Porting an intake manifold - Mustang Evolution
Old 02-08-2014, 10:39 AM   #1
geepoons's Avatar
does anyone know where i can find some information about porting my intake manifold ? Has anyone done it ? Is it worth it ? What happens exactly ? Any performance gains ? Basically any information helps because this is all new to me.
geepoons is offline   Reply With Quote
Old 02-08-2014, 11:25 AM   #2
ak_stang's Avatar
Region: Alaska
I know super six motor sports does intake porting, I would start there
ak_stang is offline   Reply With Quote
Old 02-08-2014, 09:39 PM   #3
what porting does, is to smooth out the air flow to the cylinder, in the case of the intake. the smoother the better to a point. also you want the gasket and manifold to be about the same size, so that the gasket or manifold do not cause a dead head were the air could actually reverse flow. or bounce. it works like water on a smooth surface, then add a rock. the water changes direction. and moves in directions you do not want. most intakes just have the casting marks smoothed and then do whats called gasket matching. it works best with cylinder heads that are also ported to get maximum benefit. most stock engines will gain some rpm but loose midrange power and drivability.
tugsnipe is offline   Reply With Quote
Old 02-09-2014, 06:29 AM   #4
willb2305's Avatar
look up lone wolf ported intakes. Lone wolf ported intakes installed - Ford Mustang Forums I think its around 15-20hp gain with just porting the intake manifolds. Also most the guys that run 12.7 or faster in the 1/4mile that are all motor have the lone wolf ported intake and I will be doing this as well.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 02-09-2014, 06:32 AM   #5
willb2305's Avatar
if i remember correctly lone wolf does a better job at porting the intake manifold then super six motorsports does. And more hp gains from lone wolf then super six motorsports.
2012 V6
Old 02-09-2014, 07:54 AM   #6
geepoons's Avatar
Thanks guys !
Sent from my SM-N900V using Mustang Evolution mobile app
Old 02-09-2014, 11:20 AM   #7
No way where can I find these at it doesn't seam like they have a websit
arthurcordova93 is offline   Reply With Quote
Old 02-09-2014, 12:24 PM   #8
powerwhee's Avatar
Type in lone wolf performance intake manifold on Google or go to other forums that will have members with it
Sent from my HTC6500LVW using Mustang Evolution mobile app
powerwhee is offline   Reply With Quote
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
For Sale: Boss 302 Intake Manifold primer2tone Mustang Parts for Sale and Wanted 14 02-19-2013 08:36 PM
mustang gt intake issue Jar72 1979-1995 Mustang GT 6 10-11-2012 07:51 AM
Upper intake Removal/VAP Auto installation ForsakenProto Pre-2005 V6 Mustang 22 07-06-2012 06:49 PM
Cracked Intake manifold... bobsurvives 1996-2004 Mustang GT 7 10-16-2011 12:03 AM
05:48 AM
