Manual trans question. - Mustang Evolution
Old 05-30-2014, 05:57 AM   #1
FastFord13's Avatar
OK so has anyone with a manual trans experience this or know what it could be? It happens only sometimes but when the clutch is to the floor and I'm stopped I'll put it in gear and get a "thud"!? Any ideas?
Sent from my Nexus 5 using Mustang Evolution mobile app
Old 05-30-2014, 05:59 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The stock 2-piece driveshaft tends to have a lot of play in it. That may be what you're hearing
2012 Kona Blue 3.7L V6:
Old 05-30-2014, 06:01 AM   #3
FastFord13's Avatar
Maybe, but with the clutch push in all the way I'd think there shouldn't be any torque on it.
Old 05-30-2014, 06:22 AM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Ah good point. I think I missed that part of your first post. Not really sure then.
Old 05-30-2014, 01:05 PM   #5
Sanguin's Avatar
If you're talking about the transmission kinda thunking into gear, mine does that too at times. I think it's due to imprecise alignment of the remote shift box and it binds the shifter arm.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 05-30-2014, 05:58 PM   #6
FastFord13's Avatar
Its when the clutch is fully pushed to the floor and as soon as I put it in a gear I'll get a thud, its almost like if you were to put in a gear and let the clutch out quickly and you get a thud, but this happens when the clutch is completely pushed in??!! Feels like something is engaging in the transmission ( torque ) when nothing should be.
Old 05-30-2014, 06:11 PM   #7
Siber Express's Avatar
If you are in neutral with the clutch out the front half of you transmission is turning, when you push the clutch in if the transmission does not come to a complete stop before putting it in gear you will get a thud when you do. That is the same reason they put clutch brakes on larger transmissions in the big trucks to prevent grinding to get in gear.
Old 05-30-2014, 06:17 PM   #8
FastFord13's Avatar
I actually did a test because I thought that's what was happening. I stopped at a red light, put it in neutral and waited about 10 seconds then put it in first with the clutch to the floor and thud. Most of the time its fine, could that be it? It definitely feels like that's what's happening.
Old 05-30-2014, 06:20 PM   #9
FastFord13's Avatar
When its sitting in neutral and rpms are at 700 can it still happen?
manual trans question andreas 1979-1995 Mustang GT 3 04-26-2007 12:25 PM
manual trans oil 00stang3.8 Pre-2005 V6 Mustang 4 12-28-2006 03:28 PM
Just bought a 2006 V6 Manual trans Pony pkg Rick0636 Pre-2005 V6 Mustang 17 02-22-2006 08:18 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
05 v6 manual trans.. MonteCitan Pre-2005 V6 Mustang 29 01-07-2005 04:40 PM
06:14 PM
