lowering springs with panhard bar? - Mustang Evolution
Old 05-21-2014, 11:41 AM   #1
13BKV6's Avatar
I just ordered the SR lowering springs and panhard bar for my 2013 V6. the springs should be in this Friday, but the panhard bar is on backorder
can I install the springs and run that way for a while until the panhard bar comes in or should I wait until the panhard bar arrives to install the springs? I heard that anything over 1.5 drop needs the bar, but this one drops 1.5 in front and rear.....
Current: 2015 GT Premium Performance Package-stock for now
Past: 13 V6, 11 MCA V6, 89 GT, 88 GT, 04 V6
13BKV6 is offline   Reply With Quote
Old 05-21-2014, 12:16 PM   #2
2 Stangz's Avatar
Region: Nevada
Oh lawdy, another one. Sure, you can install the springs without the adj. panhard rod. Your new camber un-alignment with those springs is going to love eating through tires as well.
Old 05-21-2014, 12:26 PM   #3
13BKV6's Avatar
this is why i'm asking. thanks for the rude answer that I needed.
Old 05-21-2014, 12:31 PM   #4
Socal Stangman's Avatar
Youll be fine. Obviously, you dont want to drive it like that for a long period of time.
Old 05-21-2014, 12:32 PM   #5
13BKV6's Avatar
thanks. it would only be until the panhard bar comes in.. I know I'll be super anxious once the springs come in...
Old 05-21-2014, 12:32 PM   #6
MustangDawg's Avatar
Perhaps 2 Stangs was eluding to the search feature, just sayin
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 05-21-2014, 12:34 PM   #7
2 Stangz's Avatar
Region: Nevada
For a 1.5" drop, you'll need caster/camber plates. I'd wait to install the springs until the adj. panhard rod arrives. An adj. UCA will also help with rear alignment. After everything is installed, it may be ideal to go to an alignment shop to make sure everything is set right.
Old 05-21-2014, 12:34 PM   #8
13BKV6's Avatar
that is why I mentioned that I read that anything over 1.5 needs the panhard... I did use the neat search feature. my question isn't whether I need the panhard or not, since it is on order....
Old 05-21-2014, 12:35 PM   #9
13BKV6's Avatar
thank you.
Old 05-21-2014, 12:38 PM   #10
2 Stangz's Avatar
Region: Nevada
I take a rude approach because many people fall for the low price of the SR springs and don't do enough research and end up taking the 'cheap way out' whether they know it or not. Going that route could result in $1,000's in damages and of course I wouldn't want that to happen to anyone.
Old 05-21-2014, 12:42 PM   #11
13BKV6's Avatar
understandable, and of course I want to avoid that route. are the SR springs not good, or do you only mean when they are installed without the c/c plates and panhard bar?
Old 05-21-2014, 12:43 PM   #12
+1
Don't risk or cheap out on anything like suspension which is constantly working to keep you on the road.
Old 05-21-2014, 12:50 PM   #13
2 Stangz's Avatar
Region: Nevada
Any lowering to our S197's will require a handful of supporting mods. The more severe the drop, the more they're going to cost.
SR seems to be a company with one goal in mind - Cheap, okay-quality parts that "get the job done," ... Saying that there's most likely better alternatives on the market, but I'm not dogging the company.
Old 05-21-2014, 12:55 PM   #14
Ideally if you want to lower your car right the first time you need:
Springs (obviously)
Shocks/Struts
CC Plates
Adj. Panhard Bar
Adj. Upper Control Arm
LCA relocation brackets.
Old 05-21-2014, 01:02 PM   #15
2 Stangz's Avatar
Region: Nevada
Springs (obviously)
Shocks/Struts
CC Plates
Adj. Panhard Bar
+1 as well.
I've got a ~$1,600 suspension build (springs/shocks/struts/cc plates/adj. panhard/adj. UCA/LCA's/LCA brackets) that I plan to work for, purchase, and install this summer. Should be a lot of fun and great final result.
Old 05-21-2014, 01:11 PM   #16
I've got just about $1,200 into my suspension right now and i haven't even lowered it yet, i'm saving that for when everything else is already in place. Which is coming up very soon, as soon as i have the money for the coilovers.
Old 05-21-2014, 01:13 PM   #17
2 Stangz's Avatar
Region: Nevada
Damn. Ah, coilovers, a territory I haven't ventured into yet.
Old 05-21-2014, 01:17 PM   #18
You get to pick your ride height, and how stiff or soft they are.... Whats not to love?!?!?!!!
Old 05-21-2014, 01:18 PM   #19
2 Stangz's Avatar
Region: Nevada
Interesting, I'll have to look into it. I bet they aren't cheap.
Old 05-21-2014, 01:21 PM   #20
Depends. You can get a full kit for $3k, or you can do what i'm doing, get a conversion kit from Maximum Motorsports, they have a conversion for name brand shocks and struts like KONI or Bilstein, so if you get the shocks and struts then the kit it will come with anything those name brand coilovers will have, and you get to pick the spring rates also. Still not "cheap", but its not like KW expensive.
Old 05-21-2014, 01:49 PM   #21
FastFord13's Avatar
You don't "need" cast/camber plates. If anything you might need camber bolts with an adjustable pan hard bar. And "it may be ideal to go to an alignment shop" , no you'll need and should always get an alignment any time you do suspension work. Your not going to cause 1000s$$$ in damages if your lowering only 1.5 or less if its a dd. I car pool every third week with three adults in one of the most notorious pot hole filled roads (Quebec) and my car, other than being a little stiffer than stock, has almost stock feel to it. Add on suspension parts will come down the line but absolutely not necessary to do all at once. This info is just not mine but the many people from the AM reviews of the lowering springs and the AM reps them selves. They will tell you the exact same thing, would be nice to do everything but not necessary. Have you lowered your ride?
2013 V6, Candy Apple Metallic.
Gt500 spoiler, Gt500 stripes,2010 Gt premium wheels, Pirelli tires,Painted side mirrors covers,Upper and lower black billet grille,Pony projection lights,Boss 302 strut tower brace, SR lowering springs, Barton shifter bracket,Airaid Cai,Bama tuned,BBK shorty headers,Roush AB, 3.73 Ford racing gears.
Old 05-21-2014, 02:05 PM   #22
LuisBlackGT's Avatar
+1
Lowering 1.5" you don't need cc plates
2014 Black Mustang GT. 20" Amr wheels, Sr Performance lowering springs 1.5", stillen front chin, mmd window louvers, roush AB exhaust. FOLLOW ME ON INSTAGRAM: @barrios_Luis
LuisBlackGT is offline   Reply With Quote
Old 05-21-2014, 02:37 PM   #23
tj@steeda's Avatar
If you all are looking to order suspension parts & save some money in the process ... Steeda is currently holding a 20% off memorial day sale.
You can always reach me at tim@steeda.com if you have any questions or are seeking feedback / advice.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 05-21-2014, 02:45 PM   #24
2 Stangz's Avatar
Region: Nevada
To each his own. However, my research doesn't come from amateur customer reviews and representatives trying to make as many sales as they can.
Old 05-21-2014, 02:48 PM   #25
tj@steeda's Avatar
I apologize if you took my informative information as a representative trying to get as many sales I can.
You are free to go with any company you choose ... I simply offered an opportunity to take advantage of suspension parts from a leading manufacturer in suspensions.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 05-21-2014, 02:53 PM   #26
2 Stangz's Avatar
Region: Nevada
Haha, no, Tim that was not directed towards you...
Whether you remember or not, you have helped me multiple times before. I'm a large fan of Steeda and especially the Steeda blog (which I have learned a lot from). Most of that $1,600 suspension build I mentioned a few posts prior actually contains Steeda parts... Except I just don't have the money yet to take advantage of that sale.
Old 05-21-2014, 02:54 PM   #27
FastFord13's Avatar
Your clearly set in your ways. All good. Bit those "amateurs" are mostly mustang enthusiasts who I will always welcome their experiences and views like your own. And for myself I'll always welcome Shayne and Dan's input anytime, even though I feel very comfortable with what direction I'm going with my car, it never hurts to have an experts view on things. If they were trying to get there hands into my wallet don't you think they would agree and say yes its necessary to replace all of those parts? I believe that's why they are so well respected on here because they will help you with their own experiences and tell you what works and what doesn't.
Old 05-21-2014, 02:55 PM   #28
tj@steeda's Avatar
No worries ... I just wanted to make sure I didn't "cross the line".
Thank you for being a Steeda supporter.
Hopefully next time we can find a sale that is aligned with your purchase period!
TJ
Steeda Autosports
www.steeda.com
Old 05-21-2014, 02:56 PM   #29
FastFord13's Avatar
Best Regards,
TJ
Please don't take offense, his views don't reflect all on this forum. I myself always welcome your input on whatever topic is being covered!
Old 05-21-2014, 03:03 PM   #30
2 Stangz's Avatar
Region: Nevada
Yes. I was taught by mentor and experience to do things right the first time.
You missed one of my posts, bud.
TJ
Any sales going on in July/August?
Old 05-21-2014, 03:07 PM   #31
FastFord13's Avatar
Lol. OK.
Old 05-21-2014, 03:15 PM   #32
FastFord13's Avatar
You'll be fine, the panhard bar is something you can do in your driveway if you install the springs first. I did me the opposite lol, not on purpose but because the shop that was doing my gears were doing the springs at the same time a month later so I did the panhard bar first, then a month later when the springs and gears were done I just adjusted it to correct the axle, literally a 20 min job. Good luck its going to look great!
Old 05-21-2014, 03:17 PM   #33
FastFord13's Avatar
SR springs adjustable panhard bar with 19's IMO a perfect drop, not to much but got rid of the 4x4 look.
Old 05-21-2014, 03:28 PM   #34
2 Stangz's Avatar
Region: Nevada
I completely forgot to address this. Any lowered S197 (even if it's a 0.1in drop, for example) you're altering the factory suspension geometry and appropriate aftermarket parts to correct the geometry will be necessary for optimal performance and less problems down the road.
Old 05-21-2014, 03:33 PM   #35
FastFord13's Avatar
Lol, yes your obviously correct, when I sit my *** in the car Im technically altering the cars geometry, lmao.
For Sale: H&R Super Sport Lowering Springs for 2011-2014 and Hotchkis Adjustable Panhard Bar sleeperstatus Mustang Parts for Sale and Wanted 12 11-20-2013 06:41 AM
Looking to sell my HR super sport lowering springs and hotchkis panhard bar sleeperstatus 2011-2014 Mustang GT 4 07-16-2013 10:05 AM
Ordered springs, panhard bar & camber bolts from AM dobypaw3 2011-2014 V6 Mustang 10 07-13-2013 09:23 AM
Panhard bar needed for lowering? mcvicar04 1996-2004 Mustang GT 3 12-20-2011 08:47 AM
01:17 PM
