Gt500 style spoiler from AM - Mustang Evolution
Old 05-08-2014, 08:11 PM   #1
Will2329's Avatar
I currently have the rear OE style spoiler (just a lip) and would like to upgrade to the gt500 style spoiler. Has anyone else done this here? How are the pre painted parts from American muscle? I have a white stang with a black spoiler right now so am going to be buying the black gt500 style one. What do y'all think...
Will2329 is offline   Reply With Quote
Old 05-08-2014, 09:16 PM   #2
BeyondUno's Avatar
I had installed mines about 2weeks ago, shipped by AM, black which matched the cars factory color perfectly. Definitely improves the look of the car. Click image for larger version
(only picture I have atm showing the spoiler/from my ig account)
2014 Black Mustang 3.7
Airaid Cold Air Intake, BBK Off Road X-Pipe, Borla S-Type Ab, Amr 18s Black Wheels, Eibach Racing Springs (will be installed soon), Rear/Side Window Louvers, 20% Tint, 50% Driver/Passenger Windows
BeyondUno is offline   Reply With Quote
Old 05-08-2014, 09:28 PM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Yes, plenty of people have done it. As far as AM's paint quality, I have no experience with it since I bought the unpainted one. My buddy painted mine for me so I couldn't justify paying that much extra for AM to paint it.
2012 Kona Blue 3.7L V6:
Old 05-09-2014, 03:40 AM   #4
bucko's Avatar
Just give yourself time (and have plenty of patience) when removing the stock spoiler. The assembly line at Ford really did not want to ever read about failure or movement of an OEM spoiler install! That thing uses bolts that are easily removed by opening the trunk; this is where the "easy" ends. The large amounts of the 3M automotive tape also used is amazing. It sticks like it should; real, real good. You will need some plastic type flat bondo applicators to assist in removal; use them to slide in between the front, side, and rear of the spoiler where it attaches to the trunk lid to carefully seperate the spoiler from the trunk. These will not scratch your paint. Don't use any type of metal! The typical dental floss trick does not work, as you will only be able to cut in with it about 3 inches from the left and right sides of the spoiler before coming to a threaded stud.
Just be patient and calm. It will come off.
Old 05-09-2014, 05:55 AM   #5
I also just did this. Here is some before and after pics so you can see the difference
Finally time to start a change to my V6 Vert
Hope it helps you make a decision. The preprinted was very well done also and comes well packaged from AM.
I did the fishing line trick to get mine off. Pried up either side until I could slip the line under the bolt and continued towards the center of the spoiler. Did that on both sides and worked great.
Batdive is offline   Reply With Quote
Old 05-09-2014, 08:22 AM   #6
I did it about two weeks ago. As others have stated, the hard work is taking the stock spoiler off. I ended up getting a cheap heat gun from Harbor Freight to help the process. I tried to just work it off, but ended up breaking one of the "wings" off the stock spoiler. I used plastic spreaders and the heat gun. It really helps to weaken the 3M tape. Start on one end, loosen, and slowly work your way to the other end. I also used a razor blade to cut the tape as I was able to get some wiggle room. Once the wing was off, the remaining tape came off with good old finger power. I tried the plastic spreader, but that really didn't work. I remembered reading somewhere that you can just start rolling the tape with your fingers, kind of like that rubber glue that attaches credit cards to the mailing paper. Just keep rolling it. That technique actually ended up being the easiest and cleanest.
Once you are ready to install the new spoiler, take just a little of the backer off the new 3M tape. Just enough to help you hold the wing in place while you put in the new screws. Once you have the wing in place, but not tightened all the way, you can now pull the rest of the tape backer off.
The color match and paint quality are great. Mine is Deep Impact Blue and you cannot tell a difference between the factory paint and the after market parts from AM...
Hope this helps...
Steve
'14 Deep Impact Blue V-6 Coupe
MCA Package
V-6 Performance Package
Premium Package
SRE TUS is offline   Reply With Quote
Old 05-09-2014, 09:52 AM   #7
Will2329's Avatar
I don't know if i want to mess with trying to take of the oem spoiler myself. I might just have a local body shop install...
Old 05-09-2014, 01:22 PM   #8
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Awesome! You'll love the GT500 rear spoiler. The paint match is perfect. We make sure that the paint is in perfect shape and a great match, every time!
The GT500 or MMD Ducktail spoiler will definitely change the looks of your Mustang! Let us know if we can be of any assistance or if you have any questions at all.
-Dan
Old 05-09-2014, 01:57 PM   #9
Here is a close up of mine...
Steve
MCA Package
Premium Package
Old 05-09-2014, 03:16 PM   #10
BeyondUno's Avatar
I forgot to mention that I did not have a original spoiler and had to drill holes to install mines.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
Old 05-12-2014, 07:49 AM   #11
AmericanMuscle.com
Sponsor
Attachment 156388
Looking good! I love the look of this spoiler.
Keep up the great work!
-Dan
new mmd ducktail style spoiler silverskoundrel AmericanMuscle 25 02-23-2014 05:09 PM
3dCarbon GT500 Style Rear Spoiler jonyou Mustang Paint, Appearance & Detailing 1 12-13-2013 04:50 AM
Gt500 style or roush spoiler? Ponyboarder 2011-2014 V6 Mustang 14 09-16-2013 01:50 PM
3DCarbon GT500 Style Spoiler ?? Kystang615 2011-2014 Mustang GT 4 09-27-2011 11:00 PM
Cobra Style or Euro Style Headlights? Black95GT Mustang Audio & Video 3 03-06-2004 10:05 PM
05:28 PM
