My chin spoiler is ripping off need help - Mustang Evolution
Old 01-16-2014, 06:18 PM   #1
So I just bought a brand new 2014 mustang and with some dips in the road I somehow managed to mess up my chin spoiler half of the spoiler is coming off I look under it and it pulled the screws out and broke the holes so I was wondering what can I do just to fix it should I just put more screws threw it? But I'm afraid if I do that I'm going to just break the bumper if I try to drill new holes
walter0711 is offline   Reply With Quote
Old 01-16-2014, 06:25 PM   #2
silvrbullet2012's Avatar
Have any pics of the damage? If it's not that bad you can get some self tappin screws and drill them in.
silvrbullet2012 is offline   Reply With Quote
Old 01-16-2014, 06:44 PM   #3
Ya it's to late right now but I'll post some in the morning
Old 01-16-2014, 09:00 PM   #4
Bear376's Avatar
You probably ripped out some of the J-clips that hold the screws on the bumper panel. Not something you can find easily, as I recently found out. You can get a replacement base unit from CJ Pony Parts for about $100. Another option is if the remains are damaged in the right places, you might put a Roush splitter on it since it requires removing a couple of strips from the top.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 01-17-2014, 05:56 AM   #5
fordfan100's Avatar
If the holes aren't stripped just get a little bit longer screws and some washers that's what I did on a buddy's car
fordfan100 is offline   Reply With Quote
Old 01-17-2014, 02:53 PM   #6
Here is the damageClick image for larger version
Name:	ImageUploadedByMustang Evolution1389995577.280443.jpg
ID:	144922Click image for larger version
Name:	ImageUploadedByMustang Evolution1389995597.234175.jpg
Old 01-17-2014, 10:30 PM   #7
Bear376's Avatar
It looks like you might get by with some new J-clips. The existing 7mm units are hard to find, so you may have to look around. Make sure to get the ones for plastic. Remove the existing screws and clips. The clips are consider single use, but if you are careful and lucky you can reuse some. You may have to carefully select some alternate locations to fasten it, drill a ⅛" pilot hole, and then drill the bumper cover out to ¼". Then insert the clips and screw together. Also, there are three plastic push rivets in each corner that may be pulled out and need replacing.
Old 01-17-2014, 11:09 PM   #8
Ok sweet ty
Old 01-18-2014, 09:58 PM   #9
Shockesh's Avatar
Looks like a good opportunity to,install a rough chin spoiler. It comes with all the clips you need and it (IMO) looks better than the default spoiler. I have a 2014 as we'll and it makes the car look even better. Just my two cents.
Shockesh is offline   Reply With Quote
Old 01-18-2014, 10:02 PM   #10
Ya but since I busted the bottom of the bumper won't I have to get an all new bumper to
Old 01-18-2014, 10:45 PM   #11
air_commando88's Avatar
If your getting the Roush no you won't. You cut some of the stock one up to use as a template for the Roush. It really just uses it's end pieces to connect to the inside of the fender where the stock one did.
Sent from my HTC6435LVW using Mustang Evolution mobile app
air_commando88 is offline   Reply With Quote
Old 01-18-2014, 10:58 PM   #12
Alright I'll look into it thanks
Cervini's type 2 chin spoiler M3hunter 2011-2014 Mustang GT 7 12-26-2013 03:27 PM
FYI: CDC chin spoiler and Retro billet grill fitment issue ThinBlueLine 2011-2014 Mustang GT 0 09-07-2012 07:41 PM
Mach1 chin spoiler Burkeys96GT 1996-2004 Mustang GT 9 12-12-2011 12:54 PM
Chin spoiler? GoldenPonyBoy 2005-2010 V6 Mustang 25 12-07-2011 01:05 PM
Chin Spoiler... check. jbanks 1996-2004 Mustang GT 14 07-08-2011 04:16 PM
07:33 AM
