CAI Install gone good or bad? - Mustang Evolution
Old 04-09-2014, 08:33 PM   #1
Frozen Yettie's Avatar
So I just got my Airaid CAI and I just finished installing everything and rechecked everything.
When I started her up it read that I had 366 miles left till Empty.
Which is strange because I am 100% sure that when my tank is full I only get 260-280 Miles till Empty and I just filled up this afternoon.
Also if you think of it this way my average fuel economy is 16.2 mpg and the 2014 Mustang V6's hold 16 gallons of fuel. So 16.2 X 16 = 259.2
Yes I have a very heavy lead weight for a foot that's why I get an average of 16.2mpg's in a V6!
So is this a good thing or bad thing lol?
Install an Airaid it'll add 100MPGs! lol
Pics
Frozen Yettie is offline   Reply With Quote
Old 04-09-2014, 08:37 PM   #2
paintmann111's Avatar
Did you get a tune as well? If not, its probably because you are running leaner than stock. More air + less fuel= more MPG's.
paintmann111 is offline   Reply With Quote
Old 04-09-2014, 09:18 PM   #3
Pics
Attachment 153454
Attachment 153455
415 to a tank no cai. 65-68mph 2.73 6spd. Shell fuel 93 octane. Hope I didn't rain on your parade lol. 366 is good, I drive like fuel is $10 a gallon. This is only on my daily work commute.
Bigshow14 is offline   Reply With Quote
Old 04-09-2014, 09:50 PM   #4
LuisBlackGT's Avatar
Holy **** 16.2 mpg in a v6? U must floor it every chance u get lol. I get 15.2 with spirited driving in my gt
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 04-10-2014, 02:20 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Did you disconnect the battery during the CAI install? If so, your ecu reset back to stock gas mileage calculations. Once it gets use to your driving habits again, your miles to empty reading at a full tank will reflect
2012 Kona Blue 3.7L V6:
Old 04-10-2014, 05:24 AM   #6
SixBanger's Avatar
Lol well with 93 octane this is what I'd expect. I assume the OP is using 87?
2014 V6 Base Coupe, Sterling Gray Metallic///3.31 Gears///FP6 Appearance Package///Tech. Package///Reverse Sensing and Security Package///Mods: Boss 302 grille, MMD Ducktail Spoiler, Weathertech Floor Mats, Bassani Axle-Back Exhaust
SixBanger is offline   Reply With Quote
Old 04-10-2014, 08:02 AM   #7
No sir my X4 Tuner is on the way from AM.
I use the same thing lol 93 octane took me almost $60 to fill up my tank yesterday.
Gas is expensive though almost $3.79 for 93 octane here in South Texas.
Well I mostly drive in the city and that does hurt my fuel economy as well and I just have a very stubborn foot lol.
Ah, Yes I did disconnect the battery as per the Airaid CAI instructions instructed to disconnect the negative terminal from the battery prior to installation. Thanks for the answer I thought it would have saved everything like it did to my radio and my track apps and stuff on the display.
Nope I use 93 octane. I always thought the higher the octane the faster it burns?
Old 04-10-2014, 10:03 AM   #8
Strange Mud's Avatar
I would mostly not worry and see what happens with math not the computer. Also look in the manual and do the idle relearn procedure.
Old 04-10-2014, 10:35 AM   #9
Damn you...$3.79 for 93? I pay $3.82 for 87 here in CT.
Old 04-10-2014, 12:04 PM   #10
MustangDawg's Avatar
It's like $4.23 for 91 out here in SoCal.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 04-10-2014, 09:32 PM   #11
$3.60 at shell, $3.89 for nonethanol 93 at a local gas station. Southeastern louisana
cai
Oil Pump gone bad, need to rebuild/replace engine? mikehailey02gt 1996-2004 Mustang GT 18 07-20-2013 11:12 PM
Mustang owner gone bad lol southernstang00 1996-2004 Mustang GT 22 07-04-2012 06:15 AM
Gang fight gone bad sonic04edge The Bar 9 02-07-2011 08:35 AM
RC Jet take off gone bad Brent Pictures and Videos 7 02-19-2008 03:55 PM
MAF gone bad powerhungry966 Pre-2005 V6 Mustang 5 01-24-2006 12:07 PM
11:33 PM
