How much torque to use on strut bar? - Mustang Evolution
Old 03-13-2014, 03:27 PM   #1
How much torque to use on the strut bar?
Thanks
Ranger052 is offline   Reply With Quote
Old 03-13-2014, 03:56 PM   #2
Anyone pls pls pls
Old 03-13-2014, 03:59 PM   #3
Frozen Yettie's Avatar
26 ft lb
watch this
Frozen Yettie is offline   Reply With Quote
Old 03-13-2014, 04:04 PM   #4
nhcowboy's Avatar
I don't know the exact torque, but if I recall, not much. There were threads on this forum of v6 guys causing damage. ( possibly stripping the bolts... Can't remember).
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 03-13-2014, 04:07 PM   #5
Thats why i need to know the exactly torque jejeje
Old 03-13-2014, 04:30 PM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Let me double check, but I think it's only 26 ft/lbs
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 03-13-2014, 04:30 PM   #7
Awesome thank you
Old 03-13-2014, 04:37 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Found it. I edited my previous post with the correct torque spec
Old 03-13-2014, 04:50 PM   #9
Tank you
Old 03-14-2014, 12:08 AM   #10
Tyriqq's Avatar
All you need to do is hand tight. There's no extra torque actually needed. It's so easy to over tighten the nuts by torquing them down. So hand tight is all you need
Tyriqq is offline   Reply With Quote
Old 03-15-2014, 07:40 PM   #11
I intalled it just by hand.
GlobalMega is offline   Reply With Quote
Old 03-15-2014, 07:47 PM   #12
Coyote_5.0's Avatar
If you don't have a tq wrench, use the german tradition technique. Goodentight.
Sent from my Galaxy S3
2011 GT SG 6M
JLT | Eibach | J&M | Diablosport | Roush | Barton
Coyote_5.0 is offline   Reply With Quote
Old 03-15-2014, 07:53 PM   #13
ArtU's Avatar
Nope, taking to my Ford Shop when I did mine here is what needs to be done to be safe. The Nuts are one time use only. So you must buy 4 more for about $9 and toss away the ones you took off.
Torque them exactly to spec. Too loose is just as bad as too tight. IE loose can lead to shear off, too tight leads to pop off the top or take off the strut rod and fark you over.
As a matter of fact if you research the many forums on this topic issue; too tight equals broken strut rods and a limp into shop or a tow.
Edit: on the other hand if after adding the bar all you do is drive to McDonalds no safety issues, just a good looking bar.
If you plan to take a road track at .9gs, well I hope you did things right to spec....Bueller?
Old 03-15-2014, 09:29 PM   #14
Thanks!
I didn't know I have to buy new nuts. Does the dealer carry does in stock?
if they do I will have to buy some
Old 03-16-2014, 01:16 AM   #15
Oh2freshstang's Avatar
Originally Posted by Ranger052 View Post
Thanks! I didn't know I have to buy new nuts. Does the dealer carry does in stock? if they do I will have to buy some
I reused mine in my old 3.7 & the 5.0 for over a year..I've taken them off & put them back on w/o a torque wrench plenty of times & I've never had an issue! Ford says all of their bolts are "one time use only" but a lot of people still reuse them with 0 issues. But if u wanna be extra careful I'm sure u can get some..
Old 03-16-2014, 06:07 AM   #16
ArtU's Avatar
Thanks!
Your dealer should have them in stock. I got my bar at CJ's and they also have them in stock for this reason. Yes, several have reused them, but they were designed to be single use. Good piece of mind when on a track. If you put the originals back on for now, you can always order the new ones and put them on.
W520112-S440A is the ford part on my spare bag of them.
I found the threads on AllFordMustangs of folks that striped the strut rod off being too tight and had to limp into the dealer; got me to buy a new Sears Needle Type Torque wrench for $19.
Wanted: Wanted 2014 v6 strut bar Mike2014V6 Mustang Parts for Sale and Wanted 2 03-04-2014 08:44 PM
Boss Strut Tower Bar Aruiz42 Mustang Parts for Sale and Wanted 7 08-03-2013 12:10 PM
How do I install strut bar Torchredfrankie Pre-2005 V6 Mustang 4 05-04-2013 10:18 PM
J&M adjustable Pan Hard bar back n a stang Mustang Parts for Sale and Wanted 22 12-26-2012 06:15 AM
rear strut bar kickerofdoom Pre-2005 V6 Mustang 4 11-03-2011 06:47 PM
01:16 PM
