13 v6 alignment problems - Mustang Evolution
Old 02-12-2014, 02:58 PM   #1
supersixx13's Avatar
Exclamation 13 v6 alignment problems
This is a long shot but I was wondering if anybody else has had this problem. The car has been lowered with SR performance lowering springs and j&m adjustable camber caster plates. It has been lowered for about 3.5 months and I have had to have it re aligned 4 times now because the toe keeps getting out. Blows my mind! If anybody has run into this problem any advice would be awsome.
P.S. Struts, shocks and ball joints are factory.
supersixx13 is offline   Reply With Quote
Old 02-12-2014, 03:23 PM   #2
MustangDawg's Avatar
Possibly you need an adjustable pan hard bar. I think one of the more experienced members may be able to chime in on this one.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 02-12-2014, 03:31 PM   #3
Marc3.71994's Avatar
I think a bump steer kit will solve your problem.
Marc3.71994 is offline   Reply With Quote
Old 02-12-2014, 03:40 PM   #4
I installed a J&m steel adjustable pan hard bar when i lowered it. Rear end is centered. Im gunna try the bump steer kit and see if that fixes my problem.
Old 02-12-2014, 04:49 PM   #5
Getn off's Avatar
Sounds to me like ur camber/caster plates keep loosening up. Make sure they are torqued correctly and maybe use some blue loctite if u don't adjust often.
Panhard or bumpsteer kit won't help this issue.
Troy
Getn off is offline   Reply With Quote
Old 02-12-2014, 05:05 PM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Troy
Caster/camber plates shouldn't affect toe alignment. That's the tie rod ends. I agree that a bumpsteer kit may solve his problems.
2012 Kona Blue 3.7L V6:
Old 02-12-2014, 05:06 PM   #7
They are tight and they haven't come loose.
Sent from my SCH-I605 using Mustang Evolution mobile app
Old 02-12-2014, 05:09 PM   #8
I ordered Steeda heavy duty strut mounts and a Steeda bump steer kit. And the maximum motorsports bump steer gauge kit.
Old 02-12-2014, 05:30 PM   #9
air_commando88's Avatar
I put a steeda bumpsteer kit on my old gt and it fixed my similar issues. Hope it works!
Sent from my HTC6435LVW using Mustang Evolution mobile app
air_commando88 is offline   Reply With Quote
Old 02-12-2014, 05:44 PM   #10
what issues were u having?
Old 02-12-2014, 08:42 PM   #11
After I lowered it my toe angle was a little off and I was getting a popping type sound when turning. After installing the kit I had no more issues. I also installed a maximum motorsports adjustable caster/camber kit.
Old 02-13-2014, 01:28 AM   #12
How much did u lower it so that it messed up the toe?
Old 02-13-2014, 06:05 AM   #13
I installed h&r ss springs so it wasn't all that much however the shop that did it I began to question their work after they explained how they pulled the front springs out. They also had difficulty aligning it so I took it to another local shop and they were able to take care of it no problem. There probably wasn't even an issue just an incompetent shop.
New Steeda Rear X-brace - Keeps rear seats! tj@steeda 2011-2014 Mustang GT 16 06-18-2013 06:32 PM
In Honor of my '11 V6 Bokeo 2011-2014 V6 Mustang 49 01-25-2013 07:14 AM
Whats the point of souping up a v6? Mustang240 2011-2014 V6 Mustang 112 10-13-2012 01:25 AM
V6 Mustang Thread! :) FORDGT14 Pre-2005 V6 Mustang 71 01-24-2012 08:24 PM
Y2k v6 idle problems 6Banger2000 2005-2010 V6 Mustang 4 07-22-2011 07:10 AM
10:19 AM
