BBK Throttle Body - Mustang Evolution
Old 03-03-2014, 07:58 PM   #1
bryan001's Avatar
BBK Throttle Body
I have a problem you guys. I bought a BBK Throttle Body for my 2013 v6 mustang and I paired it with a Airaid intake. I did the installation correct but I forgot to disconnect my negative from my battery and now, my rpm's fluctuate when I let my car idle. The fluctuation is not a lot but I it's there and very clear. I called BBK
bryan001 is offline   Reply With Quote
Old 03-03-2014, 08:00 PM   #2
bryan001's Avatar
And they told me there was a certain procedure on how to reset the idling on your mustang. Does anybody know this procedure? Keep in mind I already disconnected my negative from my battery, turned it on, and still, it fluctuates. Any ideas?
Old 03-03-2014, 08:32 PM   #3
dacm99's Avatar
Reading on the google machine, the process is in the owners manual. Of note, I did read that a leak post mass air flow sensor could be causing the wonky idle. Best of luck.
Comment from another site.
"The procedure is in your owners manual. It basically consists of starting the car and letting it idle for a while, then cruise around normally for 10 minutes or so. I was told to do this every time I loaded a new tune. "
dacm99 is offline   Reply With Quote
Old 03-03-2014, 09:53 PM   #4
bryan001's Avatar
I appreciate it bro. I'll give that a look ASAP!
Airaid Poweraid Throttle Body Spacer (11-14 GT) 2013fiveO 2011-2014 Mustang GT 29 06-12-2014 02:56 AM
Throttle body and short throw shifter Mayhem48 General Mustang Discussion 14 01-28-2014 09:22 AM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
Throttle body cleaning Mustanglife Pre-2005 V6 Mustang 10 07-04-2011 01:32 PM
04:15 PM
