Shorty header install - Mustang Evolution
Old 02-17-2014, 10:32 AM   #1
FastFord13's Avatar
I'm about to start the header install tonight, any tips and advice would be appreciated. Thanks.
2013 V6, Candy apple metallic.
Gt500 spoiler, Gt500 stripes,2010 Gt premium wheels, Pirelli tires,painted side mirrors covers,upper and lower black billet grille,pony projection lights,boss 302 strut tower brace,barton shifter bracket,Airaid Cai,bama tuned,bbk shorty headers,Roush AB.
FastFord13 is online now   Reply With Quote
Old 02-17-2014, 11:32 AM   #2
silvrbullet2012's Avatar
If you have a buddy it would be a great help. Driver side is the easiest. The only big pain is getting to the bolts in a tight space. It's doable just takes a lil time.
silvrbullet2012 is offline   Reply With Quote
Old 02-17-2014, 11:58 AM   #3
gt07's Avatar
get as many of the header bolts off before you jack up the car if you don't have a lift .....
gt07 is offline   Reply With Quote
Old 02-17-2014, 01:56 PM   #4
bucko's Avatar
There's another post (or two) of other members that have done this. The search yeilds this:
Shorty Header Installed!!!
Old 02-17-2014, 02:06 PM   #5
FastFord13's Avatar
Thanks 4 the link, after reading it should I not use the bbk gaskets?
Old 02-17-2014, 02:26 PM   #6
I'm still using the bbk gaskets and haven't had a problem.
Old 02-17-2014, 02:47 PM   #7
AJcruz1's Avatar
How long having you had the headers installed?
AJcruz1 is offline   Reply With Quote
Old 02-17-2014, 09:32 PM   #8
Since oct of 2013.
Old 02-18-2014, 03:52 AM   #9
FastFord13's Avatar
What gaskets should I use?
Old 02-18-2014, 09:36 AM   #10
Oh2freshstang's Avatar
I reused the oem gaskets when I put LTs on my old 3.7 & didn't have a problem! Also if I have one of these it'll make ur life easier when reaching those manifold bolts...
Old 02-18-2014, 09:52 AM   #11
After the install you will be more than happy to pay a shop $300 to install. it's quite a PITA. I would pay a shop before i did it again.
2013 DIB 3.7-Pypes Pype Bomb black axlebacks, BBK shorty headers, Bama & MPT tunes, Steeda Ultralite Springs, J&M steel adj. panhard, Roush hood scoop, Street scene Gen 2 chin spoiler painted to match, Custom billet grille, painted side mirror covers, 20" gloss black AMR wheels wrapped in Nitto Motivos.
Follow me on instagram @that_deep_impact
Deep_Impact is offline   Reply With Quote
Old 02-18-2014, 10:56 AM   #12
FastFord13's Avatar
Will this do or does it have to be adjustable? Also should I reuse the stock gaskets or use the bbk supplied gaskets? Thanks again.
Old 02-18-2014, 10:57 AM   #13
FastFord13's Avatar
Old 02-18-2014, 10:58 AM   #14
FastFord13's Avatar
[QUOTE=FastFord13;19508
Old 02-18-2014, 10:59 AM   #15
FastFord13's Avatar
Old 02-18-2014, 12:19 PM   #16
Charlie_santos's Avatar
My first set of headers cracked and caused a leak. Stick with the stock metal gaskets just be careful they can cut flesh very quickly!
Old 02-18-2014, 03:38 PM   #17
Will this do or does it have to be adjustable? Also should I reuse the stock gaskets or use the bbk supplied gaskets? Thanks again. 2013 V6, Candy apple metallic. Gt500 spoiler, Gt500 stripes,2010 Gt premium wheels, Pirelli tires,painted side mirrors covers,upper and lower black billet grille,pony projection lights,boss 302 strut tower brace,barton shifter bracket,Airaid Cai,bama tuned,bbk shorty headers,Roush AB.
The adjustable head is what helps get to those bolts because they're angled awkward! When I 1st installed them I didn't have the tool I showed u but I still got it done! But when I took them off (to trade my car in) it made it a lot easier..still a PITA to get those bolts but it helped me a ton! As for the gaskets I heated the bbk ones aren't better than the oem ones so I reused mine & had 0 problems!
Old 02-19-2014, 07:16 PM   #18
pwrby4d's Avatar
I used aftermarket but can't remember... Wasn't bbk though because I got my headers used. It was a major brand though that I used.. Some reuse the oem and have good luck but for the 40 bucks or so I would go with a new set because if it leaks you are screwed and have to tear it all apart. I would have used the oem but the dealer needed a few days to get them and I had aftermarket ones in a few hours.
pwrby4d is offline   Reply With Quote
Old 02-19-2014, 07:21 PM   #19
pwrby4d's Avatar
Fel-pro just remembered. They were aluminum coated in gasket sealant and they sealed perfect.
Old 02-20-2014, 01:28 PM   #20
having 2 other hands makes a world of difference!
Oliver is offline   Reply With Quote
Old 02-20-2014, 02:13 PM   #21
Sapphire's Avatar
Make sure everything goes in well before you put them on! We didn't when we did mine and the driver's side was cross threaded and was a PITA to get it fixed
Sapphire is offline   Reply With Quote
Bbk longtube header install Chasafire888 1996-2004 Mustang GT 6 01-15-2014 08:46 PM
BBK Shorty Header Issues Resolved !!! Herbstang Pre-2005 V6 Mustang 12 10-24-2012 12:40 AM
2011+ header install. Reinkey 2011-2014 Mustang GT 16 02-01-2012 05:41 PM
Header and x pipe install! Benzo 2011-2014 Mustang GT 50 11-30-2011 04:01 PM
Long tube header install CodyNelson 1996-2004 Mustang GT 12 08-22-2011 05:04 PM
06:01 PM
