Won't shift out of park - Mustang Evolution
Old 03-16-2014, 09:22 AM   #1
KONABLUE3.7's Avatar
I have a blue 2011 mustang v6 project car and when i got it back from the body shop for paint I put the car back in park without the battery on. Now when I start the car it show all doors and trunk are ajar when they are closed, power locks dont work, and the button on the shifter wont go back in to shift. This never happened before it was paint. I check all fuses, codes,and i cant figure out the problem. What should i do.
KONABLUE3.7 is offline   Reply With Quote
Old 03-16-2014, 10:34 AM   #2
GrabberMeBlue's Avatar
What about disconnecting the battery for 1/2 hour to an hour, hook it back up and see if that makes a difference. It wouldn't hurt to try.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 03-16-2014, 11:36 AM   #3
Thanks but i already tried that.
Old 03-16-2014, 12:04 PM   #4
Does anyone know if you can shift you car out of park with the engine running and door and or trunk open? It's 19 degrees out and I don't feel like going out in the garage to start my car just to test out. I know some vehicles don't let you lock the door while it is swung open with the engine running to prevent you from locking your keys inside. Don't know if Ford won't let you shift out of Park like that for safety reasons. If it does work that way, that would at least explain why he can't get it out of Park.
I also saw some people on the Web talking about crimped wires in the door boots that were causing their Door Ajar lights to stay on. Not sure how much disassembly was done or what was disturbed while painting the car.
1979 Gold Trans Am
Old 03-16-2014, 12:17 PM   #5
I'm also not clear on how you got your car back home from them to begin with. Was it towed to your house without ever being started to begin with, even at the body shop, and then you just stuck the shifter in Park after you pushed the car to wherever you wanted it? Or did you drive it home from the shop? If you drove it back, I don't understand how you put it in Park without the battery connected unless you shut it off in gear, disconnected the battery, stuck it in Park and then reconnected the battery. Could you please explain a little better what exactly happened?
1979 Gold Trans Am
Old 03-16-2014, 12:42 PM   #6
It may need to go to your dealer to get re-programmed
Somehow the CPU got corrupted and probably needs re-programming.
Old 03-16-2014, 12:45 PM   #7
You're in Florida where it is warm right now. Can you shift your car out of park while either the door or trunk are opened?
1979 Gold Trans Am
Old 03-16-2014, 01:10 PM   #8
Yes, you can drive with either open.
Colby2013 is offline   Reply With Quote
Old 03-16-2014, 01:12 PM   #9
Not just drive the car but shift it out of Park while open?
1979 Gold Trans Am
Old 03-16-2014, 01:22 PM   #10
Yeah. It just gives you the warning that it's open but still shifts.
Old 03-16-2014, 01:25 PM   #11
Ok, thanks! So the shifter problem is not related to the door or truck ajar lights.
1979 Gold Trans Am
Old 03-16-2014, 01:30 PM   #12
When you close the doors, do the windows roll up all the way and seal, or do they stay down an inch?
1979 Gold Trans Am
Old 03-16-2014, 01:42 PM   #13
@Grabbermeblue yes the windows fully seal, and the windows work.But the power lock dont work, but the doors lock with the key fob.
Old 03-16-2014, 01:49 PM   #14
Can you answer my questions above about how you got your car home?
1979 Gold Trans Am
Old 03-16-2014, 02:07 PM   #15
^ good question lol
Ranger052 is offline   Reply With Quote
Old 03-17-2014, 05:57 AM   #16
bucko's Avatar
This may sound obsurd, but what condition is the battery in? A low charged or weak battery can cause very strange symptoms in the electronics these days. many folks post about how their gauges do strange things when the battery is weak, low charged, or dead.
Old 03-17-2014, 06:04 AM   #17
Listen to Bucko
He is probably totally correct on a low battery.
Old 03-17-2014, 06:44 AM   #18
I wondered about that also, only thing is, I was waiting to see how he got the car home. I also figured it was probably charged enough if he got his car started.
1979 Gold Trans Am
Old 03-17-2014, 07:10 AM   #19
I'm Guessing it may not be His car he is talking about
It may be a case where it is his friends car and he don't know how it was brought home. Probably a trailer and not started for a long time because it is a project car. I'm just guessing because he won't answer about how the car got home.
Old 03-17-2014, 02:31 PM   #20
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The way he worded his first post makes it seem like it's his vehicle. But I do feel like we need a bit more info to help him out with his issue.
2012 Kona Blue 3.7L V6:
Old 03-17-2014, 03:48 PM   #21
It is my car, and i bought it and it lot drove. The battery is also brand new. Btw thank for helping.
Old 03-17-2014, 03:52 PM   #22
It still don't answer how it got back home from the paint shop.
Maybe it is to hard to understand. I'm Out
Old 03-17-2014, 04:05 PM   #23
Could you please read my earlier posts and answer them? One was about what kind of disassembling might have taken place to paint your car, and the other was about how you got your car home and how that whole process went. We would like to help you, but we need a better understanding of what took place.
1979 Gold Trans Am
Old 03-17-2014, 04:26 PM   #24
I think he is just trolling us!
Old 03-17-2014, 05:10 PM   #25
Well i guess ill start from scratch. I send my car in for frame work, and to be painted. I had minor framed damage to the core support, and frame horns. So last week when i got my car back it was brought by a trailer to my garage. I then installed a new radiator and hose to wrap up my project, then when i started the car i went to put in drive and the button wouldnt go in to shift, and the door ajar signal and the trunk ajar signal went on.
Old 03-17-2014, 05:40 PM   #26
Did you just have an accident with the car and that is why it is getting repaired? If so, were you able to drive it after the accident and you weren't experiencing these problems, or was the last time you had the car running before the accident and everything was fine? Wondering if the computer got damaged in the accident, it is in the engine compartment.
1979 Gold Trans Am
Old 03-17-2014, 08:44 PM   #27
If they did any welding on the frame
They may have contaminated the computer when they grounded the welder.
If it was at the shop they would have had to get it out of park to move it around their shop when needed.
I hope you have your foot on the brake when taking it out of park. If your foot ain't pushing the brake pedal it won't come out of park.
Old 03-18-2014, 05:49 AM   #28
bucko's Avatar
Good point with the foot on the brake Ronnie; totally forgot about that simple one.
Either that, or the sensor that "reads" that the brake is applied is bad, or damaged.
And, how sure are you of that battery? Many folks have replaced a battery with a new one, only to find out that the new battery was faulty. If it sat fo awhile, or if the repair shop left the doors open on your car while they were working on it, it may have a weak charge.
Old 03-18-2014, 06:02 AM   #29
He still has the problem of the door and trunk ajar lights, as well as the power locks only working with the fob. Unless he has two separate problems, I'm thinking it is more than just the brake solenoid switch, but anything is possible.
1979 Gold Trans Am
Old 03-18-2014, 06:08 AM   #30
bucko's Avatar
True. With several 'electrical" type problems he is reporting, I think it's going to end up being a damaged harness, or a harness connector near or at the point of the damage/welding he has had done if it's not a battery issue.
Bad grounds can also be a contributor to these types of faults. With the 2011 wiring factory manual I have, it's suprising as to how many body grounds there are throughout the vehicle.
Time to grab a multimeter (showing my age) or a newer test probe, a factory wiring diagram, and start probing.
Old 03-18-2014, 06:14 AM   #31
As a side note, I had the same problem with my '95 T/A for years where I struggled pushing the button in on the shifter as the weather got colder, and later, anytime it was the first startup of the day. I would have to let the car run for 10 minutes and then it would just easily push in. I finally tracked it down to replacing the SHIFTER solenoid switch underneath the console. Worked perfect ever since. Not sure if the Mustang has a shifter solenoid switch, but I'm guessing it might. Maybe someone else knows that. Don't have time to look it up right now.
1979 Gold Trans Am
Old 03-18-2014, 06:28 AM   #32
I still think it is a battery problem
I would think if he was going to do a project car he would have some Tools which would include a "BATTERY CHARGER" and the knowledge to know how to hook it up and use it. Even a brand new battery can be low from sitting on a shelf or just have one weak cell.
Like Bucko say's:
Old 03-18-2014, 06:12 PM   #33
My battery has enough power to start my car.
Old 03-18-2014, 10:30 PM   #34
Problem is fixed, thanks for the advice everyone.
Old 03-18-2014, 10:49 PM   #35
Bear376's Avatar
Don't leave us hanging. Someone else might have the same problem.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
2014 select shift automatic shifter AmericanBulldog 2011-2014 V6 Mustang 3 01-15-2014 02:11 PM
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
Useful Mustang Information - READ THIS FIRST! Trojan Horse 1979-1995 Mustang GT 24 11-19-2012 09:54 PM
Econo Shift/Skip Shift Rant michael81 2011-2014 Mustang GT 17 01-30-2012 06:52 PM
06:09 PM
