Replacing 2013 door speaker - Mustang Evolution
Old 05-08-2014, 07:17 AM   #1
colemaneric's Avatar
Just bought new speakers to replace my 2013 shaker 500 speakers but just found out I needed a speaker bracket? Totally confused any help much appreciated!
colemaneric is offline   Reply With Quote
Old 05-08-2014, 09:06 AM   #2
Socal Stangman's Avatar
I think people are ordering the spacer from a 2010 GT. Do a little more research and youll see what Im talking about. If I get a few minutes Ill see if I can find it. I just did my 2014 and I had to do some "creative cutting" but I got it to work.
Old 05-08-2014, 09:38 AM   #3
I found one thread. There are a couple more but I cant find them right now.
2013 Mustang V6 Door Speaker Installation - Ford Mustang Forums
Old 05-08-2014, 09:47 AM   #4
bucko's Avatar
Anyone want to do a write up and perhaps some pictures on how this is done? We would then move that over to the Mustang tech and DIY section.
Old 05-08-2014, 12:54 PM   #5
nhcowboy's Avatar
Silverhorseracing has a good PDF on the steps (since you have to do basically the same thing to replace the stock inside door release handles for billet ones.... Ask me how I know).
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 05-08-2014, 01:06 PM   #6
I bought these and used a dremmel to cut out some the existing plastic and these went right in place.
Amazon.com: Kenwood KFC-P680C 6-Inch x 8-Inch Easy Fit Ford/Mazda Speaker System: Car Electronics
Old 05-08-2014, 01:18 PM   #7
bucko's Avatar
I guess we could create a post then that points to this PDF, and title it "Door speaker install for 2011 to 2014 Mustangs"?
Old 05-08-2014, 01:26 PM   #8
I can tell you this much...on the 2014 no speakers are going to be drop in, plug in and done. They will all require either a new spacer or make the current one work like I did.
Old 05-08-2014, 01:38 PM   #9
bucko's Avatar
Do you have pictures of how you did it for your 2014? This would be a worthy post for the DIY section!
Old 05-08-2014, 01:40 PM   #10
Yea I've been looking around at spacers and mounts but couldn't find a website to buy them. Should I just try and call ford asking for a pair if they're in stock?
Old 05-09-2014, 04:06 AM   #11
sbbamafan's Avatar
Its all right here.
how to do speaker upgrade on 2013 shaker 500
2013 Red Candy Convertible with Stone Leather, Pony Package and Mt-82
sbbamafan is offline   Reply With Quote
Old 05-09-2014, 12:13 PM   #12
smurf stang's Avatar
But from what I understand if it is a base V6 then no spacers or brackets are necessary only on the Shaker.
2016 VW GTI 2.0 Turbo
Old 05-09-2014, 12:16 PM   #13
sbbamafan's Avatar
I am not sure whether the base needs spacers or not BUT it only takes about 10 minutes to yank off a door panel and look at it. Just do it!
Old 05-12-2014, 08:35 AM   #14
Yeah it's only the ones with the shaker that need the spacers and I'm 16 and taking the door panel off was no problem just took a second to re-align it and screw it back in
Old 05-14-2014, 04:35 PM   #15
Finally got them installed. You need to buy the 2010 GT premium speaker bracket mounts http://parts.autonationfordwhitebear...iagram=JC10465 which is item number 7 (buy left and right). I used the old screws that mounted the old speakers to the brackets and then used the wiring harness from amazon to connect and button the door back on a BAAM! new door speakers (I'm 16 and this was a piece of cake)
Need help 2013 door speaker replace colemaneric Mustang Audio & Video 3 05-08-2014 04:49 PM
Door speaker 2013 GT - pic heavy Alerotaz 2011-2014 Mustang GT 17 04-29-2014 11:43 AM
Replacing stock fuel door with stock fuel door...help? MarshallYoung 2005-2010 V6 Mustang 13 07-23-2012 11:23 PM
Replacing Driver Side Door tigerfan2771 Mustang Audio & Video 4 03-04-2010 05:14 PM
2004 door panel speaker removal drwang Mustang Audio & Video 3 10-13-2005 07:43 PM
07:52 PM
