Bad clutch? - Mustang Evolution
Old 01-24-2014, 10:36 PM   #1
Bad clutch?
How can you tell if you have a bad clutch?
I've been taking my mustang to the track and I'm having trouble putting it In 3rd gear when I race I pop clutch but even if I hold the clutch all the way down and it still grinds the gear but it only happens in high rpms when I'm driving normal it's okay
arthurcordova93 is offline   Reply With Quote
Old 01-24-2014, 11:09 PM   #2
silvrbullet2012's Avatar
Bad clutch?
I'm sure it's the shifter bracket. Mine was the same way at high rpms. Changed mine out and I almost never grind into 3rd.
silvrbullet2012 is offline   Reply With Quote
Old 01-24-2014, 11:21 PM   #3
Shifter Bracket what do you mean?
Old 01-24-2014, 11:25 PM   #4
Bad clutch?
Name:	ImageUploadedByMustang Evolution1390627453.432547.jpg
Stock bracket vs Barton bracket
This is the install. This one is the two post bracket which is the upgraded version. But pretty much works the same and install is kinda the same.
Old 01-24-2014, 11:34 PM   #5
How does this affect shifting? The stock bracket
Old 01-24-2014, 11:36 PM   #6
Bad clutch?
It's sloppy and during high revs it doesn't preform well.
http://m.bartonindustries.com/Shifter-hanger.html
Old 01-24-2014, 11:56 PM   #7
This problem just started tho
Old 01-25-2014, 12:09 AM   #8
KSconvert's Avatar
Could've worn out the stock rubber bushing with all of the racing and hard shifting.
2014 GT MT aka: Ruffian-
3.73 gears, Roush AB, BBR O/R x-pipe, JLT intake, BMR panhard bar, BMR lowers and brackets, FRPP 47# injectors, Lund E85 tune, SR springs, MGW shifter, 416rwhp/393rwtq
KSconvert is offline   Reply With Quote
Old 01-25-2014, 12:15 AM   #9
I hope that's it's it
Mcleod twin disc clutch issue ( maybe) 08shelbyguy General Mustang Discussion 1 01-23-2014 05:43 PM
Car smells really bad! Like rotten eggs or sulfur. BryanGTR169 2011-2014 V6 Mustang 24 07-16-2013 06:39 AM
Clutch Shutter Delta vt 2011-2014 Mustang GT 1 05-24-2012 09:57 AM
TOB and clutch 01StangGt 1996-2004 Mustang GT 2 02-14-2012 05:53 AM
New clutch ? jhagan1980 1979-1995 Mustang GT 8 09-21-2011 10:46 AM
08:24 PM
