CAI without tuner.. - Mustang Evolution
Old 03-13-2014, 12:15 PM   #1
rnaltamirano's Avatar
CAI without tuner..
Just bought an Airaid CAI and Borla ATAK axlebacks from AM just waiting on them. Will installing the CAI without the tuner be okay or not recommended?
rnaltamirano is offline   Reply With Quote
Old 03-13-2014, 01:19 PM   #2
MustangDawg's Avatar
I have an Airaid CAI and Borla S-type axlebacks with stock tune, no issues. Although I did install them separately. Just remember to disconnect the negative battery terminal before you install the CAI cause you'll need to disconnect the MAF from the stock intake.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 03-13-2014, 01:22 PM   #3
knight5.0's Avatar
isnt there a airaid intake that says you have to get a tune or engine damage may occur? I always wondered if that was true.
Black 2011 Mustang GT Premium
Manual transmission, SS clutch line
Brembo brake package
Steeda CAI, Borla axle back & BBK X pipe
And Jon (Godfather tuner) Lund tune
knight5.0 is offline   Reply With Quote
Old 03-13-2014, 01:27 PM   #4
From my research before I bought my Airaid CAI; the only CAI I know of that actually requires a tune is by Steeda.
Old 03-13-2014, 01:42 PM   #5
knight5.0's Avatar
I have the old style steeda intake. And I can return to stock and it seems to run fine. But I know it's not recommended
Sent from my SCH-I535 using Mustang Evolution mobile app
Old 03-13-2014, 03:39 PM   #6
I was hesitant but I was looking for someone who actually has one installed w/out one and their actual experience. Thanks guys!
Old 03-13-2014, 05:01 PM   #7
I'm running an Airraid CAI with no tune ( as the website says a tune is optional) and it runs fine. It's a purchase you won't regret! Those rpms sound devilish above 3k
Dhawk1313 is offline   Reply With Quote
Old 03-14-2014, 07:57 AM   #8
No tune required. The only one I know of that needs a tune is the Steeda CAI. Steeda has the most airflow and causes the car to run on the lean side. Hope this helps.
ryster99 is offline   Reply With Quote
Old 03-14-2014, 10:20 AM   #9
Strange Mud's Avatar
Airaid w/o tune here. I scored it used just for the sound and was worth it. as mentioned disconnect the battery look in the manual and do an idle re-learn. I also tell people when working on it place a rag in the lower air box where the snorkle is to prevent things from dissapearing when you drop them. Enjoy.
Old 03-14-2014, 11:25 AM   #10
hard learning
GlobalMega is offline   Reply With Quote
Old 03-14-2014, 12:07 PM   #11
tj@steeda's Avatar
Yes, you can install the Airaid CAI without a tune.
This intake was designed to not require custom tuning and runs perfectly on the original engine calibration. For even more performance, you can combine this intake with SCT custom tuning where gains of up to 25 horsepower and over 30 foot/lbs of torque can be achieved!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
cai
For Sale: 05-09 Airaid CAI & diablo tuner MasonStacks Mustang Parts for Sale and Wanted 9 03-13-2014 03:07 PM
JLT CAI with Steeda spacer, or BBK CAI and BBK throttle body? Aventador97 2005-2010 V6 Mustang 11 02-26-2014 03:12 PM
What tuner is best 06Stanger23 2005-2010 Mustang GT 33 01-24-2012 03:06 AM
roush cai vs jlt/steeda cai godsdisciple85 General Mustang Discussion 0 09-20-2011 08:34 AM
New jlt carbon fiber cai/ sct tuner (bama tuned) coming tomorrow i cannot wait...lol godsdisciple85 2011-2014 Mustang GT 4 06-28-2011 04:00 PM
05:05 PM
