GT mid-pipe on V6 - Mustang Evolution
Old 04-02-2014, 06:24 PM   #1
3.7L's Avatar
GT mid-pipe on V6
Hey guys! I found someone selling an oem gt h-pipe with cats for $20. I am planning on buying an aftermarket h-pipe, but I don't see why a gt h-pipe won't do the trick. I believe the gt h-pipe is 2.75 inches, same as after market h-pipes. Does anyone have any knowledge that can help me out?
3.7L is offline   Reply With Quote
Old 04-02-2014, 07:23 PM   #2
I want to say the V6 exhaust is 2.25 with aftermarket systems expanding to 2.5. I am unsure of the GT's diameter piping but you would probable need to get it fabricated with adapters to fit your V6. Also if it is indeed 2.75 I would be worried that it would be too big and you would lose some low end torque which the V6's already lack.
StarzTA17 is offline   Reply With Quote
Old 04-02-2014, 11:29 PM   #3
Oh2freshstang's Avatar
+1
The aftermarket mid pipes for 3.7s are 2.5 so I might have to get it fabbed to work. There's someone on here that cut the stock h section off the 5.0 & replaced the hybrid section of his 3.7 & hated the sound..he said it sounded like an old truck..just something to consider.
Old 04-03-2014, 01:25 AM   #4
3.7L's Avatar
Originally Posted by Oh2freshstang View Post
+1
Good to know! Thanks a lot! I'll be stay away from these lol the last thing I want is to ruin the sound of my borlas
Old 04-03-2014, 03:06 AM   #5
Charlie_santos's Avatar
Just cut the front connecting points and rear ones and weld them to the gt ones and ur good it will bolt up.
Old 04-03-2014, 04:35 AM   #6
bucko's Avatar
By cutting larger diameter (5.0) and welding lower diameter (3.7) pipes in the front and back of the GT H-pipe may actually hurt performance, as this would disrupt the smooth flow of exhaust. This, IMO, would not be worth the 20 bucks plus welding labor costs to install.
Old 04-03-2014, 05:19 AM   #7
mystang50's Avatar
x2
Old 04-03-2014, 08:19 AM   #8
This would actually help since he's adding piping way too big for a 3.7 even for F/I he needs to keep the inlet and outlet stock to keep the same back pressure. If not it'd be too free flowing and would lose power.
Old 04-03-2014, 10:17 AM   #9
bucko's Avatar
So, should he just pass on installing the GT H-pipe and keep what he has for now?
Old 04-03-2014, 10:23 AM   #10
GrabberMeBlue's Avatar
If he's just trying to add the H in there, could you have someone just cut and weld a pipe between the existing stock pipes, or is that a dumb idea?
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 04-03-2014, 10:24 AM   #11
bucko's Avatar
Here's what I found as to the H-pipe/X-pipe debate...
"if you are building a high-horsepower drag machine your choice will be different than a mildly modded street car. If you need a boost in low end torque, pick up an h-pipe. If it's high end horsepower later in the rpm band you seek, an x-pipe is the way to go".
Old 04-03-2014, 10:30 AM   #12
It's also supposed to help with scavenging. My brother put one on his 440-6 Pack Dart years ago. I think the X does the same thing, but the H has a deep tone vs. rasp with the X.
1979 Gold Trans Am
Old 04-03-2014, 10:40 AM   #13
The guy I talked about earlier that swapped the GT h section for the v6 hybrid section said he felt a loss in performance. I think his name was fintle or something like that!
Old 04-03-2014, 11:09 AM   #14
3.7L's Avatar
Thanks for all the help guys! I'm sure I can cut the h/pipe and get it to fit. I'm not worried about the loss in power, but trying to achieve a nice deep sound. I may even install LT headers in the future, however I'm not sure how that will effect the sound with an h-pipe. Is anyone running LT headers and and h-pipe??
Old 04-03-2014, 11:17 AM   #15
bucko's Avatar
Just get your local muffler shop to convert your existing stock X-pipe to that of an H-pipe.
Old 04-03-2014, 11:26 AM   #16
Here is a picture of our stock exhaust. Do those pipes just meet one another where that X is but flow is completely independent of one another, or are they open inside that X? If they are open, then why isn't our stock exhaust raspy like an aftermarket X pipe is?
Name:	ImageUploadedByMustang Evolution1396546015.768152.jpg
1979 Gold Trans Am
Old 04-03-2014, 12:01 PM   #17
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I think one person on here is running a custom h-pipe with longtubes on their 3.7L. I will be in the near future once I get my car unfrozen. I've got the lethal off-road h-pipe now. I'm gonna get it modified into a shorty when I install my Borla xr1 longtube headers.
2012 Kona Blue 3.7L V6:
Old 04-03-2014, 01:15 PM   #18
3.7L's Avatar
Here is a picture of our stock exhaust. Do those pipes just meet one another where that X is but flow is completely independent of one another, or are they open inside that X? If they are open, then why isn't our stock exhaust raspy like an aftermarket X pipe?
Here's a pic of the h-pipe. As for the science behind why x-pipes have rasp is beyond me. Click image for larger version
Name:	ImageUploadedByMustang Evolution1396552539.541488.jpg
Old 04-03-2014, 01:17 PM   #19
3.7L's Avatar
Sounds awesome! Once you have that completed, you'll have to post a vid
Old 04-03-2014, 02:29 PM   #20
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Thanks, I definitely plan on it. The rest of my setup is the Pype Bomb axlebacks and 22" glasspacks welded into the factory overaxle pipes.
Old 04-05-2014, 04:19 PM   #21
alrefire's Avatar
I've got an aftermarket H pipe, it's 2.5"
Old 04-05-2014, 04:32 PM   #22
3.7L's Avatar
Thank you, that helps a lot!
Old 04-05-2014, 04:40 PM   #23
alrefire's Avatar
No problem!
You can still fit the GT pipe, but you'd have to take it to a muffler shop for them to modify the openings.
Old 04-05-2014, 05:00 PM   #24
bazinga11's Avatar
No problem!
How different is your sound with your H pipe on idle and at WOT? -compared to factory hybrid h/x pipe?
I fellow forum member said his pretty deep at idle, but kinda flattened out at WOT.. Making it sound like a pick up truck. Also, I asked the same question to my exhaust guy and he was like the stock h/x mid pipe is way better than a proper H. Idk lol too much info
|| BlackOnBlack ||
Old 04-05-2014, 05:02 PM   #25
alrefire's Avatar
|| BlackOnBlack ||
H was way deeper, it sound weird at WOT, check out my YouTube video of my 0-60
Channel name is alrefire
Old 04-05-2014, 05:08 PM   #26
bazinga11's Avatar
Cheers thanks, I will. So it was weird.. As in?
|| BlackOnBlack ||
Old 04-05-2014, 06:06 PM   #27
alrefire's Avatar
|| BlackOnBlack ||
Metallic snake hissing
Old 04-05-2014, 08:26 PM   #28
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Odd. I don't get a sound like that at WOT.
Old 04-06-2014, 06:17 AM   #29
stangstandard's Avatar
If your looking for sound, I've been told shortys are the way to go and they also give you some low end torque where as the long tubes give you a few more hp and loss some low end tq
You cant fix stupid......
stangstandard is offline   Reply With Quote
Old 04-06-2014, 09:55 AM   #30
Alrefire, you h-pipe is an off road catless right? I just wanna know as I'm gonna add an h-pipe but keep the cats.
PonyPower17 is offline   Reply With Quote
Old 04-06-2014, 09:58 AM   #31
alrefire's Avatar
Yes, it's catless
Old 05-05-2014, 01:29 AM   #32
3.7Cyclone's Avatar
I am doing something similar except I am replacing my mid pipes (from the X back) and my muffler deletes for a stock GT setup. It is a simple pair of adapters welded to the mids to mate them to the X, after that its mostly stock setup.
I currently am running BBK shorties, stock X with cats and resonators, stock mids with magnapacks welded in with Pypes bombs in the rear. Mellow, very deep and very aggressive sounding. However I am having some alignment issues with the axle backs that I fixed a while back with my BBK X pipe but since I removed that they are all out of whack. So I am ditching the mid to axle backs. I will still get resonators with the GT mid pipes and I will have more muffler options with the 3" pipes and as long as I stay with a chambered muffler over a delete or pure strait through should not lose much or anything for being too open.
16 Mustang Ecoboost Prem Fast Back | 2.3L | 3.55 gears | 201A Package | 20" Foundry Wheels P265/35R20 Continental DWS tires | Interior Trim package | Shaker Audio with SYNC 3 | Redline Elite Hood Struts | Mishimoto catch can | Mishimoto Intercooler(Black) | TS Vee port supersonic BOV | Tune+ tuning | Driveshaft Shop aluminum DS | Map big turbo kit | AEM Meth injection w/Mishimoto charge pipe and bung | http://www.youtube.com/user/eclypse3d
3.7Cyclone is offline   Reply With Quote
headers and mid pipe mylilpny 2011-2014 Mustang GT 10 01-07-2011 03:04 PM
Mid pipe with mid mufflers? Tompkins 2005-2010 Mustang GT 5 03-27-2010 12:26 PM
Long tube mid pipe Ninethourpm Pre-2005 V6 Mustang 25 03-18-2010 09:41 PM
Getting new catback/headers, need mid pipe? CreationNation 1979-1995 Mustang GT 13 03-31-2009 07:57 AM
I want a new mid pipe 01mineralgrey6 1996-2004 Mustang GT 17 05-25-2005 09:16 PM
05:41 PM
