Ford Factory Sync Install - Mustang Evolution
Old 05-14-2014, 09:28 AM   #1
So I just received my sync kit in the mail and can only find instructions for installing on a 2009- Mustang. Does anyone know if the installation will be significantly different on the 2014 Mustang? I have the base v6 if that matters. I have also included a link to the instructions below. Thanks in advance.
http://www.partscheap.com/v/vspfiles...nc_6-18-08.pdf
blp12 is offline   Reply With Quote
Old 05-14-2014, 09:35 AM   #2
If you go back to the link I sent you earlier in your post about Bluetooth everything you need to know on the install is there.
my04gt is offline   Reply With Quote
Old 05-14-2014, 09:40 AM   #3
I did look through it, just felt I didn't quite understand from what was said in that thread. I will look again though. I did try searching through the forums and couldn't find any other threads discussing this. Thank you.
Old 05-14-2014, 09:51 AM   #4
Where you live at I'm in southern Ohio I might be able to help you
Old 05-14-2014, 10:18 AM   #5
I'm in Southern California. I'll drive right over. J/k. I appreciate your willingness to help. I will pm you if I run into any trouble.
Old 05-14-2014, 10:46 AM   #6
FastFord13's Avatar
Just curious, is this kit the that's on eBay for like 70$?
2013 V6, Candy Apple Metallic.
Gt500 spoiler, Gt500 stripes,2010 Gt premium wheels, Pirelli tires,Painted side mirrors covers,Upper and lower black billet grille,Pony projection lights,Boss 302 strut tower brace, SR lowering springs, Barton shifter bracket,Airaid Cai,Bama tuned,BBK shorty headers,Roush AB, 3.73 Ford racing gears.
Old 05-14-2014, 11:36 AM   #7
$63, but yes. I'm going to work on it and plan on updating the forum on my progress. I compared the $63 one and it is the exact same kit that is $500-$600 everywhere else. I'm excited about the possibility of adding sync to my base v6 for $63, instead of the $1000s every alternative cost. I figure if it doesn't work I'm only out $63.
Old 05-14-2014, 12:53 PM   #8
It works and will gladly help
Old 05-14-2014, 01:39 PM   #9
FastFord13's Avatar
Can you please keep me updated??!! I inquired about this fitting on a 13 base with the seller and he said no, not compatible. I hope you get it to work I'd be all over that! When are you attempting to do it?
Old 05-14-2014, 02:51 PM   #10
I have installed this as well as others and it works. there are a few items like say a command that does not work unless you get it programmed. the wiring is a litter different the for the 09 mustang but if you look for adding sync to a 2011 it will come up
Old 05-14-2014, 10:59 PM   #11
Quick Update:
Spent a good few hours working on installing the kit today. The instructions that come with this kit are not very detailed, and I will confess I know very little about electronics. Thanks to the help of my04gt I made a lot of progress. Unfortunately I also made several mistakes. While trying to splice one of the wires on my data connector I accidentally cut the wire. I was able to get it back together and everything seems to be working fine. The other negative was that I couldn't find schematics to compare the wiring of the 09 Mustang (the year this kit was made for) with the 14 Mustang (my year). I believe I have the wiring correct, but that is yet be determined. In the morning I will begin working on splicing into the Smart Junction Box which is the final big step before putting everything back together. Again, I don't know what the proper wiring is, but hope to find out. What I am finding is that there are not a whole lot of schematics on the internet for later model Stangs. More to follow tomorrow.
Old 05-15-2014, 03:54 AM   #12
FastFord13's Avatar
My wife just bought a 14 fusion with sync and from what I can tell early on is isn't the "say a command" basically the sync?
Old 05-15-2014, 06:33 AM   #13
Fast Ford no that is just a part of what the sync offers, and can be programmed for around 70.00 or so. I make phone with the phone button and dieler numbers with the number butttons. Stream music, and have music with a usb drive.
Old 05-15-2014, 06:36 AM   #14
Blp12 please please double check your wiring with the link I sent you. If you need more help text me and I will call you back when I get off
Old 05-15-2014, 10:57 AM   #15
FastFord13's Avatar
Very cool! Did they pull it off of eBay now? I can't seem to find it, would anyone have the link please?
Old 05-15-2014, 11:32 AM   #16
http://www.ebay.com/itm/251219233257
Old 05-15-2014, 01:36 PM   #17
FastFord13's Avatar
Thanks
Old 05-16-2014, 07:52 PM   #18
UPDATE: Got my Sync to work and I can't believe it only cost $63. I will not say it was easy, but I did make it much more difficult than it should have been through my own stupidity. Now knowing how it all goes together I could do it again in a couple of hours. The biggest struggle of it all was figuring out which wire to splice into for accessory power. Again, I want to thank my04gt without whose help I am not sure I would have never made it past looking at the instructions.
Old 05-16-2014, 07:54 PM   #19
FastFord13's Avatar
Can you post a video of how it works? I'm very interested in getting one. Thanks
Old 05-16-2014, 10:43 PM   #20
I'm not sure I am the best person to post a video, but that's a good idea. I did a lot of googling but found very little help on the internet, so I think it would be good to have some more info about the installation online. I got a lot of help from one generous guy on here who spent a lot of time with me on the phone and putting up with my obvious ignorance of how cars work. I am open to helping you, or anyone out if you want to install, and at the very least I may post some pictures later on. There is a nice thread on here about the install that I found helpful, but some of it I had difficulty with. If you don't have sync, I would definitely encourage you to purchase this box for $63. If I can install it breaking my car, anybody can. And considering it costs $1000s to have one professionally installed, this is a fantastic deal and well worth it.
is it hard to install a factory 2010 to 2013 mustang gps radio manlaw38 2011-2014 Mustang GT 13 03-27-2013 08:57 PM
Install fog lights in the center of factory bumper Built_GT_Tough 2005-2010 Mustang GT 6 01-16-2013 05:31 PM
What changes do I need to make on a 2004 Mustang GT to install factory Saleen supercharger? eljin 1996-2004 Mustang GT 4 12-21-2011 06:09 AM
Ford to Open Sync Software for Developers OsirisGuy General Car Discussion 7 11-04-2009 09:30 AM
94-98 Factory headers VS 99-04 Factory headers Herbstang Pre-2005 V6 Mustang 2 08-08-2007 04:53 PM
12:57 AM
