3.7 turbo mustang - Page 40 - Mustang Evolution
Old 09-09-2014, 01:20 PM   #1366
clamphier's Avatar
3.73 is kind of short for the kit. Most I would do is 3.55s. And it uses all its own exhaust so no need for any of that
Sent from my SM-N900V using Mustang Evolution mobile app
clamphier is offline   Reply With Quote
Old 09-09-2014, 01:33 PM   #1367
The final kit will Y into the stock catback is that correct?
2011 Mustang 3.7: 13.2 @ 105
BBK Shorty, MRT H, Borla S, 3.55 Gear, MPT Tuned.
LiveWire003 is offline   Reply With Quote
Old 09-09-2014, 01:47 PM   #1368
alrefire's Avatar
Hot side
The real... boss 227
Old 09-09-2014, 01:48 PM   #1369
alrefire's Avatar
Forgot the pic
Here's the
Old 09-09-2014, 01:49 PM   #1370
clamphier's Avatar
Yes it will livewire
Old 09-09-2014, 03:09 PM   #1371
5pointYoBro's Avatar
Alright so go with 3:55s. You obviously know what's up so I'll listen and get them instead of 373s. What about my catback exhaust I have now, can I keep that?
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 09-09-2014, 04:31 PM   #1372
clamphier's Avatar
Does it meet with the stock mid pipes or is it a whole full thing? The way we have it set up it goes to stock midpipes. I'm about to switch to 3.15s because it can barely shift because there is no power drop off
Old 09-09-2014, 04:41 PM   #1373
Rapinator126's Avatar
Go 2.73's. I'm dropping my 4.10's for 2.73's with the new nitrous setup.
Old 09-09-2014, 05:01 PM   #1374
clamphier's Avatar
I had 2.73s stock, I'm not going back that low. If you want a set cheap I took mine out at 4k. I still need some bottom end especially when I'm not on spray
Old 09-09-2014, 05:04 PM   #1375
I was going to buy a set off a member on here, but with shipping it wasn't worth it.
How much do you want for them?
Old 09-09-2014, 05:31 PM   #1376
clamphier's Avatar
Like 40 bucks I think I even have all the extra bearings and crush sleeve and stuff
Old 09-09-2014, 05:40 PM   #1377
I will take them, I should be in Houston this weekend.
Old 09-09-2014, 05:43 PM   #1378
Daveauth21's Avatar
Hey clamphier I have a manual with 3.73s I just had installed do you think this is too much gear for your kit?
Sent from my HTC6600LVW using Mustang Evolution mobile app
Daveauth21 is offline   Reply With Quote
Old 09-09-2014, 06:28 PM   #1379
clamphier's Avatar
Just let me know rapinator. For the power that you will be making initially it will be fine its just not good for mine with nitrous
Old 09-09-2014, 06:33 PM   #1380
It connects to the mid pipe I believe. It's the Cat back system from MBRP. Are 3:55s too much just from the power you make. I only plan on running stock internals and low boost for about a year or so until I save up for forged internals
Old 09-09-2014, 07:20 PM   #1381
clamphier's Avatar
Yea you'd be ok with 3.73s, they are for me but I'm making a lot of power now. I'll look it up and let you know!
Old 09-09-2014, 07:26 PM   #1382
Alright. Hopefully I can keep it. Got it from stage3motorsports. Just let me know on here, I'll keep an eye out
Old 09-09-2014, 07:28 PM   #1383
JoeyM91's Avatar
Any current plans about the twin turbos? Obviously at that level forged internals would be a must. I was thinking 2 smaller turbos for quick spool, but modern turbos are a lot better about turbo lag I suppose.
Old 09-09-2014, 08:00 PM   #1384
clamphier's Avatar
They are a lot better mines instant almost drives like a stick turbo car. We are going twins just because mine is limited to 800 just boost that's why it's on spray now.
Old 09-09-2014, 08:03 PM   #1385
clamphier's Avatar
You can't use the mbrp unless you got someone to fab some stuff. But yes looking to do twins mine is limited to 800hp so I need to either get a bigger housing for 400 or do twins. But the modern turbos are like instant spool, like a stock turbo car!
Old 09-09-2014, 08:03 PM   #1386
Ahh crap. I don't even have the old exhaust either
Old 09-09-2014, 08:06 PM   #1387
GrabberBlue1993's Avatar
I have my stock Axleback exhaust if you need a pair
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 09-09-2014, 08:06 PM   #1388
What are my options?
Old 09-09-2014, 08:18 PM   #1389
clamphier's Avatar
You just need the stock mid pipes you can probably hook those axle backs up to them
Old 09-09-2014, 08:20 PM   #1390
clamphier's Avatar
Nvm I think those will work if they still use the stock clamps
Old 09-09-2014, 08:26 PM   #1391
Connor, any chance you have a photo of the end-piece? You keep saying midpipes I assume you mean the pipes that go over the axle? If the end-piece of the turbo kit hooks up where the stock x-pipe does, than any catback system should be a direct fit.
Old 09-09-2014, 08:27 PM   #1392
Now im confused. Ive got the stock mid pipe on it now, never changed it. the catback is clamp on to it. So what i have will work??
Old 09-09-2014, 08:30 PM   #1393
Here is a pick of it in pieces
Old 09-09-2014, 08:33 PM   #1394
alrefire's Avatar
We have had this Convo many times :p
Both referring to different things.
what we are describing is the part after the x or h pipe.
Old 09-09-2014, 08:34 PM   #1395
JoeyM91's Avatar
Any good exhaust shop should be able to fabricate something that will work. Will it be pretty? Probably not.
Old 09-09-2014, 08:39 PM   #1396
Im going to call the shop tomorrow that installed them and see if by some miracle they still have the stock exhaust
Old 09-09-2014, 08:44 PM   #1397
clamphier's Avatar
Yea whatever installs to the factory x if that's all your exhaust is you are good to go
Old 09-09-2014, 09:05 PM   #1398
Here is another pic. I know it bolts to the stock h/x pipe
Old 09-09-2014, 09:07 PM   #1399
clamphier's Avatar
Then yes you are good no worries
Old 09-09-2014, 09:08 PM   #1400
Good or no?
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
the 85 mustang turbo prodject 2300turboford 1979-1995 Mustang GT 24 12-24-2011 07:44 PM
My Mustang Videos Mike90 Pictures and Videos 13 10-04-2011 08:15 PM
mustang vs. camaro secomejia General Car Discussion 58 09-29-2011 02:03 PM
11:57 AM
