Clutch stuck - Mustang Evolution
Old 02-22-2014, 05:01 PM   #1
Clutch stuck
I did a burnout and the clutch didn't come all the way up it came up but not all the way
arthurcordova93 is offline   Reply With Quote
Old 02-22-2014, 05:06 PM   #2
It's not me, it's you.
primer2tone's Avatar
How big a burnout did you do exactly? Lol, have you tried pulling it up with your hand? Is there a lot of play now?
Old 02-22-2014, 05:08 PM   #3
That what I did I pulled it with my hand is that bad? Is sown thing messing up?
Old 02-22-2014, 05:13 PM   #4
It might be ok. After you pulled it back up, did it stay up?
Old 02-22-2014, 05:19 PM   #5
Yes it stay up but what would cause that? It doesn't when I burn out
Old 02-22-2014, 06:16 PM   #6
silvrbullet2012's Avatar
When your hard on the clutch it tends to happen. I've seen this on mainly on 3.7s mine used to get a lil sticky when I was doing sprinted driving. Changed the clutch line and it doesn't do it anymore.
silvrbullet2012 is offline   Reply With Quote
Old 02-22-2014, 06:18 PM   #7
Ish416's Avatar
It's the junk clutch and pressure plate Ford installed into these cars. Banging gears will often get the same result. At this time there is no fix from Ford as they know about the issue but have yet to issue a TSB about it. Supposedly when I talked to an engineer from Ford he said they know about the issue and are working to get it resolved.
He stated the fix should be out around now.
Old 02-22-2014, 07:14 PM   #8
I did have a similar issue when my car was new. Maybe it happened once or twice but that's been about it.
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
For Sale: TR3650 5 Speed and Ram Dual Disk Clutch ColeJohnson Mustang Parts for Sale and Wanted 4 02-17-2014 04:20 PM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Transmission fluid for the T5 Combatman 2005-2010 V6 Mustang 18 08-05-2013 04:23 AM
Clutch, how can i prolong its life? the_stig 2011-2014 V6 Mustang 26 06-16-2012 07:58 PM
12:28 PM
