2014 v6 launch? - Mustang Evolution
Old 05-13-2014, 08:07 PM   #1
G3racing's Avatar
2014 v6 launch?
What is the best rpm to dump the clutch for a race at the strip I have a cold air intake Nd running bamas 93 race tune along with a set of nitto 555r drag radials my tread is wearing down In the back need help guys
2014 Mustang V6 Manual
AMR Charcoal Wheel & NITTO Tire Kit - 20x8.5
G3racing is offline   Reply With Quote
Old 05-13-2014, 08:09 PM   #2
G3racing's Avatar
I had no problem launching before but now after I modded my car I get no traction I usually keep advancetrac off should I or should I leave it on
Old 05-14-2014, 09:12 AM   #3
somedopebeats's Avatar
2k rpm and dont dump the clutch
somedopebeats is offline   Reply With Quote
Old 05-14-2014, 09:25 AM   #4
Send a message via AIM to Borii
Dumping the clutch is a no no. With the 555R I would say 6k and a slimp dump after a decent burnout when the temps are above 60. 1.75X 60' should be attained with tire pressure around 25-28
Also NO TRACTION CONTROL
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-14-2014, 09:57 AM   #5
G3racing's Avatar
So just let off clutch fast and give it gas ?
Old 05-14-2014, 09:59 AM   #6
Sold - 2001 Audi S4
Old 05-14-2014, 12:12 PM   #7
ebgonzalez1's Avatar
It all depends.... if you slip the clutch might burn it out but with nittos you shouldn't need to slip it, I do mine at around 3200 rpm dump it and press the gas according to how much its gripping my best was a 13.7 with a passanger same mods but regular stock tires. It depends on you.
Sent from my SGH-T999 using Mustang Evolution mobile app
"Just a lil Sixxer...."
ebgonzalez1 is offline   Reply With Quote
Old 05-14-2014, 12:37 PM   #8
You slip the clutch on a manual from pure shock.
WHat was your 60' foot time?
Sold - 2001 Audi S4
Old 05-15-2014, 07:50 AM   #9
2.00-2.10 it varied as I changed lanes
Old 05-15-2014, 07:58 AM   #10
Exactly what I expected. You said you were "gripping" but with a 2.0-2.10 60' you definitely were not. See what I am saying? If your 60' times aren't low 1.9s or with practice, high 1.8s then the advice is moot because the results conflict with the advice.
You will not burn your clutch our slipping it for a split second.
Sold - 2001 Audi S4
Old 05-15-2014, 09:15 AM   #11
1.9 on stock tires v6 with just a tune on 2.73?? Thats hard to believe... possible but rare, the 5.0 with tire and gears were getting a best of 1.9...? Note I didnt have drag radials like the op... worn out stock good years not even pirellis... on a cai and tune 2.73 I did hit 1.8-1.9 but once I got control arms better tires and shocks.... 1.8 on stock 3.7 with 2.73 thats really unheard from what ived seen from other people and at the track... no matter dumping or slipping the clutch
Old 05-15-2014, 09:32 AM   #12
Fyi fastest naturally aspirated 3.7 hitting 12.6 1/4 on drag slicks did a best of 1.6-1.7 ft times....
Old 05-15-2014, 10:09 AM   #13
WHat do you mean a 5.0 with "tire"? Not street tires I hope.
You don't have to believe it for it to be true lol. I was just stating that 2.0-2.10 is not gripping by any means. May be the best most people will get but that doesn't mean it is good. Know what I mean? Doesn't have to be common.
The car has the power to pull a 1.9 on 2.73. Launching at 5 or 6k slip.
Sold - 2001 Audi S4
Old 05-15-2014, 10:20 AM   #14
All I am saying is its hard to believe a stock 3.7 will hit 1.9, it might be possible but it would have to be in really good conditions. And to slip it at 6k... thats too much from what others slip at. Unless I see proof I cant see it happening with constant runs... as for the op it depends on what he is more comfortable at.
dump the clutch before launch? good advise? jones4stangs Pre-2005 V6 Mustang 2 10-26-2005 12:18 AM
How to launch on a 1999 v6 w/ 4.10 gears ntc432 Pre-2005 V6 Mustang 6 05-30-2005 08:25 PM
nice launch Warfire80 The Bar 6 05-21-2004 10:46 AM
Drag Launch Springs 02whitestang Pre-2005 V6 Mustang 1 11-22-2003 01:41 PM
.. Official Office 2003 System Launch Thread ...? ..... Yeah Laser02 The Bar 4 11-06-2003 02:14 PM
09:34 AM
