3.73 gears affect top speed ? - Mustang Evolution
Old 05-11-2014, 10:14 PM   #1
Okay I searched quite a bit and couldn't find an answer to my question. Well after borlas I'm now planning to go with 3.73 or 3.55 gears. Currently mustang is electronically locked to 115mph. If I put new gears will the top speed decrease or will it remain same? In other words, Is electronic lock based on speed or rpm?
This is my daily driver and I used in winter as well. Highway driving everyday and is about 48 miles with about 5 miles of city driving. What do you guys recommend ? The service tech at ford is willing to install gears for about 400-500 with oil,etc. he will also tune the speedometer. I will get the tuner soon too.
Thanks
FordMustang12 is offline   Reply With Quote
Old 05-11-2014, 10:19 PM   #2
GrabberMeBlue's Avatar
Thanks
Speed. If it was based on RPM, your engine would be cutting out on you all the time as you go through the gears.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 05-11-2014, 10:26 PM   #3
Not necessary, it can be programmed to cut out the engine ONLY in 6th gear at a certain rpm. This would limit the speed then. If it is locked using speed then I'm sure top speed won't be affected with 3.73 gears but if it is locked using rpm then the top speed would decrease.
Old 05-11-2014, 11:15 PM   #4
Same can be said for if you get a taller tire in the rear. That will make less rotations than before so your rpms will go down which will technically raise the top speed......
It's based on actual speed
Top Speed with Gears Slow4V 1996-2004 Mustang GT 36 04-11-2013 07:34 PM
4.10 gears and top speed 13 stang22 General Mustang Discussion 7 02-19-2013 08:40 AM
CAI affect stang with cali emmisons 2000v6stang Pre-2005 V6 Mustang 5 09-11-2012 12:40 AM
what mods dont affect your warranty Sprintradc 2011-2014 Mustang GT 10 03-31-2012 08:47 AM
does cluster gauge affect sensor?? jmpark527 2005-2010 Mustang GT 0 11-23-2011 08:32 AM
09:55 AM
