Suspension issue - Mustang Evolution
Old 02-17-2014, 02:48 PM   #1
13 stang22's Avatar
Suspension issue
Lately, my springs/shocks have been making an annoying squeezing sound along with my control arms making a rattling sound. It feels like pieces and karts are loose but when I check under the car, everything seems fine. Any ideas or reasons why this may be and how I can fix this?
13 stang22 is offline   Reply With Quote
Old 02-17-2014, 03:03 PM   #2
Did you check all the bushings?
Old 02-17-2014, 03:45 PM   #3
13 stang22's Avatar
I did. I have to take my car in to my friends shop cause it's making a weird noise in the engine bay so I'll have them look at it but it's so annoying. every single bump and sometimes on turns it squeaks
Old 02-17-2014, 05:34 PM   #4
13 stang22's Avatar
Anyone got any other ideas?
Old 02-17-2014, 05:43 PM   #5
colemaneric's Avatar
I had a same sort of problem turns out I had a cracked lower control arm
colemaneric is offline   Reply With Quote
Old 02-17-2014, 09:27 PM   #6
silvrbullet2012's Avatar
Most likely it's your front control arms. Mine was replaced under warranty.y rear sway bar bushings went out as well and I just replaced it with a steeda one.
silvrbullet2012 is offline   Reply With Quote
Old 02-17-2014, 09:32 PM   #7
13 stang22's Avatar
hmm...I see. I hope it's not something serious
Old 02-18-2014, 01:08 PM   #8
sunnytan06's Avatar
I have the sound too when I go over bumps. Only the front left end tho.
sunnytan06 is offline   Reply With Quote
Old 02-18-2014, 08:08 PM   #9
13 stang22's Avatar
what do you think it is?
Old 02-18-2014, 08:16 PM   #10
AJcruz1's Avatar
Best to get it on a rack or jack stands and put pressure on each corner to see if you can find it. I had some rattling and found out it was one of the lock nuts on my BMR panhard bar was loose.
AJcruz1 is offline   Reply With Quote
Old 02-19-2014, 09:48 AM   #11
sunnytan06's Avatar
At first I thought it was just a break in stage. But it continues till now that I already have almost 5k miles. So I think probably is the spring or shock. Not really a big deal for normal driving tho. Without the sound. The performance is balance
Old 02-19-2014, 10:35 AM   #12
sunnytan06's Avatar
Old 02-19-2014, 11:16 PM   #13
mpachal's Avatar
I had the squeak. After three times at the dealer they finally heard it ( would not happen in wet weather) and they replaced the rear sway bar bushings. Also had a bang sound in the front over speed bumps. They replaced the lower control arms but it still happens.
mpachal is offline   Reply With Quote
Old 02-20-2014, 06:35 AM   #14
ArtU's Avatar
This exact issue is a TSB Ford has but when I had my dealer look at it, they said it would only cover 2011-2012; that 2013 did not have the issue. Its strarting to look like 2013 does, as mine will only do it if I go over a speed bump with one tire avoiding the bump and the other over the bump. [squeek]
Both over the bump, no noise. The 2011-2012 resolution was to replace the LCAs with new ones. It seems the bushing in the original is melting somewhat from what I heard others say.
Old 02-22-2014, 12:50 AM   #15
Interesting. My '14 makes that noise. I have 5k miles on mine. I'll take it to ford and see what they say.
jrexer is offline   Reply With Quote
Old 02-22-2014, 06:18 AM   #16
cmegnin1's Avatar
My rear passenger side squeaked when. I hit bumps and the car moved laterally. I replaced the lower control arms with new bushings, old bushings were shot. Squeak went away and car hooks up better now. Also replaced the old leaking rear shocks with Bilsteins. The live rear axle which I despise, is under much better control now.
Air Suspension MythlinMasterdo General Mustang Discussion 4 01-26-2014 01:17 PM
Suspension Write Ups ! Slow4V 1996-2004 Mustang GT 8 04-15-2013 08:51 PM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 11:02 AM
Stearing Issue... lConnerl 1996-2004 Mustang GT 9 01-12-2012 01:34 PM
EVAP issue plaguing Mustangs! fluffyGT06 General Mustang Discussion 2 12-01-2011 11:56 AM
04:22 PM
