AdvanceTrac Warning - Mustang Evolution
Old 03-03-2014, 12:06 PM   #1
Exclamation AdvanceTrac Warning
My 2011 V6 MCA has been triggering the 'Service AdvanceTrac Light' for the last 5,000 miles or so that I've driven it. It is very random when it comes on but it does not stay on for more than a day or couple hours. I believe I figured out how to trigger it, by simply turning the steering wheel all the way.
So my question is what happens if I don't service my AdvanceTrac? The dealership already told me it's not covered under warranty since I already passed 36K and 3 years. I have been driving my stang for some time now since the light first came on.
BokuIchi is offline   Reply With Quote
Old 03-03-2014, 01:58 PM   #2
The next time it comes on
Drive straight to your nearest AUTO ZONE and get them to pull the code Number. Once you have the Number they may be able to tell you which sensor may need replacing. If They can't replace it just tell the dealer what the Number is and how much will it cost to fix it.
Old 03-03-2014, 02:06 PM   #3
Thanks Ronnie, appreciate the input!
Old 03-03-2014, 05:00 PM   #4
nhcowboy's Avatar
I assume you are running different tires than stock.
Even if the same "specs", brands differ on the revolutions per mile...
I can generate this at will by turning to wheel lock and keeping it there while moving (like pulling out of a parking space).
It only happened when I changed to different wheel/tires.
Now if it happens in a straight line, like a dirty/ failing sensor ( which I recently started to get in severe rain / cold )... Crushing at 40. No tire slip. Just something shorting.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 03-03-2014, 05:28 PM   #5
Thanks, love the blacked out ride you got there, that's a mean looking grille!
Old 03-03-2014, 06:50 PM   #6
thejohncarlson's Avatar
I used to get the service Advancetrac message intermittently. It was air in the lines. After bleeding the brakes, it has never happened again.
thejohncarlson is offline   Reply With Quote
Old 03-23-2014, 09:32 PM   #7
Took the mustang into a local ford dealership and it was diagnosed with a EPAS problem. Dealer told me EPAS will need to be replaced....$1500 (parts & labor)!!! Warranty does not cover it so I am looking at area auto shops that might have experience working on this.
Old 03-23-2014, 10:01 PM   #8
Warranty doesnt cover it??? Wtf i thought our warranty is 36K bumper to bumper plus extended warranty if you have it.
Ranger052 is offline   Reply With Quote
Old 03-23-2014, 10:05 PM   #9
It does, I just managed to pass 36K and 3 years a while ago. Dealership told me it is good under those circumstances but 5 years or 50 K and you're out of luck. Hopefully you don't run into the same AdvanceTrac problem.
Old 03-23-2014, 10:34 PM   #10
Did they explain what exactly the EPAS is? Can't say I've heard of that.
Colby2013 is offline   Reply With Quote
Old 03-24-2014, 01:34 AM   #11
Abominable Mustang
WhoDat's Avatar
Region: Alaska
It's our Electronic Power Assist Steering. Basically the steering rack
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 03-24-2014, 05:13 AM   #12
bucko's Avatar
Look for one in a local boneyard. Lots of low mileage Mustangs are showing up there, and most salvage yards give a warranty on the part.
warning about roush hood scoop install GRREEN 2011-2014 V6 Mustang 14 06-07-2013 11:03 AM
WARNING pamson The Bar 14 01-31-2013 09:48 PM
08:21 PM
