2014 GT grill and LED fog lights on a V6 - Mustang Evolution
Old 05-31-2014, 09:06 PM   #1
Toydos's Avatar
Just got this >>> Click image for larger version
ID:	158281 I've seen two methods to do the mod,one is to remove the bumper, the other is pull it out, what method for the upper grill do you guys recommend, the lower grill seems less complicated. What type plug/socket connector will work for the LED fog lights , hints welcome
[SIGPIC] My other toy and babe
Toydos is offline   Reply With Quote
Old 05-31-2014, 09:35 PM   #2
Just installed the upper gt grille on mine yesterday. I pulled the grille out from the front and popped the gt grille right in. I haven't done the bottom yet.
Bigshow14 is offline   Reply With Quote
Old 05-31-2014, 09:51 PM   #3
dacm99's Avatar
I just did a quick write up on pulling out the v6 grille last week. It is super simple.
dacm99 is offline   Reply With Quote
Old 05-31-2014, 10:04 PM   #4
I must have missed it, what's involved with changing out the lower.
Old 05-31-2014, 10:06 PM   #5
Cise's Avatar
I hope you got the GT grille surround too
Cise is offline   Reply With Quote
Old 05-31-2014, 10:17 PM   #6
Toydos's Avatar
^^^ Going by description and pictures , looks like I'am getting the whole grill assembly
Old 05-31-2014, 10:35 PM   #7
Originally Posted by Toydos View Post
Just got this >>> Attachment 158281 I've seen two methods to do the mod,one is to remove the bumper, the other is pull it out, what method for the upper grill do you guys recommend, the lower grill seems less complicated
So you're the guy that outbid me?! Damn you!
blp12 is offline   Reply With Quote
Old 05-31-2014, 10:39 PM   #8
Toydos's Avatar
^^^ Open market , there are others up for grabs
Old 05-31-2014, 10:42 PM   #9
dacm99's Avatar
Same process as the upper but disconnect the air sensor just behind grille. Tape off area, thread two shop towels through the lower grille and pull on towels. Should pop out on first try.
Old 05-31-2014, 10:45 PM   #10
Oh I know. You got a good deal though. Good on you.
Old 06-01-2014, 05:26 AM   #11
Toydos's Avatar
What type plug/socket connectors will work on the LED fog lights
Old 06-01-2014, 12:19 PM   #12
I just installed my lower grille this morning. If you put your car on ramps and remove the cover that's attached to the bumper cover you can easily remove the upper and lower without the risk of scratching your paint. You will have to remove about 12-15 7mm bolts. This cover allows you to access the back of the bumper cover from the bottom of the car.
Old 06-02-2014, 04:35 AM   #13
Toydos's Avatar
Looks like the pull method is the choice here , will like to know on the type of plug/socket connector for the lights in order to make them functional and not to go with a premium price pre made harness >>Click image for larger version
Old 06-02-2014, 05:50 AM   #14
After doing the top grille with the pull method I don't recommend it. The lower cover removal is the best way imo to reach the tabs without removing the bumper cover.
Old 06-02-2014, 05:55 AM   #15
Toydos's Avatar
^^^ Thanks for the alert, I'll be doing the removal with extreme care. Any info/hints/tips on the LED fog light connectors
Old 06-02-2014, 09:44 AM   #16
No I'm doing the deletes. I'll see if I can find some info
Old 06-03-2014, 06:05 AM   #17
Toydos's Avatar
Well it looks like this is the option that I have , did my Google and Ebay thing and no plugs surface , this pre made short harness is the one that pops up >>>Click image for larger version
ID:	158488 for 50$
Old 06-03-2014, 09:02 PM   #18
Im getting a gt grill with fog lights too! Im getting as much info as i can get.
2014 Mustang V6 Metallic Gray
michaelboy2375 is offline   Reply With Quote
Mustang GT 5.0 2014 :: 2014 Ford Mustang jeanmorissette Member Garages 0 09-20-2013 07:08 PM
Billet grill that doesnt overlap exitsting grill gorillaz131 2011-2014 V6 Mustang 21 07-10-2013 07:31 AM
Modern Billet Black Grill or Roush Grill kornflake7 2011-2014 Mustang GT 46 05-06-2013 07:05 AM
For Sale: 2014 oem fog lights and grill Joey8 Mustang Parts for Sale and Wanted 16 04-17-2013 06:16 AM
GT Grill different then V6 Grill ? stampde Pre-2005 V6 Mustang 6 11-26-2010 02:35 PM
11:31 AM
