idle help - Mustang Evolution
Old 02-15-2014, 09:18 PM   #1
Question idle help
Hi guys,
What the normal idle RPM for a 2014 Auto?
Here is a picture of my bb at idle.
Ranger052 is offline   Reply With Quote
Old 02-15-2014, 09:24 PM   #2
LuisBlackGT's Avatar
I have 2014 gt, and that is exactly where mine idles so I think it should be the same
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 02-15-2014, 09:27 PM   #3
I have been getting some vibration through the steering wheel so I didn't know if that is normal or not
Old 02-15-2014, 09:27 PM   #4
Is it while your driving or just idle?
Old 02-15-2014, 09:28 PM   #5
just idle
Old 02-15-2014, 09:32 PM   #6
Hmm, how many miles on the car and have you done any mods yet?
Old 02-15-2014, 09:33 PM   #7
0 mods and 1250 miles
Old 02-15-2014, 09:38 PM   #8
I'm not sure about the vibrations sorry. Hopefully someone who knows can chime in to help
Old 02-15-2014, 09:40 PM   #9
Thanks
Old 02-15-2014, 10:00 PM   #10
sunnytan06's Avatar
Around the same. I have a manual. Hope it helps
sunnytan06 is offline   Reply With Quote
Old 02-15-2014, 10:10 PM   #11
Thanks god I am not alone lol
Old 02-15-2014, 10:19 PM   #12
sunnytan06's Avatar
What makes u think there's something wrong in the first place tho if u don't mind me asking
Old 02-15-2014, 10:21 PM   #13
no no no I am not saying there is something wrong jeejj I just want to know of that is normal or not this is my first mustang and I am just getting use to it
Old 02-15-2014, 10:27 PM   #14
silvrbullet2012's Avatar
I have a 2012 manual and mine did the same. I just replaced coils and raised my idle by 100 and it's smooth now. Haven't had a problem since. I thought it was my a/c at first but it wasn't.
silvrbullet2012 is offline   Reply With Quote
Old 02-15-2014, 10:30 PM   #15
sunnytan06's Avatar
U use a tune to raise the idle?
Old 02-15-2014, 10:31 PM   #16
Ya. I have a SCT tuner and you have an option to raise/lower the idle. So I just raised mine. Lol
Old 02-15-2014, 10:33 PM   #17
sunnytan06's Avatar
What is the difference?
Old 02-15-2014, 10:57 PM   #18
will a tune void my warranty? and could the dealer find out if I have a tune?
Old 02-15-2014, 10:58 PM   #19
2011 Kona Blue's Avatar
How does one raise or lower the idle on our Sct tuner. I don't think I have seen that option for my bama hybrid tune.
Old 02-15-2014, 11:00 PM   #20
Originally Posted by Ranger052 View Post
Hi guys,
I have an 11 V6 and mine idle's at same rpm's as yours when in park. All is normal bro.
Old 02-15-2014, 11:01 PM   #21
Old 02-15-2014, 11:13 PM   #22
sunnytan06's Avatar
Depends on your dealership. Talk to them if you are worry about your warranty. And yes they could find out how many times you tuned the car.
Old 02-15-2014, 11:16 PM   #23
Awww . I though tunes were not an issue for ford
Old 02-15-2014, 11:23 PM   #24
sunnytan06's Avatar
I hope that's the case too lol
Old 02-15-2014, 11:28 PM   #25
Is your car tuned?
Old 02-16-2014, 12:02 AM   #26
sunnytan06's Avatar
No. I am planing to do a steeda tune tho
Old 02-16-2014, 12:15 AM   #27
Whitelightning's Avatar
My idle is that. 700 rpm. It'll dip down to 600-650 and shake some then come back up. Been playing with it to see if the accessory stuff is making it do this or not. I have 87,000 miles on mine and is bolt on and tuned.
Old 02-16-2014, 11:32 PM   #28
willb2305's Avatar
on the diablosport trinity tuner to raise your idle rpm you go to performance then it should be under one of the settings to change your idle rpm and neutral rpm. i think its set at 650 or 700 at default i raised mine to 800 on both idle rpm and neutral rpm. Also by raising the idle rpm if you have longtube headers you will see less dips or stuttering during idle that happens with longtubes.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 02-17-2014, 08:00 AM   #29
bucko's Avatar
The idle comes up a bit whenever the AC is operated....
My idle is at the same as the OP, but I do not feel any sort of engine vibration in the steering wheel. I too operate with a tune (MRT 83 octane), but did not request them to change the idle, nor have I looked to see if my tuner allows for me to change it. Since it is not an issue with my 2011, I've not had to look into it.
But it does make me wonder if I could...
Old 02-17-2014, 02:31 PM   #30
AJcruz1's Avatar
Does anyone know if a dirty MAF sensor could cause problems idling?
AJcruz1 is offline   Reply With Quote
Old 02-17-2014, 02:48 PM   #31
bucko's Avatar
A symptom, yes.
Go here for more symptoms of a dirty MAF, and the proper way to clean it (instructions mention to "pluck it" out of the air filter box, but Our Mustangs have it held into the air tube (runs between the throttle body and air filter box) with two screws):
How to Detect and Clean a Faulty Mass Airflow Sensor - CarsDirect
Old 02-17-2014, 03:32 PM   #32
AJcruz1's Avatar
Originally Posted by bucko View Post
A symptom, yes.
Yeah I know where it's at. Thanks for posting the link. Gonna take a look at it as it may be causing my idle woes. I've took it out and put it back Ina number of times now and having a CAI with oiled filter makes sense it might be a little dirty.
Old 02-17-2014, 03:43 PM   #33
AJcruz1's Avatar
Never mind it's clean. Looks brand new.
Old 02-17-2014, 04:00 PM   #34
ArtU's Avatar
ON your SCT tuner, before you put the tune from anyone in, there is a message about changing things. When you go into that there should be a list of items that can be changed that the tune maker did not block out. My past Bama tunes didn't have anything blocked out.
You should see Idle Neutral, Idle Drive in the list. On another point, many folks pay money to have tunes that Idle "Rough", like ghost cams emulating the old school Huff and Puff Idles of the 60s and 70s big race cams. (not for daily drivers)
I can tell you the factory stock idle vibration of a V6 2013 3.7 mustang is nothing like the hell that a 5.3 Chevy truck V8 with AFM has that they call "normal". AFM by the way is Active Fuel Management when talking about Chevy hell. Not All Ford Mustangs
Art (I own a AFM hell 5.3 chevy truck)
Old 02-17-2014, 05:46 PM   #35
AJcruz1's Avatar
It's the same on Diablosport tuners. You can change the idle if you want.
modded 95 gt rough idle SyKoticStang 1979-1995 Mustang GT 7 01-28-2014 07:23 PM
1987 Mustang GT 5.0: Huge Help Needed Johnson 1979-1995 Mustang GT 24 01-18-2012 09:19 PM
High idle Travis B 1979-1995 Mustang GT 10 12-09-2011 07:48 PM
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 09:44 PM
Stupid idle NateNasty 1979-1995 Mustang GT 23 10-17-2011 08:12 AM
04:45 AM
