Intake - Mustang Evolution
Old 03-23-2014, 11:42 AM   #1
Mattjohnson's Avatar
Intake
I put a sr performance intake from American muscle on my automatic 2012 mustang v6 . It feels like I lost low end power but idk for sure. It doesn't pull as hard from around 20. Tires use to spin when I floored it at 20 now they don't . I can hear the intake sucking in air so I think it's on correctly. Any idea what the problem is. Maybe the tube isn't far enough in the cone filter or the throttle body ?? Please help
Mattjohnson is offline   Reply With Quote
Old 03-23-2014, 12:16 PM   #2
13savage6's Avatar
Do you have a tune to go with it
Sent from my SM-T217S using Mustang Evolution mobile app
mods- eibach sportline springs, camber bolts, j&m panhard bar, pypes pipebombs, upr short shift kit, 92 hybrid bama tune , JLT cai ,lethal perfomance o/r x-pipe , pypes m-80 mufflers.
13savage6 is offline   Reply With Quote
Old 03-23-2014, 12:28 PM   #3
-it says it's no tuned required.
- I have a dyno tune and a full exhaust -longtubes catted midpipe and axleback
---------- Post added at 12:28 PM ---------- Previous post was at 12:27 PM ----------
Tune*
Old 03-23-2014, 12:56 PM   #4
fknjulian's Avatar
Do you need a tune for a CAI?
fknjulian is offline   Reply With Quote
Old 03-23-2014, 12:57 PM   #5
No not on this one I was told. Is my car not performing as well because my car was tuned with the stock intake?
Old 03-23-2014, 12:59 PM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The only tune required CAI for the 3.7L Mustangs is the Steeda intake.
Sent from the future.
2012 Kona Blue 3.7L V6:
Old 03-23-2014, 01:02 PM   #7
You think I have a vacuum leak or exhaust leak. I bought ngk 02 sensors from American muscle is there a possibility they sent me faulty ones?
Old 03-23-2014, 01:15 PM   #8
fknjulian's Avatar
Intake
Did you have a tune on it before?
Old 03-23-2014, 01:21 PM   #9
Before intake yes.
Old 03-24-2014, 07:38 AM   #10
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
I would definitely go over the installation and see if anything looks like it's not installed correct. You definitely shouldn't be feeling a loss in power. This intake is usually "No Tune Required" however, you could be throwing it off a bit since you actually tuned the car for the stock intake and your current mods.
I would recommend giving whoever tuned your car a call and see if they can update the parameters for the SR CAI. We've run this on a few different project cars here at AM and definitely noticed some good improvements!
Hope this helps. Let me know if you have any questions or need some assistance.
-Dan
Old 03-24-2014, 02:50 PM   #11
MadGenius's Avatar
It may be that you need to update your tune. Even though you have one of those no tune required intakes, there is an increased amount of air going into your engine that the computer doesn't know what to do with. You need to calibrate your tune to let it know you're no longer running with the stock intake. Maybe that will help.
MadGenius is offline   Reply With Quote
Old 03-24-2014, 05:00 PM   #12
My sound stupid but try this:
Disconnect the battery for about 1/2 hour. Connect it back up and drive about fifty miles and see if it is not better.
Or else go back to your stock tune. See what happens.
Old 03-24-2014, 05:40 PM   #13
Stock tune works fine no idle surges at all. It's a tune prob
Old 03-25-2014, 03:03 AM   #14
13savage6's Avatar
Iwas on the right track :p
2013 mca 3.7: DIB
mods: sportline springs, bmr lca, steeda adj. uca, bmr panhard bar, lca relocation brackets, jlt cai, 91 mpt race tune, lethal o/r x-pipe, pypes m-80 resonators, pypes pipe-bombs.
Old 03-25-2014, 04:49 AM   #15
bucko's Avatar
CAI's that specify they do not require a tune are because the stock mapping can adjust for the increased air flow of the CAI.
However, if other mods have been done, including a tune to support the other mods, then that current tune may not be able to compinsate for the increased (?) air flow of the CAI.
As mentioned, call the folks that supplied your tune and ask them.
COLD AIR INTAKE or SHAKER COLD AIR INTAKE zalizar21 2005-2010 V6 Mustang 14 08-19-2012 07:41 AM
Boss intake manifold and the stock intake Yellow50 2011-2014 Mustang GT 43 04-26-2012 06:30 AM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 11:22 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 08:41 AM
03:07 AM
