6, they can tune for 2.73 or 3.31
Old 01-22-2014, 04:45 PM   #19
2011 Kona Blue's Avatar
Actually, completely the opposite. The 3:73 gears helps the transmission work easier NOT add stress. Its better for your transmission.
Old 02-12-2014, 07:19 PM   #20
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I personally bought my tuner first so that I wouldn't run into this issue, but I've got an auto, so it's a different situation haha. Also, you don't know what might happen in those 30 days. Something could come up, that doesn't allow you to buy the tuner, so now your car is still racking up extra mileage for longer than you planned.
To OP:
Umm the OP has a V6, just sayin.
2012 Kona Blue 3.7L V6:
Old 02-13-2014, 11:38 AM   #21
David Young's Avatar
I'm not sure about this but its something to think about. I think your 'Advance Trac' might go crazy. Since your speed and rpm will be miss matched, your 'Traction Control' 'might' start applying the brakes and all kind of crazy things. Maybe?.........
David Young is offline   Reply With Quote
Old 02-13-2014, 03:02 PM   #22
ak_stang's Avatar
Region: Alaska
I believe traction control looks for speed difference between individual wheels, if all the wheels go the same speed you should be fine
Old 02-14-2014, 05:27 AM   #23
bucko's Avatar
Your avatar pic had me cringing....that snow!
Old 02-15-2014, 08:33 AM   #24
The Puma's Avatar
You mean an automatic?
The Puma is offline   Reply With Quote
Old 02-15-2014, 08:36 AM   #25
The Puma's Avatar
Originally Posted by alrefire View Post
Honda forums :p
Hahaha
+1
Intake Spacer Effects on RPM power band? DieselStang 1979-1995 Mustang GT 1 04-18-2013 07:35 AM
Quad shock removal, adverse effects? deadsp0t 1979-1995 Mustang GT 7 09-19-2012 11:20 PM
Interior lighting effects FifeGotem 2005-2010 Mustang GT 40 10-04-2011 07:09 AM
06:42 AM
