3.73 Gears - Mustang Evolution
Old 02-25-2014, 10:03 PM   #1
G3racing's Avatar
3.73 Gears
I have 800$ and a stock 2014 v6 Manual tranny what should i do first ?( i want a sleeper )
3.73 gears are they worth it i heard you loose rwhp?
2014 Mustang V6 Manual
AMR Charcoal Wheel & NITTO Tire Kit - 20x8.5
G3racing is offline   Reply With Quote
Old 02-25-2014, 10:16 PM   #2
LuisBlackGT's Avatar
You don't gain or lose RWHP with gears
---------- Post added at 12:16 AM ---------- Previous post was at 12:15 AM ----------
But gears will definitely help the lower end of your powerband which is where your car lacks
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 02-26-2014, 12:17 AM   #3
willb2305's Avatar
the best mods to do to your car is getting gears either 373 or 410 and a tune.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 02-26-2014, 04:18 AM   #4
The Puma's Avatar
Gears really help with low RPM acceleration. You do lose MPG, though, due to RPMs being higher at lower speeds. I have the 3.73s and it's not a huge difference in fuel usage, but a huge difference in acceleration. However, you have an automatic, so I highly recommend getting a tuner or have it tuned to recalibrate your shift points. If you don't, you can (not absolutely will) cause damage to your transmission. The tune is also a noticible upgrade in power as well as economy.
The Puma is offline   Reply With Quote
Old 02-26-2014, 03:09 PM   #5
Black12's Avatar
Gear change will require a tuner to correct the speedo. So do both. You won't regret it. After that, your wasting your money. JMO.
Black12 is offline   Reply With Quote
Old 02-26-2014, 10:17 PM   #6
The Puma's Avatar
What do you mean you're wasting your money after tune and gears?
Old 02-26-2014, 10:57 PM   #7
Sebas395's Avatar
Definitely get a tune
Sebas395 is offline   Reply With Quote
The truth about gears.. Ish416 General Mustang Discussion 121 09-17-2015 11:33 PM
Ok...3.55 vs 3.73 vs 4.10 Gears illestdomer2005 2011-2014 V6 Mustang 16 01-17-2015 09:17 PM
Anyone go back from 3.73 gears? lcseds 2011-2014 V6 Mustang 14 10-14-2013 08:21 AM
3.73 gears & MPG. Junkyard 2011-2014 Mustang GT 34 07-21-2011 01:40 AM
06:54 PM
