Suspension help? - Mustang Evolution
Old 05-13-2014, 01:57 AM   #1
Eric e's Avatar
Suspension help?
Things I have done to my car:
Sr lowering springs
Adj. panhard bar
Strut tower brace
Camber bolts
So when I did these to my car, I could go around a curve pretty easy at 50+ mph (this is on private course) but now when I try this, the car seems to jerk a couple times and the traction control light flashes and the break pedal also shutters a bit. What did I mess up on my car? What do I need to replace? Please help me lol
Eric e is offline   Reply With Quote
Old 05-13-2014, 09:02 AM   #2
air_commando88's Avatar
What tires are you running? Did you get an alignment afterwards? Are you pushing those corners harder than the 50+ prior?
Sent from my HTC6435LVW using Mustang Evolution mobile app
air_commando88 is offline   Reply With Quote
Old 05-13-2014, 09:03 AM   #3
Eric e's Avatar
Stock tires
Yes I got the alignment a little after the install
And it happens when I go 40-50 mph
Haven't tried going faster since it started happening
Old 05-13-2014, 10:54 AM   #4
Site Sponsor
Sponsor
AMWill's Avatar
Make sure your ABS is plugged in all the way, both front and back. It may have a poor connection that's causing it to kick on. Even with a poor alignment, you shouldn't have the ABS kicking on with the stock tire at a slower speed than the stock suspension.
Is there anything else that you changed?
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-13-2014, 12:18 PM   #5
Eric e's Avatar
I have a cai with tune
And axle backs but that's about it
---------- Post added at 12:18 PM ---------- Previous post was at 12:18 PM ----------
Where is the connection for the abs?
Old 05-14-2014, 12:12 PM   #6
Site Sponsor
Sponsor
AMWill's Avatar
There should be a connector at each wheel hub. Just make sure it doesn't have grim all over it. Unplug and replug it back in just in case. Also, try and pull the negative battery terminal to reset the KAM memory.
Hope this helps!
Shane
Suspension Make-over help blue-saleen Pre-2005 V6 Mustang 6 12-09-2009 07:18 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
suspension help tim11 Pre-2005 V6 Mustang 5 10-23-2005 02:53 PM
rear suspension need help fixing it... rpm Pre-2005 V6 Mustang 18 10-03-2005 07:01 PM
suspension help 35thAniVertible Pre-2005 V6 Mustang 23 10-31-2003 12:54 PM
08:22 PM
