What are the best bolt on mods for a 2013 v6 mustang. - Mustang Evolution
Old 02-11-2014, 08:20 AM   #1
giogonzalez101's Avatar
Sorry I am very new to the forum and would love some advice, and in what order should the mods be done. All feedback is appreciated.
giogonzalez101 is offline   Reply With Quote
Old 02-11-2014, 09:08 AM   #2
bucko's Avatar
Welcome aboard. Your best bet would be to grab a beverage of choice, type in the word "mods" in the search box, then read the hundreds of posts about this.
They end up being (but not in any order): CAI's exhaust, and tuners in the way of engine mods. Most seem to install an axle back exhaust first, as this gets the most attention. A tuner might be next, as this will gain you the most bang for the buck, but if warranty is an issue, it's been suggested many times in many threads, check with your local dealership as to what they consider a warranty breaker in the way of mods. There are CAI's that requre a tuner to produce significant HP/TQ gains over the stock air box, and then there are CAI's that do not require a tuner. I'd avoid these, as the stock air box flows quite well, so unless you plan to tweak every last bit of numbers out of your engine, save on the CAI purchase.
As far as apperance, this is your taste, and I'd suggest you design the outside as you like. No one here lines up to make anyones car payment (that I know of), so your taste counts the most.
Old 02-11-2014, 09:12 AM   #3
Black12's Avatar
I did QA1 upper and BMR lower rear control arms because I race the car and wheel hop was ridiculous. Street traction and dragstrip traction is night and day.
Black12 is offline   Reply With Quote
Old 02-11-2014, 09:39 AM   #4
sunnytan06's Avatar
Tune
CAI
Gear
Exhaust
sunnytan06 is offline   Reply With Quote
Old 02-11-2014, 09:42 AM   #5
Site Sponsor
Sponsor
AMWill's Avatar
bucko covered the most popular bolt-on mods for you! I agree with him, too. The best bang for your buck performance bolt-on, is a customer tune. There's a lot to be had in the factory tune with no other additional mods. Especially if your Mustang is an automatic!
Give me a shout if you would like to hear about our Bama custom tunes and tuners. I'd be happy to assist you with info and answer your questions!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-11-2014, 10:08 AM   #6
Thanks bucko, awesome info
Old 02-11-2014, 10:10 AM   #7
I didn't even think about control arms thanks black saving up for handling packs.
Old 02-11-2014, 10:13 AM   #8
Thank you shane will be looking for a tuner soon, bama is the best.
Old 02-11-2014, 10:15 AM   #9
Thanks, Sunnytan does changing the gear really make that much of a difference?
Old 02-11-2014, 10:53 AM   #10
sunnytan06's Avatar
The actual performance won't have any change. It just help pushing the car forward. It does help a lot if you have enough traction.
Of course. Better tires is always helpful
Do u have an manual or auto?
Old 02-11-2014, 11:57 AM   #11
Auto, wish I could switch it out.
Old 02-11-2014, 12:01 PM   #12
sunnytan06's Avatar
I think a tune will really help for automatic cars
Old 02-11-2014, 01:17 PM   #13
bucko's Avatar
It does. Be prepared for firmer shifts though, as the tune will change the shift points (RPM range), and the firmness of the shift. While it may not make sense to you initially, the firm shift is better for the transmission from a wear standpoint, as it eliminates the slipping required to obtain a smooth shift.
Old 02-11-2014, 01:31 PM   #14
2 Stangz's Avatar
Region: Nevada
I did not know that, I thought it'd be the other way around (the firmer shifts would wear more etc.). Thanks for the info and you nailed it with your first post in this thread.
Old 02-11-2014, 03:13 PM   #15
Intake and tune first, then x pipe, then gears. It will be ridiculous with those mods.
Torch10 is offline   Reply With Quote
Old 02-11-2014, 03:43 PM   #16
That's awesome info,gonna look into a tuner and some gears asap.
Old 02-11-2014, 03:45 PM   #17
Thanks for the sweet info, I would love some firmer shifts points. I didnt know those would make such a difference.
Old 02-11-2014, 05:17 PM   #18
ArtU's Avatar
The factory 2011+ H/X hybrid pipe is fine for better sound than an x-pipe makes at street rpms. An x-pipe wont do anything with stock manifolds unless you are getting rid of cats, and then your off road only. An x-pipe is for super high end RPM. Unless you are drag racing with 4.10 gears you don't need that.
This is different in the 2011+ than in the 2010 V6.
Most folks on the street need better low end grunt and driveability with our 3.7
3.55-3.73 gears with the factory h/x hybrid pipe is fine until you get into other mods with header choices.
Old 02-11-2014, 05:38 PM   #19
Midnight2012's Avatar
Originally Posted by ArtU View Post
The factory 2011+ H/X hybrid pipe is fine for better sound than an x-pipe makes at street rpms. An x-pipe wont do anything with stock manifolds unless you are getting rid of cats, and then your off road only. An x-pipe is for super high end RPM. Unless you are drag racing with 4.10 gears you don't need that. This is different in the 2011+ than in the 2010 V6. Most folks on the street need better low end grunt and driveability with our 3.7 3.55-3.73 gears with the factory h/x hybrid pipe is fine until you get into other mods with header choices.
I'm curious as to which ends up with a lower overall gear ratio the manual or automatic. Given equal rear end ratios.
If I make any sense.
Midnight2012 is offline   Reply With Quote
Old 02-11-2014, 05:41 PM   #20
ArtU's Avatar
That makes perfect sense, just look at the ratio of the last gear in each transmission.
Old 02-11-2014, 07:20 PM   #21
If you don't mind me asking what's the difference between 3.73 and 3.55 which is a better choice.
Old 02-11-2014, 08:07 PM   #22
ArtU's Avatar
Do you stay in town all the time? Or do you like to tour the countryside and or take weekend getaways? [do you have someone you plan to be in the shot gun seat that wants you to take her places?]
Driving at 70-75 on many freeways on weekend getaways will get tired on your motor, RPMs, gas tank, and general drone on higher numbers. Heck average traffic speed on some highways for hours on end can be as high as 77-82mph traveling cross country.
If you never plan to drive highways much and so dont need to care about the high rpm wear and tear and MPG, 3.73 will be funner acceleration.
I tour the contrysides and love travel in the Mustang, so I use 3.55s. Some stay as low as 3.31 for such travel but I chose 3.55 for a middle ground between good acceleration and easy travel both.
Guys will now jump in here and talk about what MPG they get on 3.73s & even 4.10s; but I challenge them on how many 700 mile+ trips they take at 72-82mph average traffic speed.
Next thing is will you ever sell the car? If you do, will you be putting the original gear back in place for another high price of 5 hours labor? 3.31 to 3.55 gears can still be sold to most regular car buyers without much trouble. Once you go 3.73 and higher, your car now will never sell to most normal folks/buyers. Your market for resale will be to folks that will reduce your price because you hot-rodded the car. You never get back most mods you put in a car unless your like Richard Rawlings or can channel the same.
Old 02-11-2014, 09:00 PM   #23
Bear376's Avatar
The deal with firmer shift is the same as with manual transmission. People tend to ease into the next gear to be more comfortable. This means a smooth shift will not get fully engaged longer, thus adding wear to the clutch packs. Pre-computerized shifting, it was a common to change the springs in the transmission hydraulic control module to firm up the shift. Some even had the ability to dial in the level of firmness for the application. If I remember right, the old C4 Ford tranny, all that was needed was to pull one spring out, and it would firm the shift points.
I was once told that modifying any car came down to PAT. Power, Appearance, Track. Decide what is your first goal is, then go from there.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 02-11-2014, 10:06 PM   #24
I am on the highways a lot, I live in miami florida, so I don't have much countryside but I do like the idea of 3.55 for best of both worlds.
Old 02-11-2014, 10:09 PM   #25
That PAT motto is cool, its gonna come in handy.
Old 02-11-2014, 10:10 PM   #26
Searched high and low
Old 02-12-2014, 03:08 AM   #27
bucko's Avatar
Found this. Does it help? (click on it to enlarge):
Old 02-12-2014, 06:39 AM   #28
ArtU's Avatar
Thanks Bucko, that might be the Manual Stats, with .065 overdrive gear in 6th?
I saw a list of auto trans ratios last year I will try and dig one up and compare, I know with the 3.55s I do about 2256rpm at 75mph on my Auto.
Edit: ---------------------------------------------------------------
Just found this, looks like in the end gear very close between man/auto; but different than the chart Bucko has. "Just confirmed Bucko's chart is for a GT's MT82."
2011 automatic 6R60 ratio's for 3.7LV6
1st 4.17
2nd 2.34
3rd 1.52
4th 1.14
5th 0.87
6th 0.69
2011 Manual MT82 3.7L V6
1st 4.24
2nd 2.54
3rd 1.67
4th 1.24
5th 1.00
6th .70
Art
Old 02-12-2014, 07:07 AM   #29
Does that mean that auto is a little better?
Old 02-12-2014, 07:14 AM   #30
ArtU's Avatar
Looks to me to be like only about ~0.1 sec in a 0-60 time with the manual being slightly faster.
Old 02-12-2014, 09:31 AM   #31
That's good to know.
Old 02-12-2014, 09:37 AM   #32
Thanks Art. I assume that 0-60 time depends on how well one can shift the manual. I can also assume then too that my 3:31 rear end auto is faster than a 2:73 manual given equal driver performance. And my 3:31 should leave my buddies 2:73 auto Vert in the dust. lol
Old 02-12-2014, 11:13 AM   #33
Site Sponsor
Sponsor
AMWill's Avatar
My pleasure buddy!
I see you're already super active on the forums. It shouldn't be long before you hit 50+ posts. You'll have to send me a PM once you have and I'll hook you up with the exclusive AM Forums Discount code for active members with over 50 posts. It's a 6% discount that can be used on all of your future orders with AM or Bama!
Shane
Old 02-12-2014, 12:03 PM   #34
Awesome, you bet I will when I do.
Old 02-12-2014, 02:31 PM   #35
ArtU's Avatar
yes, on the above. Unless you got an experienced gear jammer, the tuned Auto with firm shift points will win a 1/4 mile, 0-60 etc.
v6 mustang
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
Wheels for 2013 v6 mustang kpope2013 2011-2014 V6 Mustang 15 09-10-2013 09:08 PM
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
Valve covers!!! Coreyw428 1996-2004 Mustang GT 22 12-12-2011 10:53 AM
06:38 AM
