MT-82 Transmission Chattering - Mustang Evolution
Old 01-30-2014, 11:43 AM   #1
silvrbullet2012's Avatar
So it has slightly got worse to the point you can hear it louder.
When the clutch is in. It stops. Sounds like it could be my flywheel? My gears go in just fine.
Here's a video of the sound. Might have to turn up the volume to hear it clearly. When you hear the sound go away I pushed the clutch in. And when it comes back I released the clutch.
Chattering - YouTube
silvrbullet2012 is offline   Reply With Quote
Old 01-30-2014, 05:59 PM   #2
WJBertrand's Avatar
Are you parked and running in neutral when you're doing this? It might just be the transmission shafts spinning up when you release the clutch and they stop when you push it in. Every manual transmission vehicle I've ever owned has some level of audible transmission noise in neutral with the engine running and the clutch released that goes away when you press it in.
How many miles and how long since you changed the lube in there?
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 01-30-2014, 06:52 PM   #3
Yes. I am parked and when I take off you can hear it chatter a lil more but goes away at high speeds.
Ive never changed the lube 😳 it has 62k miles.
Old 01-30-2014, 11:47 PM   #4
WJBertrand's Avatar
Might try changing the lube, its probably sheared down to about water by now!
-Jeff-
STOC 025
-Jeff-
Ventura, CA
Old 01-31-2014, 12:12 AM   #5
Sorry for the dumb question. But change the lube where?
Old 01-31-2014, 04:44 PM   #6
WJBertrand's Avatar
In the transmission of course
-Jeff-
Ventura, CA
Old 01-31-2014, 04:49 PM   #7
Oh you mean the transmission fluid 😜😅
Old 01-31-2014, 05:16 PM   #8
Ish416's Avatar
Finally an MT82 issue that I don't have ........ yet.
Old 02-04-2014, 12:09 PM   #9
sunnytan06's Avatar
Lmao. That's why my first mod will be mgw.
sunnytan06 is offline   Reply With Quote
Old 02-04-2014, 01:38 PM   #10
Ish416's Avatar
An MGW will not fix internal transmission issues..
Old 02-04-2014, 01:48 PM   #11
FastFord13's Avatar
+1
Old 02-08-2014, 05:42 PM   #12
check allfordmustangs.com they have some threads about the same thing. also some on the whole drivetrain issue.
tugsnipe is offline   Reply With Quote
Old 02-10-2014, 12:02 PM   #13
The Puma's Avatar
Drivetrain issue? I haven't had a problem with either... Is this common and I'm just lucky? Only thing I noticed is a dull click when clutch is engaged... Usually only around a turn in second gear, though.
The Puma is offline   Reply With Quote
Old 02-10-2014, 12:11 PM   #14
Well I did more research. And it's comin down to is my transmission fluid. I'm getting it changed this week. So hopefully it'll stop.
Old 02-10-2014, 12:42 PM   #15
that click could be the front drive lower control arm, there is a tsb on it, and I believe a recall
Old 02-10-2014, 12:54 PM   #16
The Puma's Avatar
Any info on how to find this TSB? Maybe I'm Googling wrong...
Old 02-10-2014, 01:02 PM   #17
check www.allfordmustangs.com under forum 2011+ V6
Old 02-10-2014, 01:03 PM   #18
The Puma's Avatar
Think I found it... It isn't a squeek, it's just a click with the engagement of the clutch.
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
87 AOD rebuild bcosta56 1979-1995 Mustang GT 15 03-04-2012 09:47 AM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
10:04 PM
