Hid lights installing - Mustang Evolution
Old 02-06-2014, 10:36 AM   #1
ebgonzalez1's Avatar
Hello has anyone done a switch from a 2013-2014 head lights from a mustang to a 10-12 if so what do you need cost and is it plug and play? I want new headlights because since I travel at night a lot because of work I want better viability and honestly I dont like the aftermarket headlights. I want to install 13-14 headlights on my mustang but have no idea if they are the same connectors
Sent from my SGH-T999 using Mustang Evolution mobile app
"Just a lil Sixxer...."
ebgonzalez1 is offline   Reply With Quote
Old 02-06-2014, 11:21 AM   #2
LuisBlackGT's Avatar
I'm quite confused as of which mustang lights you have now? could you clarify.
try here
Will 2013 HID Headlight fit in my 2012 GT
LuisBlackGT is offline   Reply With Quote
Old 02-06-2014, 11:29 AM   #3
try here
also you are looking to spend anywhere from 800-1200 for the 13-14 headlights
Old 02-06-2014, 12:49 PM   #4
O.o thank you and holy crap
Old 02-06-2014, 04:35 PM   #5
NicholasP's Avatar
Originally Posted by ebgonzalez1 View Post
O.o thank you and holy crap Sent from my SGH-T999 using Mustang Evolution mobile app
There were also stock hids made for our cars too you can get
NicholasP is offline   Reply With Quote
Old 02-06-2014, 05:12 PM   #6
thejohncarlson's Avatar
You are better off getting retrofits. Mine were $550 for the pair including a high quality hid kit.
thejohncarlson is offline   Reply With Quote
Old 02-06-2014, 06:44 PM   #7
From where?
---------- Post added at 07:44 PM ---------- Previous post was at 07:44 PM ----------
You guys have any links to anything resembling the 13s
Old 02-06-2014, 07:23 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
theretrofitsource.com is where I got mine. $300 for the projectors, HID kit, and Iris shrouds. I'm doing the retrofit myself, so no labor cost.
Sent from my HTC One X using Mustang Evolution mobile app
2012 Kona Blue 3.7L V6:
Old 02-06-2014, 07:24 PM   #9
Hidretrofitlights.com - I have been very happy. Search my previous posts, I have posted pics of the light output.
Old 02-06-2014, 08:06 PM   #10
Thank you all
Old 02-07-2014, 03:23 AM   #11
bucko's Avatar
Before you shell out the bucks for true HID headlight assemblies, try these brighter bulbs in your current setup:
Sylvania Ultra: https://www.sylvania.com/en-us/produ...tar-ultra.aspx
I have them in my 2005 F150. I used to drive from Dallas to orlando, and would make this haul at night (quiet, less traffic). These bulbs produce a ton of usable light!
I plan to install them in the Mustang when the current bulbs require replacement.
Old 02-07-2014, 07:15 AM   #12
GrabberMeBlue's Avatar
Also try cranking the adjusters up one full revolution to raise the light beam. I did this on my '12 and can see much better at night. I think they pointed our lights too low at the factory. I have yet to have oncoming traffic flash me for being too bright.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 02-07-2014, 09:12 AM   #13
This is a great idea! Just be careful not to put them too high
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
Old 02-07-2014, 07:01 PM   #14
Whitelightning's Avatar
I did this along with my GT fogs. Get brighted every time. Thankfully I can flash my brights on with the fogs and tell them in a blinding manner, hey buddy, I got one more light setting, they are not on bright. I run sylvania gold tips in my heads and silvers in my fogs.
Old 02-10-2014, 12:09 PM   #15
The Puma's Avatar
I just put high power HIDs in my stock housing... 160 bucks from hidguy.net. Super fast shipping and lifetime warranty. Plug and play, they even plugged it all up for me, so I opened it, grounded it, hooked up the hot wire and lights in housing and I was done... Way cheaper/easier option and looks great too.
The Puma is offline   Reply With Quote
Old 02-10-2014, 04:00 PM   #16
Abominable Mustang
WhoDat's Avatar
Region: Alaska
*sigh* Cheaper isn't always better. Not only are HIDs in your stock halogen housing illegal. They're a safety hazard for oncoming traffic. The bright point on HID bulbs is different than halogen bulbs and causing the HID light to scatter upward and directly into drivers eyes, rather than being focused down onto the road.. Yeah, you think the bright blue tint is cool, but it's a ******bag mod that everybody and their mother is starting to do. Either do a proper HID retrofit or use brighter HALOGEN bulbs. Do NOT use HID bulbs in halogen housing!
Old 02-10-2014, 04:10 PM   #17
Not to mention the headlights work much better in the housing that was designed for them.
Old 02-10-2014, 04:20 PM   #18
If you're just looking for the light to get a little further down the road, see my earlier post about just adjusting the stock lights. Our lights are too low from the factory. One turn of the screw doesn't cost anything.
1979 Gold Trans Am
Old 02-10-2014, 10:18 PM   #19
The Puma's Avatar
Not quite... I aimed mine to be about four meters in front of my Pony at the ground and did some drive by's on my girlfriend's car. She stated they were bright white, but not blinding at all. Most don't aim their lights after changing them, something you need to do no matter what you go with. As for the blue tint you speak of, don't have it. It depends on the K rating you go with. 6000K is solid white.
And, as many parts, lights are a huge suckers game... Everyone is trying to make a buck off special crap you don't need...
Old 02-10-2014, 10:25 PM   #20
2 Stangz's Avatar
Region: Nevada
From multiple experiences, 5000K is "pure white." 6000K most of the time has a hint of blue. OEM manufacturers use 4300K and 5000K. "k rating" is inaccurate, you mean color temperature measured in kelvin.
Aiming your lights won't do it. Trust me I've spent hours combined trying to aim halogens with multiple HID setups. If you're not blinding people your light output will still blow.
Retrofits are worth the $500/whatever people. theretrofitsource.com
Old 02-10-2014, 11:22 PM   #21
The Puma's Avatar
Umm... 5000K (Kelvin rating, I.e; K rating) is yellow white. 6000K is diamond white. 6000K have no blue what so ever.
As for aiming them not working, guess my Pony is a magical unicorn instead, because my light quality and visibility is awesome, and it does not disturb passing motorists...
And case and point, plugging an expensive mod when there is a much easier and less expensive option...
Old 02-11-2014, 12:19 AM   #22
2 Stangz's Avatar
Region: Nevada
I've installed several HID kits in different makes and models using kits varying from low and high quality. I call 5000K 'pure white' and 6000K 'diamond white' (like you call it). 6000K does in fact have a cyan hue and I have photos to prove it. I had 6000K bulbs in my headlights and in all of my photos that I took:
1st photo; as you can see from a distance they appear to be just white.
2nd photo; look on the ground in front of the car, a cyan hue is on the ground.
3rd + 4th photos; up close you can see the hints of cyan around the white light.
5th photo; an example of halogen vs. projector housings. Do your HID's have a cut-off line as sophisticated as the projector's?
ID:	147574   Click image for larger version
ID:	147576   Click image for larger version
Old 02-11-2014, 12:26 AM   #23
The Puma's Avatar
What watt ballasts are you running? Lower wattage might give that blue hue. I have 55w and they have no blue to them... My HIDs don't have the dispersed look like in the picture you have, though... I must admit, though. I really like your set up. Your pony looks clean.
2012 3.7L
Airraid CAI. Bama tune. AMR wheels. SR lowering springs. SR lower control arms. Boss 302 tower brace. Pypes bombs. Borla LTs and O/R X pipe. Barton short throw shifter and bracket.
Old 02-11-2014, 12:40 AM   #24
2 Stangz's Avatar
Region: Nevada
35W. I've always got and installed 35W because it's bright enough. I've heard 55W have a tendency to wash out the color so it makes sense that we're on two different pages here.
Thanks, that's my 06'. It got totaled last summer.
ID:	147580   Click image for larger version
Old 02-11-2014, 12:51 AM   #25
The Puma's Avatar
Yeah, K rating does change with wattage. Perhaps that's our difference of opinion.
I'm really sorry to hear about your pony getting totalled... It sure was a pretty pony.
2012 3.7L
Old 02-11-2014, 12:55 AM   #26
2 Stangz's Avatar
Region: Nevada
Appreciate it man. Long story short, I upgraded afterwards
Old 02-11-2014, 01:06 AM   #27
The Puma's Avatar
Happy ending to every sad story.
2012 3.7L
Old 02-11-2014, 05:22 AM   #28
bucko's Avatar
Amen. I wish the police force had more time to inforce these laws on folks that think scattered blue light is great and cool.
Old 02-11-2014, 08:34 AM   #29
2 Stangz's Avatar
Region: Nevada
Agreed. They'd bring in a decent amount of money in tickets you'd think. I'd also imagine a lot of 2nd or 3rd time offenders not uninstalling the kits the first time.
Old 02-11-2014, 08:55 AM   #30
bucko's Avatar
I'll admit, I got wrapped up and convinced (early on), that HID's with a ballest were the way to go in non HID headlight buckets. I bought a set about 5 years ago for my 2005 F150. I thought the light blue hue was nice, but realized after a week of night time driving, they did not produce any additional usable light, and only splattered it over a wide pattern. That, and I annoyed oncoming folks with them. I removed them, destroyed them, and bought the sylvania ultras. They were so much better and not annoying to others I share the road with.
There are always going to those that like them and don't care, and those that do not like them. To those who want usable light, get a different bulb designed for non-HID headlight buckets, or go full out and buy the correct projection headlight buckets for HID if you convert.
Old 02-11-2014, 12:49 PM   #31
Here is a great explanation of why HIDs do not go in reflector housing and why adjusting them does not solve the problem:
HID lights in reflector housings- A reminder to some of you out there. - ClubRoadster.net
Old 02-11-2014, 01:12 PM   #32
bucko's Avatar
^^^ Good read. Don't make the mistake I did.
Old 02-11-2014, 01:31 PM   #33
The Puma's Avatar
I live in Europe, bro... Lights are not blue or illegal here...
Old 02-11-2014, 01:46 PM   #34
2 Stangz's Avatar
Region: Nevada
That is besides bucko's and thecarljohnson's point. They're mainly talking ab HID's in halogen housings being a hazard and annoyance for drivers... Which I agree with. Just like bucko I tried HID's and I will no longer will install or support HID's in halogen housings. I do not enjoy the the headaches and potential to run off of the road from them.
Old 02-11-2014, 03:48 PM   #35
willb2305's Avatar
6k hid lights does have a slight blue color to them. and only use a 35 watt ballast. 55 watt ballasts do make the hid bulbs a little bit brighter but the bulbs will only last half as long as they will with a 35 watt ballast. 4600k or 5k is the brightest hid light available its a bright white color. and hid lights in a halogen headlight will send scattered light everywhere. not to mention hids produce way more heat then halogen do so the hids will eventually melt your halogen or projector housing if it isnt all metal with glass lenses.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
HID Lights! Melodyz_714 2005-2010 V6 Mustang 38 07-18-2013 07:41 PM
Help diagnose! TCS / Traction Lights GWraith 2011-2014 Mustang GT 9 05-21-2013 10:36 AM
HID lights Petty_stang Pre-2005 V6 Mustang 14 12-10-2011 04:32 AM
Getting HID lights Blackedout Pre-2005 V6 Mustang 34 11-02-2011 09:59 PM
03:25 PM
