MAF replacement & installation - Mustang Evolution
Old 02-19-2014, 03:29 PM   #1
Yankytyke's Avatar
Given my history of idling problems & flat out stalling. I've been advised to replace my MAF.
Is it just a case of unplugging the battery, moving the old one & installing the new one? I'd rather do it myself then double the cost by paying labor etc.
Yankytyke is offline   Reply With Quote
Old 02-19-2014, 04:19 PM   #2
MustangDawg's Avatar
That's exactly all there is to it.
Disconnect the negative terminal on the battery.
Unplug the MAF.
Unscrew the MAF from the intake hose.
Reverse the process with the new MAF.
Boom - you're done!
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 03:12 PM
Coyote Air Filter Replacement graystone2013 2011-2014 Mustang GT 26 04-30-2014 08:49 PM
MAF conversion + heater core replacement. Is this a deal breaker? sawyers_15 1979-1995 Mustang GT 12 02-01-2014 08:39 PM
Achieving 70% inj. duty cycle Smokum281 1996-2004 Mustang GT 29 03-01-2013 04:03 PM
maf Robbie94gt 1979-1995 Mustang GT 7 12-17-2011 07:58 PM
10:58 PM
