Mpt ghost cam issues please respond if u have tune - Mustang Evolution
Old 01-19-2014, 11:17 AM   #1
pwrby4d's Avatar
Ok. So I have a Stage 2 GC tune. I dont use it much. When starting it makes this clack clack clack clack sound very fast sometimes before the car turns on. Sounds like the timing chain or something maybe the tvict phasers or something spinning to relocate the cams IDK just a guess. In any case, I had MPT make the tune over three times and every tune they sent did it. The first tune the idle surged really bad. The second still had surge and the third was better but all three had the sound I am describing.
Anyone else?
pwrby4d is offline   Reply With Quote
Old 01-19-2014, 01:24 PM   #2
Getn off's Avatar
I don't have their tune, I have the Bama ghost. No problems here. The ghost idle will surge...thats the point. In fact it will die if ur not quick with the throttle.
As for the clicking...sounds like injectors to me. Maybe the injectors are activated a bit early, or maybe that is designed that way on their tune?!
Did u datalog for them and have them check it out yet? Might be a great starting point.
Good luck,
Troy
Getn off is offline   Reply With Quote
Old 01-19-2014, 06:29 PM   #3
pwrby4d's Avatar
Hey good point with the injectors I never thought of that but it sounds more like a chain on a bicycle kind of sound. That might be it.
Yes the idle surge is the point but this was like RPM going from 500 then going to a grand and then hanging for 2 seconds and back down to 500 and hanging for 2 seconds and repeat over and over. They got it right so no worries with that. I did not datalog. I plan on it but just wanted to post to see if anyone else has the issue and is that normal. I am going to try to capture it and see if I can hear it from the fuel rail.
Thanks Troy!
Old 01-19-2014, 11:01 PM   #4
Charlie_santos's Avatar
Do a data log. If u want talk to Jon Lund and ask him to do a courtesy review of the MPT tune. He will tell you whats wrong.
Old 01-19-2014, 11:03 PM   #5
I have a MPT stage 3 GT and a Lund Racing GT and holy **** is Lunds tunes way better. Pulls harder, idles smooth. Like with my ghost cam the idle doesnt surge crazy it looks like its holding steady at 850
Old 01-20-2014, 05:53 PM   #6
13savage6's Avatar
Charlie I did not kn8w that lund ma,ke gt for the 3.7
mods- eibach sportline springs, camber bolts, j&m panhard bar, pypes pipebombs, upr short shift kit, 92 hybrid bama tune , JLT cai ,lethal perfomance o/r x-pipe , pypes m-80 mufflers.
13savage6 is offline   Reply With Quote
Old 01-20-2014, 07:10 PM   #7
oh I meant he will tell u whats wrong with ur car. I have his GT for my 5.0 and the MPT is for my 3.7 but he looked over it and told me what to tell mpt to adjust for it.
---------- Post added at 08:10 PM ---------- Previous post was at 08:09 PM ----------
He might make them im not sure id have to emal him and ask.
Old 01-22-2014, 05:56 AM   #8
pwrby4d's Avatar
He probably looked at it as a courtesy for you because you were a customer though. So Charlie, did your MPT tune for the 3.7 ever male any noise as soon as you turned the key? Also, did MPT adjust your tune after Lund gave you the adjustments he suggested?
Old 01-22-2014, 09:48 AM   #9
He is a good friend of a friend so he made me a free tune so yea prolly. Ive never had issues besided the first one sent having jerking issues since im an auto. But they fixed that. And yes they tweaked what I asked. They were wondering how I knew what was wrong n how to fix it and I told them I had lund look over ky data long and they were like ohhhhhh ummmmm okay hahaha.
The only issue ive seen is the engining making a ticking noise but ive only seen it from my two buddies with manual cars
Old 01-22-2014, 12:33 PM   #10
pwrby4d's Avatar
gotcha. it doesnt do it every time only every once in a while on start up. makes this clack clack sound when the key is turned on to ignition for like 3 seconds and then it starts right up. I stopped using it and now that I am looking at buying a procharger I doubt I will be able to use it at all. But I am curious as to what the sound is. M.aybe Ill load the tune in and try to capture it on video
Old 01-22-2014, 02:54 PM   #11
Load the tune and do a data log and a video
Old 01-22-2014, 03:28 PM   #12
pwrby4d's Avatar
Ok loaded it in again. Of course I start it a few times on video and it doesn't do it . Then I'm out and start it with no video and it does it . It sounds like the throttle body is opening and closing maybe adjusting very rapidly. Hmmm.
Old 01-22-2014, 03:29 PM   #13
pwrby4d's Avatar
I'm gonna get it on video I will keep the tune in and every time I start it I will roll video at this point. Idk if data logging will help because it only does it at start up occasionally. Won't data logging only track when it is running? The tune seems to run fine. It only makes this noise on the ghost tune though and not on any other tune by other vendors.
Old 01-22-2014, 05:24 PM   #14
Thats really weird :/
Old 01-22-2014, 05:35 PM   #15
Whitelightning's Avatar
Did it do this before? Or any other tune? I think that may be your starter. My starter fires slower and it just sounds unhealthy. But it's 37* in the morning when I start it up. Just a thought.
Old 01-22-2014, 06:17 PM   #16
pwrby4d's Avatar
No when I load in any other tune it is fine. I had another tune in for about a month now and no issue. Loaded in the MPT tune and it did it on like the 10th start. Does it randomly and sounds like it is coming from the top of the motor.
Old 02-28-2014, 07:34 AM   #17
I'm reviving this is hopes of having an answer to the grinding your were facing.
A fellow member in a cyclone mustang chapter I'm part of informed me that when you go to turn the car off, give it gas before you do, it'll reset the cams back to normal so you can shut it off.
Without doing so, the car will have a grind on start up. Hope this helps. He had a stage 3
Old 02-28-2014, 11:59 AM   #18
No idea what ur talking about bro^^^ both my 3.7 and 5.0 don't have that issue while loping and shutting off
Old 05-14-2014, 07:15 AM   #19
pwrby4d's Avatar
Next time I load the tune I'll try it. Thanks!
For those who are running BAMA cam tune back n a stang 2011-2014 Mustang GT 10 03-24-2014 04:50 PM
Custom vs. Strategy Tune (BAMA SCT) Rynarok AmericanMuscle 63 06-17-2013 09:21 AM
Bama 93 series tune issues after H-Pipe install 2013_stang_gt 2011-2014 Mustang GT 7 09-26-2012 04:31 PM
Bama ghost tune. 86custom 2011-2014 Mustang GT 138 08-02-2012 03:22 PM
Cai and tune bigsmitty24 2011-2014 Mustang GT 41 10-11-2011 09:08 PM
02:27 PM
