2011 Remote (Fob) Programming - Mustang Evolution
Old 05-02-2014, 12:32 PM   #1
Blogger
99ford's Avatar
I bought a friend of mine a new key fob. I went to program it today following the steps found in the owners manual, and the computer recognizes the signal, however, it won't stay programmed.
The other keys work, to unlock, lock, and do everything, but this one will not do anything.
Old 05-02-2014, 01:00 PM   #2
You mean this process..
Also says max of four remotes, not sure if that is the issue or what. Hope it helps.
Batdive is offline   Reply With Quote
Old 05-02-2014, 01:01 PM   #3
bucko's Avatar
Does this help?
Create a MyKey™
To program MyKey™ on one of the keys programmed to the vehicle,
insert the key that you want to make a MyKey™ into the ignition. For
vehicles equipped with push button start, put the intelligent access key
in the backup slot; see the Driving chapter for the location of the
backup slot. Turn the ignition on. Use the message center buttons to do
the following:
1. Press SETUP until PRESS RESET TO CREATE MYKEY is displayed.
2. Press and release the RESET button. HOLD RESET TO CONFIRM
MYKEY will be displayed.
3. Press and hold the RESET button for two seconds until MARK THIS
AS RESTRICTED is displayed.
4. Wait until KEY RESTRICTED AT NEXT START is displayed.
MyKey™ is successfully programmed.
Old 05-02-2014, 01:01 PM   #4
bucko's Avatar
Does this help?
Programming spare keys
You can program your own integrated keyhead transmitters or standard
SecuriLock coded keys to your vehicle. This procedure will program
both the engine immobilizer key code and the remote entry transmitter
portion of the IKT to your vehicle. Note: A maximum of eight coded
keys can be programmed to your vehicle; only four of these eight can be
IKTs with remote entry functionality.
Tips:
• Only use integrated keyhead transmitters (IKTs) or standard
SecuriLock keys.
• You must have two previously programmed coded keys (keys that
already operate your vehicle’s engine) and the new unprogrammed
key(s) readily accessible.
• If two previously programmed coded keys are not available, you must
take your vehicle to your authorized dealer to have the spare key(s)
programmed.
Please read and understand the
entire procedure before you begin.
1. Insert the first previously
programmed coded key into the
ignition.
2. Turn the ignition from the 1 (off)
position to the 3 (on) position. Keep
the ignition in the 3 (on) position
for at least three seconds, but no
more than 10 seconds.
3. Turn the ignition to the 1 (off) position and remove the first coded
key from the ignition.
4. After three seconds but within 10 seconds of turning the ignition to
the 1 (off) position, insert the second previously coded key into the
ignition.
5. Turn the ignition from the 1 (off) position to the 3 (on) position. Keep
the ignition in the 3 (on) position for at least three seconds, but no more
than 10 seconds.
6. Turn the ignition to the 1 (off) position and remove the second
previously programmed coded key from the ignition.
7. After three seconds but within 20 seconds of turning the ignition to
the 1 (off) position and removing the previously programmed coded
key, insert the new unprogrammed key (new key/valet key) into the
ignition.
8. Turn the ignition from the 1 (off) position to the 3 (on) position. Keep
the ignition in the 3 (on) position for at least six seconds.
9. Remove the newly programmed coded key from the ignition.
If the key has been successfully programmed it will start the vehicle’s
engine and will operate the remote entry system (if the new key is an
integrated keyhead transmitter). The theft indicator light will illuminate
for three seconds and then go out to indicate successful programming.
If the key was not successfully programmed, it will not start your
vehicle’s engine and/or will not operate the remote entry features. The
theft indicator light may flash on and off. Wait 20 seconds and you may
repeat Steps 1 through 8. If failure repeats, bring your vehicle to your
authorized dealer to have the new key(s) programmed.
To program additional new unprogrammed key(s), wait 20 seconds and
then repeat this procedure from Step 1.
Old 05-03-2014, 04:43 PM   #5
Blogger
99ford's Avatar
I actually used this guys video.
Old 05-03-2014, 04:48 PM   #6
Blogger
99ford's Avatar
Originally Posted by bucko View Post
Does this help?
Tips:
SecuriLock keys.
programmed.
ignition.
ignition.
than 10 seconds.
ignition.
I found that after the youtube video. What is weird is it knows the key is there because at the end it honks and the doors lock and unlock. But when I remove the key it acts like "I don't what this is"
Key fob remote 1998 Mustang V6 cor66vette General Mustang Discussion 0 02-06-2014 07:28 AM
Key fob remotes Peterzinyou 1996-2004 Mustang GT 11 04-21-2013 08:52 AM
Key fob problems. Evolution Pre-2005 V6 Mustang 8 03-01-2013 03:05 PM
key fob issues spencerbed 1996-2004 Mustang GT 0 02-24-2013 05:16 PM
Possible to replace dead "fob" battery? RedFire2006 2005-2010 Mustang GT 5 12-31-2009 05:05 AM
10:17 PM
