Brake conversion ? - Mustang Evolution
Old 01-21-2014, 10:13 PM   #1
Whitelightning's Avatar
Brake conversion ?
Is it possible to "upgrade" to a GT sized rotor. From my understanding the calipers are the same. What's different is the bracket, and the rotors?
Old 01-21-2014, 10:52 PM   #2
Charlie_santos's Avatar
You can do it easy and relatively cheap. Just buy the caliper and rotor from Roush ebay site and swap everything out. Its pretty easy.
Old 01-22-2014, 12:22 AM   #3
crazychink's Avatar
They are cheap from Roush ebay store as previously mentioned.
brackets + calipers(same as V6) + rotors, all for 125 shipped
MUSTANG-13-2-GT-FRONT-BRAKE-ROTORS-SET-OEM-FACTORY-TAKE-OFF-
MUSTANG-GT-FRONT-BRAKE-CALIPER-SET-2-OEM-FACTORY-TAKE-OFF-
Installation just follow this video, you only need to swap over the brackets and rotors
but why not go for brembos?
crazychink is offline   Reply With Quote
Old 01-22-2014, 08:24 AM   #4
Because broke college kid!
Old 01-23-2014, 01:47 PM   #5
bucko's Avatar
Confused. Are the V6 calipers the same as the GT's, and we only need the caliper BRACKET off of a GT to switch to a GT rotor?
Old 01-23-2014, 02:11 PM   #6
Same caliper which is why the front pads work on my v6 and 5.0 u need the bracket to clear the larger rotor
Old 01-23-2014, 11:02 PM   #7
Gunner's Avatar
Brake conversion ?
So the performance package says it has the GT Coup suspension. Does that include the brakes, and what are the differences in the two suspensions?
Gunner is offline   Reply With Quote
Old 01-24-2014, 04:41 AM   #8
bucko's Avatar
What about the rears? I'm assuming the GT's use alarger rotor in the back? If so, is it a matter of swapping out the rear caliper bracket as well?
Old 01-24-2014, 07:15 AM   #9
My question is, if it's so simple sounding, why hasn't anyone done it? I know the 2011 guys like me should be nearing a milestone servicing. Instead of servicing I'm just upgrading.
Old 01-25-2014, 08:14 AM   #10
crazychink's Avatar
As far as I know V6 performance pack has the same size rotor as base model except PP uses different brake pads.
Rear is the same size, even on the Shelby up to 2012 model. Only the 2013+ Shelby has larger rear rotors.
It is that simple, every V6 owner should at least upgrade to GT rotors front if you ask me.
Old 01-25-2014, 01:22 PM   #11
JimC's Avatar
The 2011+ V6 already has the same size front brakes as the 2005-10 GT. So not an upgrade to add the GT brakes from 2005-10 to a 2011+.
JimC is offline   Reply With Quote
Old 01-25-2014, 08:33 PM   #12
ArtU's Avatar
You are correct, the 2011 V6 can go or accelerate about as fast as a 2007 GT, so they put that size on the 2011+ V6. BUT the 2011+ GT is even larger since it has more power; and these pull offs allow us 2011+ V6 folks get the better stopping power.
I think I will get a "pull off" set and wait on putting them on until I need to.
Old 01-25-2014, 09:23 PM   #13
JimC's Avatar
You are correct about the even bigger front brakes on the 2011+ V8 Mustang. But the picture that I saw was of a 2005-10 Mustang and so I didn't want to see someone buying a take off set for those model years, only to find they already have that on their 2011+ V6.
Old 01-25-2014, 09:31 PM   #14
ArtU's Avatar
These FRONT Brake Rotors were taken off a brand new 2012 Mustang GT, so that it could be converted into a ROUSH Mustang
Good Point Jim , while the calipers seemed to be a good ad; looking at that upgrade table on the rotors they say they come off a 2012 GT, so what am I missing that as a intermediate?
http://www.ebay.com/itm/2011-2012-FO...item3f2aed9743
Art
Old 01-26-2014, 06:42 AM   #15
ArtU's Avatar
Ok, I think you are saying that the Calipers in the set are the same but only that the bracket size changes? Yes I was willing to buy the Calipers at the take off prices to get the bracket. Also have spare parts on the Calipers should the factory ones get worn at 60-70k.
Old 01-27-2014, 05:18 AM   #16
bucko's Avatar
I just finished the front upgrade this weekend. Easy peasy. Remove the caliper, hang it with a clothes hanger, remove the stock V6 caliper bracket, remove the stock V6 rotor, install the GT rotor, install the GT caliper bracket, re-install the caliper (you may need to compress the pistin in a bit if the GT rotor is new and perhaps thicker than your removed V6 rotor; use a simple C-clamp for this), and your done.
For anyone that perhaps bought some new rims that were specific to V6 only, make sure the GT bracket with the V6 caliper clears the inside of the rim as a precaution.
Old 01-27-2014, 07:25 AM   #17
Tangster's Avatar
I actually did brakes upgrade last fall. From V6 PP brakes to GT500 6 pots with 15" rotors. I saw a very good deal at ebay that I was not able to resist. The package includes brake calipers and rotors in all 4 corners, rear bracket and parking brake cable for under $1k. So far it works well for me. I lost about 1.5 to 2 mpg per fill the first few fill, but now my mpg seems like it slowly coming back to where it was prior to the brakes upgrade.
Tangster is offline   Reply With Quote
Old 01-27-2014, 08:11 AM   #18
crazychink's Avatar
You were able to fit 6 pots in those PP rims? How thick is the spacer that's require to clear? Your car looks great btw
Old 01-27-2014, 09:17 AM   #19
Swag. Click image for larger version
Name:	ImageUploadedByMustang Evolution1390839410.908522.jpg
ID:	146015 redid the brakes. Also the back of my front calipers are labeled v6... Are y'all sure the GT and V6 are the same?
Old 01-27-2014, 09:21 AM   #20
Tangster's Avatar
Yes, I only use 1/2" spacers. Btw, I have to mention that you have to change your studs for you to be able to use the spacers. Stock studs are too short to work with 1/2" spacer. I am using the ARP 3" studs I bought from LMR. You can actually use the 2.5" studs for 1/2" spacer.
Some pics of the swap:
Front
Name:	ImageUploadedByMustang Evolution1390839463.044338.jpg
Back
Name:	ImageUploadedByMustang Evolution1390839494.260954.jpg
With PP wheels
Name:	ImageUploadedByMustang Evolution1390839648.327212.jpg
Old 01-27-2014, 10:51 AM   #21
VIG
VIG's Avatar
Region: Delaware
Can you feel any difference??
VIG is offline   Reply With Quote
Old 01-27-2014, 11:42 AM   #22
bucko's Avatar
On the street, honestly, no. However, I have not been on a road course track recently where I have had to make a high speed stop or slow down. I plan to visit the local airport weekend get together within a few weeks, and am looking forward to see if this upgrade provides some improvement in brake fade I was experiencing during this track running.
I also like how it "fills in" the space in the front wheels. That however is not going to make it worth the expense (even though it's a cheap upgrade). I'm into spending money on stuff I see improving performance. I should expect to see the brake fade diminish with these larger rotors on the course.
Old 01-27-2014, 03:18 PM   #23
VIG
VIG's Avatar
Region: Delaware
Yeah, I was thinking that that little of a change couldn't make that much of a difference. Although, like you said, it will be interesting to see what the effects are like at the track. I'd imagine brake fade would be reduced.
Old 01-27-2014, 07:58 PM   #24
JimC's Avatar
Swag. Attachment 146015 redid the brakes. Also the back of my front calipers are labeled v6... Are y'all sure the GT and V6 are the same?
The calipers are the same, it is the bracket that the caliper mounts to that is different. You are looking at the bracket - they are stamped for the V6 and GT.
This is the bracket, closest to the lug nuts:
and stamped bracket for GT
And stamped for the V6
Size difference
These are comparing the 2006 V6 to a 2006 V8 though. In 2011 Ford upgraded the V6 front brakes. So if you are looking at a 2012 front brake, the bigger bracket probably does say "V6" on it, since the 2011+ uses the same front brakes as the 2055-10 V8 uses. The 2011+ V8 has a bigger bracket and rotor now.
Fox Body Brake Conversion mcdonaldnick 1979-1995 Mustang GT 0 06-24-2013 11:15 AM
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 09:22 AM
Disc brake conversion for 66 Mustang Seattle66 Classic Mustangs 9 01-25-2012 10:52 AM
Brake upgrade!!! gvstack 1979-1995 Mustang GT 1 10-27-2011 02:16 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 10:29 AM
09:23 AM
