transmission issue need help! - Mustang Evolution
Old 02-15-2014, 02:45 PM   #1
paintmann111's Avatar
So my car has been driving great up until now. '14 v6 base auto 2500 miles. I went to accelerate onto a main road and hit a bit of ice. The wheels spun while turning left, then caught dry pavement. This caused the car to lurch forward and shift hard. I could hear a loud noise like a hard shift. After that the check engine light came on and it seemed to stay in second gear. I drove home slowly parked it. About 10 mins later I came outside and took it for a spin. It seems to be shifting fine, but the light is still on. Any ideas? Ford doesn't open until Monday.
I'll be really pissed if this hard shift caused transmission damage. Another bit of info was traction control was OFF since in snowy weather I like it off.
paintmann111 is offline   Reply With Quote
Old 02-15-2014, 05:22 PM   #2
I went to advanced auto and the kid used the scanner. He said it read code P0657 "interruption to trans control solenoids.". Anyone know what that means?
Also on the way home the check engine light turned off. Only reason I'm asking is that I'm in Maine right now and will have to drive back home to Connecticut tomorrow.
Old 02-16-2014, 10:36 AM   #3
David Young's Avatar
My research is P0657 code means Actuator supply voltage A circuit open. I don't know what it means either . I would drive it around for a whie to see if the code comes back on.
I think its just a 'fluke' and the code won't come back.
David Young is offline   Reply With Quote
Old 02-16-2014, 11:17 AM   #4
AJcruz1's Avatar
Still under warranty. Just take it to the dealer and have them check it out. I dunno if I would tell them you had the traction control off on slick roads as they might try to say its your fault if there is something wrong.
AJcruz1 is offline   Reply With Quote
Old 02-16-2014, 10:34 PM   #5
JSchu22's Avatar
I'm sorry this isn't helpful but may I ask why you like having the TC off in the snow?
JSchu22 is offline   Reply With Quote
Old 02-17-2014, 06:55 AM   #6
bucko's Avatar
I checked Google and came up with this:
Possible causes
- Faulty Engine Control Module (ECM)
- ECM harness is open or shorted
- ECM circuit poor electrical connection
- ECM Programming
For me, this would be a trip to the dealership, as your Mustang is still under warranty. I would not offer any information as to "how you were driving" or that you had the TC disabled (off). Although, they might be able to tell, as the PCM stores certain information about the car; not sure if it stores if/when the traction control is disabled or not.
You could always plead ignorance if asked; it's always easier to ask for forgivness then to ask for permission!
Old 02-17-2014, 08:54 AM   #7
nhcowboy's Avatar
Fwiw, I had this happen yesterday after my battery of 4 years took a dump. After I jumped it, it did this. Hard "lurching" shifting in/out of reverse as well as in/out of drive. When driving, it stayed in second.
Once I got home, I pulled the negative terminal. Waited ten. Reconnected. Effectively reset everything. Solved the issue. Now today my battery died again so I'm just going to swap out for new batt.
You triggered the computer freak out with loss of traction... Mine from the jump.
I wouldn't worry about it unless it happens again.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 02-17-2014, 01:00 PM   #8
Update: its at the dealership in Maine being looked at. They said it should be fixed in 1-2 days. I wont be back in Maine until Friday anyways.
I like the basic traction control off (i never disable the stability control one)when on icy roads since the car becomes more predictable. Yes it will break loose, but I know how to counter that. When I first got the car I was driving on ice and when the traction control kicked on it caused me to overcorrect. Its great in rain and snow. Useless on ice. Being born and rised in Maine Ive driven through a lot of **** and advancetrac is a joke on ice.
It did it again yesterday night so I decided to leave it in Maine for the local ford dealer to look at. Took my mothers rav 4 back to CT
Old 02-18-2014, 07:46 AM   #9
If you read the 'owners manual', it says if you get stuck in the snow or mud, you 'might' need to turn the traction control 'off' to get un stuck. Just saying........
Old 02-18-2014, 10:52 AM   #10
Issue fixed. The wire harness plug came loose that plugs into the transmission. Easy fix for the dealer.
Old 02-18-2014, 10:54 AM   #11
Strange Mud's Avatar
sweet
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
1996 Ford Mustang transmission issue? Moor208 1996-2004 Mustang GT 0 11-19-2012 09:55 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
Transmission issue goherd 2005-2010 V6 Mustang 2 07-22-2011 06:18 PM
11:19 AM
