Hurst?? - Mustang Evolution
Old 05-05-2014, 11:28 PM   #1
Mattjohnson's Avatar
Hurst??
Anyone have a hurst drive hard shifter stick and plate ?? Looks sick. Thinking about eating for my base 2012 auto. Was hoping someone could give me accurate info or a review on it.
Mattjohnson is offline   Reply With Quote
Old 05-06-2014, 08:56 AM   #2
Or tci
Old 05-07-2014, 01:22 AM   #3
fordfan100's Avatar
Ive driven an 05 with a tci and it was awesome I want one for mine now but I got other stuff I want to do first
fordfan100 is offline   Reply With Quote
Old 05-07-2014, 04:53 AM   #4
bucko's Avatar
I have the Hurst shifter. No problems, it looks nicer than the stock shifter, and installation was 30 minutes or less. The TCI looks too "gimicky" for my tastes. I like the simple look of the Hurst.
Old 05-07-2014, 05:39 AM   #5
It's a ratchet shifter right ??
Old 05-07-2014, 10:52 AM   #6
bucko's Avatar
Ratchet? No. It's simply replaces the stock "T" handle. Are you talking about an automatic transmission?
Check this post:
A ratchet shifter for an automatic??
If you want firmer shifts, simular to those of a manual transmission, get a tune; cheaper then the ratchet shifters, and much easier, as you'll put it in drive, and the tune firms the shift's, and makes for better shift points.
Old 05-07-2014, 10:57 AM   #7
Oh so it's not like the TCI 4"ratchet? Yes I have an auto.
---------- Post added at 10:57 AM ---------- Previous post was at 10:57 AM ----------
TCI ratchet *
Old 05-07-2014, 11:01 AM   #8
bucko's Avatar
No, it's not. I was looking at the TCI ratchet shifter awhile back; saw one on ebay...I read quite a bit of pros/cons of it (the early ones were prone to failure) and decided against the "gimicktry" of it.
My tune provides nice, crisp, firm shifts. No need for the ratchet shifter.
Old 05-07-2014, 10:43 PM   #9
So with the hurst automatic kit you can still shift from 1st to 3rd on accident or even reverse or whatever ?
Old 05-07-2014, 11:23 PM   #10
fordfan100's Avatar
Where do you get the hurst kit?
Old 05-08-2014, 04:58 AM   #11
2011fastford's Avatar
Region: New Mexico
I have the hurst as well the tci is quite the contraption if you ask me...
if you can get just the handle for the hurst I'd just do that there are some fitment issues with the plate
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 05-08-2014, 05:08 AM   #12
bucko's Avatar
I read that too when I bought my Hurst handle. Also found this when I googled the shifter and plate:
"Will not work 100% with the 2013 Mustang - Ford changed the stock shift plate so the install instructions aren't exactly correct. Also the stock PRNDL will not line up with the Hurst opening in the plate" "
Ford did change the automatics in 2013 ("Select Shift"), so this handle works for 2011 and 2012 automatics only.
Install instructions:
http://www.catalograck.com/ImgVD/HUR/5380420.pdf
Here's a link to Amazon that sells them:
Satin finish:
http://www.amazon.com/Hurst-5380421-...ype=automotive
Black finish:
http://www.amazon.com/Hurst-5380423-...V0VFE6VX8063YY
Again, very easy installation.
In buying any replacement shifter/handle for the automatic transmissions, be sure it has the O/D button! There are some aftermarket ones that do not have this, and you have to be creative to equip one. The Hurst has the button, and the correct harness clip to simply plug into the factory harness.
I "customized mine a tad by using a black sharpie marker to fill in the "HURST" letters in black. You could do it in any color that you can get with sharpie markers.
Old 05-08-2014, 05:10 AM   #13
Region: New Mexico
I got mine off of Amazon. Again, very easy installation.
All plug and play.
gotta be careful with the harness some tiny gauge wires they give you lol
Old 05-08-2014, 05:16 AM   #14
Region: New Mexico
the best pic I have
Old 05-08-2014, 05:52 AM   #15
bucko's Avatar
But mine had the factory harness clip, so I simply had to unplug the factory shifter with its O/D button harness, and plug in the Hurst handle, with its harness and factory equipped plug.
Easy peasy.
For Sale: FOR SALE: Hurst Black Shift Ball / No Hurst Script MELLOWYELLOW06 Mustang Parts for Sale and Wanted 0 01-30-2014 07:13 PM
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 10:34 PM
Hurst Shifter: Will this one fit? USMCSS 1996-2004 Mustang GT 16 03-18-2007 11:01 AM
WTB: Hurst shifter Ball bullitt482 Mustang Parts for Sale and Wanted 6 03-17-2007 03:50 AM
Hurst short throw shifter Blue232 Pre-2005 V6 Mustang 3 10-11-2003 11:07 PM
08:58 PM
