Possible to fix this at home? - Mustang Evolution
Old 03-05-2014, 07:49 AM   #1
Gdocumet's Avatar
I was backing out of a parking spot at the same rate as the car directly behind me regretfully. The hit was relatively minor but i was wondering if it could be returned to factory condition with a bit of bondo, paint , and clear coat. If not, then how much would a shop charge for this type of damage on averageClick image for larger version
Name:	ImageUploadedByMustang Evolution1394030961.963544.jpg
ID:	149735?Click image for larger version
Name:	ImageUploadedByMustang Evolution1394030919.068492.jpg
Gdocumet is offline   Reply With Quote
Old 03-05-2014, 07:50 AM   #2
turnitepp's Avatar
Have you tried catching your tears and rubbing those on it?
turnitepp is offline   Reply With Quote
Old 03-05-2014, 08:14 AM   #3
Gdocumet's Avatar
Day in and day out, I'm so paranoid of backing out now haha
Old 03-05-2014, 08:35 AM   #4
Blogger
99ford's Avatar
Well considering it is plastic you won't be able to use Bondo to the best of my knowledge. See if Bondo makes a filler for plastic. If it is cracked it's done if its just a chip your okay. A shop will replace it most likely an OEM refurb should run 300-400, and paint probably another 200-300 depending on who paints it.
*By chip I mean gougued you know how plastic gets when it's not cracked.
Old 03-05-2014, 09:12 AM   #5
About 550-600 for everything.
Colby2013 is offline   Reply With Quote
Old 03-05-2014, 09:31 AM   #6
Gdocumet's Avatar
Thanks for the responses, i thought so too around that price range of 500. I'll go to a shop today to get an estimate and I'll post up a pic or info to help anyone else in a similar position.
Old 03-05-2014, 01:48 PM   #7
somedopebeats's Avatar
Its written off lol
somedopebeats is offline   Reply With Quote
Old 03-05-2014, 01:50 PM   #8
Did you look for a matching used bumper in good shape? Imsure someone around here has to have replaced their rear bumper
Old 03-05-2014, 02:04 PM   #9
Gdocumet's Avatar
That's also a good option. Went to my mechanic and he said that the rear bumper alone without any of the mounts or clips goes for $239,
Old 03-05-2014, 02:16 PM   #10
bucko's Avatar
The plastics such as bumper covers require a special repair, especially if they have a split. The cover is removed, and a special heat gun with "staples" are used to keep the tear fron spreading. Then a epoxy is used on the front surface, sanded, and then a small amount of bondo is used to smooth it out for paint.
Anything can be done at home, but it requires the tools, skill set, and materials to do. This one may better be left to a body shop.
Old 03-05-2014, 02:43 PM   #11
Gdocumet's Avatar
Old 03-05-2014, 02:59 PM   #12
Is it pre-painted? If so, thats prob your best deal. I imagine most if not all clips and mounts are still in place (hopefully the right place haha)
Old 03-05-2014, 03:03 PM   #13
Theres a specific epoxy actually made for fixing bumpers. I think its called bumper patch. Magical stuff. Not so magical to do yourself haha
Home audio gear olds442111 The Bar 0 02-17-2014 09:50 PM
Just got home from a deployment Enderthreesix General Mustang Discussion 21 01-29-2014 08:53 PM
Anyway ideas to fix muffler rattle Charles.young10 2005-2010 Mustang GT 48 01-23-2012 08:20 AM
curb rash fix austinknoll Mustang Wheels & Tires 22 01-10-2012 07:29 PM
how to fix power loss? austinknoll General Mustang Discussion 8 07-26-2011 10:49 PM
10:28 PM
